Node-RED Dashboard Flow
Usage
The Flow
[{"id":"400cba0d.021bd4","type":"ncd-wireless-node","z":"13754c0b.dca3a4","name":"Pressure/Temperature","connection":"","config_comm":"","addr":"","sensor_type":"6","auto_config":true,"node_id":0,"delay":"5","destination":"0000FFFF","power":"1","retries":10,"pan_id":"7FFF","change_enabled":false,"change_pr":"0","change_interval":"0","cm_calibration":"0","bp_altitude":"0","bp_pressure":"0","bp_temp_prec":"0","bp_press_prec":"0","amgt_accel":"0","amgt_mag":"0","amgt_gyro":"0","x":120,"y":340,"wires":[["af59356d.0f23f8","9a2a7cbf.76161"]]},{"id":"af59356d.0f23f8","type":"split","z":"13754c0b.dca3a4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":310,"y":320,"wires":[["e24a52cf.d53e2"]]},{"id":"e24a52cf.d53e2","type":"switch","z":"13754c0b.dca3a4","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"absolute_pressure","vt":"str"},{"t":"eq","v":"relative_pressure","vt":"str"},{"t":"eq","v":"altitude_change","vt":"str"},{"t":"eq","v":"temperature","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":430,"y":320,"wires":[["8aecc887.85b3a8","f9ca4edf.47aa4"],["a59fc3b1.f0d74","ee7b70f5.01003"],["b66e142a.3e3ae8","949b51d2.d1e08"],["91a15743.aa9538"]]},{"id":"8aecc887.85b3a8","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"8b6cb092.e5788","order":1,"width":"12","height":"6","label":"Absolute Pressure","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":990,"y":200,"wires":[[],[]]},{"id":"9a2a7cbf.76161","type":"change","z":"13754c0b.dca3a4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"data.battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":580,"wires":[["238470ce.4d10f"]]},{"id":"786bff29.83c1f","type":"ncd-gateway-node","z":"13754c0b.dca3a4","name":"","connection":"","x":170,"y":140,"wires":[["e2d8807d.240c6"]]},{"id":"e2d8807d.240c6","type":"debug","z":"13754c0b.dca3a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":430,"y":80,"wires":[]},{"id":"91a15743.aa9538","type":"function","z":"13754c0b.dca3a4","name":"C to F","func":"msg.payload = (msg.payload * 1.8) + 32;\nreturn msg;","outputs":1,"noerr":0,"x":610,"y":500,"wires":[["4adf4a13.461a44","5cc8646d.11e81c"]]},{"id":"4adf4a13.461a44","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":4,"width":"6","height":"4","gtype":"gage","title":"Temperature","label":"Fahrenheit","format":"{{value | number:2}}","min":"30","max":"100","colors":["#dad0ff","#2ce619","#ca3838"],"seg1":"","seg2":"","x":770,"y":520,"wires":[]},{"id":"238470ce.4d10f","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":5,"width":"6","height":"4","gtype":"gage","title":"Battery","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#e00600","#e6e600","#07ca00"],"seg1":"","seg2":"","x":680,"y":580,"wires":[]},{"id":"5cc8646d.11e81c","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"8b6cb092.e5788","order":4,"width":"12","height":"6","label":"Temperature","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":970,"y":500,"wires":[[],[]]},{"id":"f9ca4edf.47aa4","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":1,"width":"4","height":"4","gtype":"gage","title":"Absolute Pressure","label":"mbar","format":"{{value}}","min":0,"max":"30","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":770,"y":200,"wires":[]},{"id":"ee7b70f5.01003","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"8b6cb092.e5788","order":2,"width":"12","height":"6","label":"Relative Pressure","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":990,"y":280,"wires":[[],[]]},{"id":"a59fc3b1.f0d74","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":2,"width":"4","height":"4","gtype":"gage","title":"Relative Pressure","label":"mbar","format":"{{value}}","min":0,"max":"30","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":770,"y":280,"wires":[]},{"id":"949b51d2.d1e08","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"8b6cb092.e5788","order":3,"width":"12","height":"6","label":"Altitude Change","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":980,"y":380,"wires":[[],[]]},{"id":"b66e142a.3e3ae8","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":3,"width":"4","height":"4","gtype":"gage","title":"Altitude Change","label":"m","format":"{{value}}","min":0,"max":"30","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":760,"y":380,"wires":[]},{"id":"8b6cb092.e5788","type":"ui_group","z":"","name":"Pressure/Temperature","tab":"38410f18.307bb","disp":true,"width":"24","collapse":false},{"id":"60afd6aa.b52828","type":"ui_group","z":"","name":"Pressure/Temperature","tab":"4c7c29de.f9ea38","disp":true,"width":"12","collapse":false},{"id":"38410f18.307bb","type":"ui_tab","z":"","name":"History","icon":"dashboard"},{"id":"4c7c29de.f9ea38","type":"ui_tab","z":"","name":"Current","icon":"dashboard"}]
