- Industrial Grade 3-axis Vibration Sensor with RMS, MAX and MIN g vibration
- Vibration Range ±16g
- Noise Removal using Low pass filter
- Offset Removal at Power up
- Two modes of Operation
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s Long Range IoT Wireless Vibration Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture. Incorporating a STMicro LSM9DS1 sensor, transmits highly accurate data at user-defined intervals.
This Vibration Sensor samples 3-axis of Accelerometer for vibration for 100 msec and then calculates RMS, Maximum and Minimum Vibration in this interval. It then combines this data with temperature samples in a packet to be sent to one or multiple receivers. At power up, it reads multiple samples and takes their average as an offset value. This value is subtracted from every sample taken afterwards. Therefore, make sure to power off the device under test during sensor power up. Once the sensor stabilizes and starts sending data, the device/machinery under test can be powered on. After it sends data for the 100msec interval, it goes back to sleep for a user defined interval, thus minimizing power consumption.
The long range, price, accuracy, battery life and security features of Wireless Vibration Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Wireless Industrial Vibration
- Orientation Applications
- Home Automation
2. Getting Started With Wireless Vibration Sensor
The Vibration Sensor and Zigmo/Router come pre-programmed and work out of the box. In this section we will setup a sensor and Zigmo link and start receiving data on our PC. Though this guide shows how to visualize data on LabVIEW utility, you can also use a simple serial terminal to see raw data by following these steps.
- IoT Long Range Wireless Vibration And Temperature Sensor (with power source Battery Or External DC)
- Press the port configure button and select the PORT you identified in step 3. Select baud rate of 9600 and press OK.
- Run Mode
- Configuration Mode
In configuration mode, the device sets its X-bee pan id to 7BCD (ASCII). Also, the destination address used by the sensor is broadcast (0000FFFF). This ensures that once you put a device in configuration mode you just need to change the PAN ID of your Zigmo to match with sensor and start configuring your device. You can change the PAN ID of your Zigmo using XCTU from Digi. If you use our LabVIEW utility, it will automatically change Zigmo PAN ID once you open the configuration window. When you exit this window your PAN ID will be restored to old value.
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0008 F4
