NCD Wireless Sensor Configuration Commands
Sending Configuration Commands - Overview
The following guide demonstrates the fundamental configuration commands required to configure NCD Enterprise Low-Power Long Range Wireless Sensors.  A Wireless USB Modem will be required to configure NCD wireless sensors over a wireless connection.  The examples shown below assume prior knowledge of DigiMesh® API Packet Structure, including MAC addresses and checksum calculations.  We STRONGLY ADVISE using NCD Alpha Station software to configure sensors; however, if integration of sensor configuration is absolutely required, the commands shown below may be used.
Please note the MAC address MUST be changed (shown in the API frames below as 00 13 A2 00 41 91 1B 83) to match the MAC address of a remote sensor.  The checksum must also be re-calculated (the last byte of the API frame) to include the new MAC address.  Additionally, the PAN ID must be set to 0x7BCD.   This PAN ID is reserved for configuration ONLY, and may not be used for daily operation.
A working sample of configuration with source code is available by downloading Alpha Station software.  Alpha Station includes an installer but also runs as editable source code under Microsoft Visual Studio Community Edition, a FREE download from Microsoft.  Alpha Station handles all configuration commands automatically and is capable of configuring every device that has been discovered.
The commands shown below are explained in greater detail within product manuals, this guide is a summary overview of all configuration command samples.  Also note that configuration commands cannot be sent to NCD wireless sensors while in run mode.  Each sensor must be placed in configuration mode, which will drain the battery very quickly.  Be SURE to execute these commands quickly and return each sensor to RUN mode to preserve battery life.  Optionally, select NCD wireless sensors may be powered from a external power supply during configuration.
Enter Configuration Mode
Step 1 : Power up the sensor.
Step 2: Every sensor has 2 buttons: Reset and Configuration (RST and CFG).  Enter configuration mode by holding both buttons down.  Next, release the reset button.  Wait 6 seconds and release the CFG button.  The sensor will send a Configuration API frame, indicating configuration mode is active.  The API frame will look similar to this:
7E 00 1C 90 00 13 A2 00 41 91 1B 83 FF FE C2 7A 00 00 00 23 00 00 50 47 4D 00 00 00 00 00 00 0A
Above command contains the sensor MAC address. This MAC address may be used to send future targeted commands to this particular sensor.
In the above case, the MAC address is:
Note: Throughout this guide we will be sending data in broadcast mode and sensors ID and node ID will be set to 0. This is done to make these commands work with all the sensors and all the nodes. These commands may be used with all the sensors without any change.
For optimal performance keep only one sensor in config mode at a time.
Reminder: During configuration mode, the sensor PAN id needs to be set as 0x7BCD.  When using Alpha Station software, this operation is completed automatically during configuration.
Warning: Batteries will drain quickly in configuration mode.  Be sure to exit configuration mode as soon as possible by pressing and releasing the Reset (RST) Button on the sensor once configuration changes have been completed.
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Set Wireless Sensor Transmission Power Level
This command may be used to change the sensor transmission power. The default value is 0x04, which indicates the highest transmission power and shortest battery life. Setting this value lower will reduce the wireless range and improve battery life.
If long range is not required, setting this value lower in all sensors with close proximity will greatly improve battery life.
The following Command may be used to change the wireless module power level:
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 04 00 00 00 03 F6
Above Command Contains Sensor payload which contains new power level value.
Complete Payload
F7 04 00 00 00 03
F7 is the command header byte and 04 is the sub command for setting the Sensor Transmit Power Level.
In the Above command, we set the new power level to 3 (byte 23).
7E 00 1C 90 00 13 A2 00 41 91 1B 83 FF FE C1 7C 00 19 00 0E 00 00 FF 00 00 00 00 00 00 00 00 EA
Read Wireless Sensor Retries
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries
Complete Payload
F7 06 00 00 00 05
Complete Payload
Configuration Commands Table
1Set Broadcast Transmission 0XF70x01–0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15–0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16–0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17–0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18–00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19–0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01–0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02––Disables the Encryption of the Frame Transmitted from the Sensor
