AMS5915 Dashboard - Historic
Node-RED Dashboard Flow
The examples in this series are for use with Node-RED and our NCD IoT line of products. If you haven’t already, check out this post, which will provide the resources required to get your environment set up.
Usage
From the command line (Power Shell for Windows users), navigate to the Node-RED directory and type npm i ncd-red-ams5915, then start Node-RED.
Double click on the AMS5915 node and set up the “I2C Connection” field.
You also need to update the sensor type, the info tab has more information.
Deploy the flow and you will begin receiving telemetry at the interval indicated by the sensor node settings.
The Flow
[{"id":"b084cf2d.b73b6","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"d79de0e4.bda58","order":2,"width":0,"height":0,"gtype":"gage","title":"Temperature (Current)","label":"Fahrenheit","format":"{{value | number:2}}","min":0,"max":"100","colors":["#4288ff","#0de617","#ff312d"],"seg1":"","seg2":"","x":470,"y":360,"wires":[]},{"id":"966d9f8d.a3776","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"e42b58e2.7254b8","order":2,"width":"8","height":"5","label":"Temperature (Historic)","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#0eb417","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":470,"y":320,"wires":[[],[]]},{"id":"4f759e4d.a8b1","type":"ui_chart","z":"13754c0b.dca3a4","name":"","group":"e42b58e2.7254b8","order":1,"width":"8","height":"5","label":"Pressure (Historic)","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"x":470,"y":160,"wires":[[],[]]},{"id":"be16cc6f.47a6","type":"ui_gauge","z":"13754c0b.dca3a4","name":"","group":"d79de0e4.bda58","order":1,"width":0,"height":0,"gtype":"gage","title":"Pressure (Current)","label":"mBar","format":"{{value | number:2}}","min":"-1.5","max":"1.5","colors":["#ff151a","#e6e600","#18ca10"],"seg1":"","seg2":"","x":470,"y":200,"wires":[]},{"id":"68a3f00b.aef48","type":"ncd-ams5915","z":"13754c0b.dca3a4","name":"","connection":"","interval":"500","range":5,"sType":"d-b","pScale":1,"tempScale":"f","x":160,"y":260,"wires":[["4f759e4d.a8b1","be16cc6f.47a6"],["b084cf2d.b73b6","966d9f8d.a3776"]]},{"id":"d79de0e4.bda58","type":"ui_group","z":"","name":"Default","tab":"104ce52d.cc60bb","disp":false,"width":"12","collapse":false},{"id":"e42b58e2.7254b8","type":"ui_group","z":"","name":"Default","tab":"459c002f.aa916","disp":false,"width":"16","collapse":false},{"id":"104ce52d.cc60bb","type":"ui_tab","z":"","name":"Current","icon":"dashboard"},{"id":"459c002f.aa916","type":"ui_tab","z":"","name":"History","icon":"dashboard"}]
AMS5915 Flow
Check out a full list of AMS5915 products on our store!
ncd.io
Made in the USA
5 Year Warranty
Log in with your credentials
or
Forgot your details?
Create Account
