ProXR Lite Series Relay Controllers
ProXR Lite is a no frills version of all of the most used features of our Industry Leading ProXR Series Relay Controllers.
- 1 to 8 Channels of Relay Control
- Wide range of Relay Options
- Swappable Communication Options
- Wired, Wireless, and Network Options
- 8 Channels of Analog to Digital Conversion
- Control locally, wirelessly, or over the internet
- 5 Year Warranty
- 30 Day Worry Free Returns
ProXR Lite - Computer Controlled Relays
ProXR Lite has all of the most popular features of our popular ProXR Series of computer controlled switching. With a simple to use API and an interchangeable communication interface it can easily fill any role in industrial control applications.
Our ProXR Lite Relays are equipped with Computer Controlled firmware built into the board that will allow you to Control one relay at a time, a bank of relays or all relays at once with manual and automatic refreshing command set.
Why Choose NCD?
How It Works
All Wireless Relay Controllers except for WiFi and Wireless Key Fob Relays communicate to a Modem that is connected directly to a PC, ECM, or MCU.
The PC, ECM, or MCU attached to the modem will send serial commands over USB to the modem which will Control and Monitor the Wireless Relays and Sensors within range.
Wireless Relays are equipped with firmware built into the board that will allow you to Control one relay at a time, a bank of relays or all relays at once with manual and automatic refreshing command set.
The Communication Technology you choose will dictate how you will control and monitor the board. If you want to monitor over a LAN or WAN you can choose WiFi, Ethernet, or Web-i. Need wireless control? Choose S3B, Bluetooth, 802.15.4, or ZigBee Mesh. Want Reliable Wired communication? Choose USB, Serial, or RS-485.
WiFi Relays
Much of our development work was done with embedded Wi-Fi. Put simply, we adore this technology and we think you will too. Configuration requires careful attention to our instructions, but once configured…wow. It’s simply amazing and holds so much promise for future development work.
We are working to make configuration easier, but for now, plan on reading our manual found on the product pages BEFORE purchasing. Configuration requires a WiFi Configuration Kit.
S3B Long Range Wireless
Digi XBee-PRO 900HP embedded modules provide best-in-class range wireless connectivity to devices. They take advantage of the DigiMesh® networking protocol, featuring dense network operation and support for sleeping routers, and are also available in a proprietary point-to-multipoint configuration. Supporting RF line-of-sight ranges up to 28 miles (with high-gain antennas), and data rates of up to 200 Kbps, these modules are ideal for extended-range applications requiring increased data throughput.
Digi XBee® modules are easy to use, share a common hardware footprint and are available in a variety of different protocols, enabling users to substitute one Digi XBee for another with minimal development time and risk.
Bluetooth Relays
We offer Bluetooth communications because of its popularity with mobile devices. If you want to control relays with your smartphone (and you are savvy at writing such an application), then Bluetooth is the ideal choice. iPhone, iPad, and iPod developers should be warned, Apple iOS devices encrypt the Bluetooth protocol deliberately, so our Bluetooth interface is compatible with every computer ever made, including Android, PCs (and every version of Windows that supports Bluetooth), and Linux (and all variants thereof that support Bluetooth), but it will NEVER work with Apple iOS devices.
802.15.4 Relays
This is one of our favorite wireless technologies. It is easy to setup and use and very reliable. You need a 802.15.4 modem that plugs into your USB port to talk any number of 802.15.4 Wireless relays with up to 1 mile range! You can purchase a modem with the device you choose.
ZigBee Relays
ZigBee Mesh networking is pretty slow, but extremely powerful and very reliable when you follow all the rules. We highly recommend you purchase a ZigBee Development Kit from www.digi.com before attempting to use this communication technology…this one is for the advanced user. But it has the distinction of offering a low-cost Mesh networking protocol…which means wireless data hops around the wireless network until it reaches the destination device…very cool! Very powerful, very long range, but NOT for the timid.
Key Fob Relays
Our 2nd generation Key Fob Series controllers allow users to control relays from a hand-held remote up to 750 feet away! Configure buttons to toggle relays, turn relays on and off, activate timers and control relay flashers. Integrated security features prevent unauthorized operation while maintaining easy configuration. Pair up to 40 different Key Fob remotes to a single controller.
Serial Relays
Serial communications may seem like old hat, but they’re also one of the most reliable and proven communication protocols available and are in fact the basis of most of the other communication options here.
You can choose between a Serial DB9 Connector or a 3 wire terminal connector for simple wire hookups. DB9 is the standard serial connector while the 3 wire terminal is usually more advanced and for existing ECM’s and serial splicing applications.
USB Relays
When it comes to ease of use, USB can’t be beat. With the reliability of Wired Communications and the pure simplicity of USB Technologies this is one of our most popular interface technologies.
To use USB simply plug it in to your computer/ECM, the driver should automatically be installed or already be installed, and open a COM/Serial Port to it. We use an industry standard FTDI chip for added reliability and compatibility across all Operating Systems.
RS-485 Relays
RS-485 Serial Communications makes it easy to network up to 256 NCD devices together at distances up to 4,000 feet. Each RS-485 node includes 3 screw-terminals for a 3-wire connection to the RS-485 master. Since RS-485 is a physical layer networking protocol, users will make use of the NCD E3C command set to select which device they are speaking to at the software layer. Using the E3C protocol, communicate to each device individually or all devices simultaneously.
Ethernet Relays
Ethernet communications combine the reliability of a wired connection with the power of network communications. Control your devices reliably from anywhere in the world by implementing a simple socket directly to the device.
Web-i Relays
Our Web-i Relays offer a web interface to control relays and monitor inputs directly from your browser. You can set this web site up to be accessed anywhere in the world and password protect it.
For simple remote relay control and data monitoring without any code it doesn’t get any easier than the Web-i.
