![Wireless Enterprise ADC Dashboard](https://media.ncd.io/20180808104515/Screen-Shot-2018-08-08-at-9.47.40-AM.png)
Node-RED Dashboard Flow
Usage
![](https://media.ncd.io/20180808104604/Screen-Shot-2018-08-08-at-9.48.11-AM-1024x846.png)
The Flow
[{"id":"128499f8.93e056","type":"ncd-gateway-node","z":"95b1ec27.9fae5","name":"","connection":"","x":490,"y":320,"wires":[["c46e88b2.17d308"]]},{"id":"b8b2f766.dcbb48","type":"switch","z":"95b1ec27.9fae5","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"input_1","vt":"str"},{"t":"eq","v":"input_2","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1070,"y":480,"wires":[["5021590d.bf6f68"],["8a4de388.55bc9"]]},{"id":"a092304c.8edce","type":"split","z":"95b1ec27.9fae5","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":630,"y":480,"wires":[["4a563dc7.1ad264"]]},{"id":"f4cbd0e4.11b03","type":"ncd-wireless-node","z":"95b1ec27.9fae5","name":"","connection":"","config_comm":"","addr":"","sensor_type":"3","auto_config":false,"node_id":0,"delay":300,"destination":"0000FFFF","power":4,"retries":10,"pan_id":"7FFF","change_enabled":"","change_pr":"0","change_interval":"0","cm_calibration":"60.6","bp_altitude":"0","bp_pressure":"0","bp_temp_prec":"0","bp_press_prec":"0","amgt_accel":"0","amgt_mag":"0","amgt_gyro":"0","impact_accel":"0","impact_data_rate":"4","impact_threshold":25,"impact_duration":1,"activ_interr_x":1,"activ_interr_y":2,"activ_interr_z":4,"activ_interr_op":8,"x":470,"y":480,"wires":[["a092304c.8edce","d5c92f84.b9e07"]]},{"id":"542cdc32.ad6d24","type":"ui_chart","z":"95b1ec27.9fae5","name":"","group":"8f08e849.547418","order":0,"width":0,"height":0,"label":"Input History","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"3.3","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":1090,"y":360,"wires":[[],[]]},{"id":"c46e88b2.17d308","type":"debug","z":"95b1ec27.9fae5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":930,"y":280,"wires":[]},{"id":"2daa15.908a15ec","type":"ui_gauge","z":"95b1ec27.9fae5","name":"","group":"b8a7bc9b.086d6","order":3,"width":0,"height":0,"gtype":"gage","title":"Battery","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#ff0011","#e6e600","#09ca00"],"seg1":"","seg2":"","x":1080,"y":580,"wires":[]},{"id":"d5c92f84.b9e07","type":"change","z":"95b1ec27.9fae5","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"data.battery","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":820,"y":580,"wires":[["2daa15.908a15ec"]]},{"id":"4a563dc7.1ad264","type":"range","z":"95b1ec27.9fae5","minin":"0","maxin":"1023","minout":"0","maxout":"3.3","action":"clamp","round":false,"property":"payload","name":"","x":830,"y":480,"wires":[["b8b2f766.dcbb48","542cdc32.ad6d24"]]},{"id":"5021590d.bf6f68","type":"ui_gauge","z":"95b1ec27.9fae5","name":"","group":"b8a7bc9b.086d6","order":1,"width":"6","height":"6","gtype":"gage","title":"Input 1","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#24c928","#e6e600","#ff0700"],"seg1":"","seg2":"","x":1260,"y":440,"wires":[]},{"id":"8a4de388.55bc9","type":"ui_gauge","z":"95b1ec27.9fae5","name":"","group":"b8a7bc9b.086d6","order":2,"width":"6","height":"6","gtype":"gage","title":"Input 2","label":"V","format":"{{value | number:2}}","min":0,"max":"3.3","colors":["#24c928","#e6e600","#ff0700"],"seg1":"","seg2":"","x":1260,"y":500,"wires":[]},{"id":"8f08e849.547418","type":"ui_group","z":"","name":"Default","tab":"c4f82725.5cb928","disp":false,"width":"12","collapse":false},{"id":"b8a7bc9b.086d6","type":"ui_group","z":"","name":"Status","tab":"104ce52d.cc60bb","order":1,"disp":true,"width":"12","collapse":false},{"id":"c4f82725.5cb928","type":"ui_tab","z":"","name":"History","icon":"dashboard","order":4},{"id":"104ce52d.cc60bb","type":"ui_tab","z":"","name":"Current","icon":"dashboard","order":1}]
![](https://media.ncd.io/20180808104634/Screen-Shot-2018-08-08-at-9.48.55-AM-1024x474.png)
