Node-RED Dashboard Flow
Usage
The Flow
[{"id":"400cba0d.021bd4","type":"ncd-wireless-node","z":"13754c0b.dca3a4","name":"","connection":"","config_comm":"","addr":"","sensor_type":"4","auto_config":true,"node_id":0,"delay":"5","destination":"0000FFFF","power":"1","retries":10,"pan_id":"7FFF","change_enabled":false,"change_pr":"0","change_interval":"0","cm_calibration":"0","bp_altitude":"0","bp_pressure":"0","bp_temp_prec":"0","bp_press_prec":"0","amgt_accel":"0","amgt_mag":"0","amgt_gyro":"0","x":90,"y":340,"wires":[["9a2a7cbf.76161","af59356d.0f23f8"]]},{"id":"8aecc887.85b3a8","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"8b6cb092.e5788","order":1,"width":"0","height":"0","label":"Temperature","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"step","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"1","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"colors":["#00e40f","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":710,"y":240,"wires":[[],[]]},{"id":"9a2a7cbf.76161","type":"change","z":"13754c0b.dca3a4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"data.battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":440,"wires":[["238470ce.4d10f"]]},{"id":"786bff29.83c1f","type":"ncd-gateway-node","z":"13754c0b.dca3a4","name":"","connection":"","x":190,"y":160,"wires":[["e2d8807d.240c6"]]},{"id":"e2d8807d.240c6","type":"debug","z":"13754c0b.dca3a4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":450,"y":100,"wires":[]},{"id":"238470ce.4d10f","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":2,"width":"12","height":"4","gtype":"gage","title":"Battery","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#e00600","#e6e600","#07ca00"],"seg1":"","seg2":"","x":540,"y":440,"wires":[]},{"id":"74ab95f3.c4efac","type":"function","z":"13754c0b.dca3a4","name":"C to F","func":"msg.payload = (msg.payload * 1.8) + 32;\nreturn msg;","outputs":1,"noerr":0,"x":450,"y":300,"wires":[["8aecc887.85b3a8","6d7d915b.663c3"]]},{"id":"af59356d.0f23f8","type":"split","z":"13754c0b.dca3a4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":310,"y":320,"wires":[["74ab95f3.c4efac","e2d8807d.240c6"]]},{"id":"6d7d915b.663c3","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"60afd6aa.b52828","order":1,"width":"12","height":"4","gtype":"gage","title":"Temperature","label":"Fahrenheit","format":"{{value | number:2}}","min":"20","max":"100","colors":["#8e9aff","#00e614","#ff0c00"],"seg1":"","seg2":"","x":710,"y":320,"wires":[]},{"id":"8b6cb092.e5788","type":"ui_group","z":"","name":"Thermocouple","tab":"38410f18.307bb","disp":true,"width":"24","collapse":false},{"id":"60afd6aa.b52828","type":"ui_group","z":"","name":"Thermocouple","tab":"4c7c29de.f9ea38","disp":true,"width":"12","collapse":false},{"id":"38410f18.307bb","type":"ui_tab","z":"","name":"History","icon":"dashboard"},{"id":"4c7c29de.f9ea38","type":"ui_tab","z":"","name":"Current","icon":"dashboard"}]
