- Industrial Grade Sensor with Ambient Temperature Range -200°C [-328°F] to 260°C [500°F])
- Resolution 0.0625°C
- Accuracy of ±2.2°C
- Two modes of Operation
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s Long Range Wireless Thermocouple Sensor , boasting up to a 28 Mile range using a wireless mesh networking architecture. Incorporating a MICROCHIP MCP9600 sensor, transmits highly accurate temperature samples at user-defined intervals.
The on-board thermocouple sensor is rated for -200°C to 260°C or -328°F to 500°. Powered by just 2 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered.
The long range, price, accuracy, battery life and security features of Long Range Wireless Thermocouple Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Industrial Equipment Thermal Management
- Industrial Engine Thermal Monitor
- Petrochemical Thermal Management
- Hand-held Measurement Equipment
- Temperature Detection Racks
- Wireless Thermal Monitoring For Raspberry Pi/Arduino
- Home Automation
- IoT Long Range Wireless Thermocouple Temperature Sensor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
Frame Field | Offset (Payload Section) | Fixed Value (if any) | Description |
Header | 0 | 0x7F | Header to differentiate various type of packets |
Node ID | 1 | 0x00 Factory Default | Node ID to differentiate up to 256 nodes in a network. User configural values |
Firmware | 2 | – | Used to determine firmware version programmed in the device |
Battery Voltage | MSB 3 | – | Sampled battery voltage of the device. Battery Voltage =((Battery Voltage MSB x 256 +Battery Voltage LSB) x 0.00322 V |
LSB 4 | – | ||
Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
Sensor Type | MSB 6 | 0x00 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
LSB 7 | 0x04 | ||
Reserved | 8 | 0x00 | For future use |
Sensors Data | MSB 9/ Data[0] | – | Temperature data Temperature(signed) (data[0]<<24)+(data[1]<<16)+(data[2]<<8)+(data[3]) = ———————————————————————- 100 |
10/ Data[1] | – | ||
11/ Data[2] | – | ||
LSB 12/ Data[3] | – |
2 Channel Thermocouple
Frame Field | Offset (Payload Section) | Fixed Value (if any) | Description | |
Header | 0 | 0x7F | Header to differentiate various types of packets | |
Node ID | 1 | 0x00 Factory Default | Node ID to differentiate up to 256 nodes in a network. User configural values | |
Firmware | 2 | – | Used to determine firmware version programmed in the device | |
Battery Voltage | MSB 3 | – | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V | |
LSB 4 | – | |||
Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. | |
Sensor Type | MSB 6 | 0x00 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end | |
MSB 7 | 0x17 | |||
Reserved | 8 | 0x00 | For future use | |
10/ Data[1] | – | |||
11/ Data[2] | – | |||
LSB 12/ Data[3] | – | |||
Sensors Data | MSB 13/ Data[0] | – |
14/ Data[1] | – | |||
15/ Data[2] | – | |||
LSB 16/ Data[3] | – |
3 Channel Thermocouple
Header | 0 | 0x7F | Header to differentiate various type of packets | |
Battery Voltage | MSB 3 | – | Sampled battery voltage of the device. Battery Voltage =((Battery Voltage MSB x 256 +Battery Voltage LSB) x 0.00322 V | |
LSB 4 | – | |||
LSB 7 | 0x0C | |||
Sensors Data | MSB 9/ Data[0] | – | Temperature data Temperature(signed) (data[0]<<24)+(data[1]<<16)+(data[2]<<8)+(data[3]) = ———————————————————————- 100 | |
Sensors Data | MSB 13/ Data[0] | – | Temperature data Temperature(signed) (data[0]<<24)+(data[1]<<16)+(data[2]<<8)+(data[3]) = ———————————————————————- 100 | |
LSB 16/ Data[3] | – | |||
Sensors Data | MSB 17/ Data[0] | – | Temperature data Temperature(signed) (data[0]<<24)+(data[1]<<16)+(data[2]<<8)+(data[3]) = ———————————————————————- 100 | |
18/ Data[1] | – | |||
19/ Data[2] | – | |||
LSB 20/ Data[3] | – |
3 Wire RTD Sensor Type 39
LSB 4 | – | ||
LSB 7 | 0x27 | ||
Reserved | 8 | Error Code | 0x20 — VBIAS Fault 0x10 — VBIAS Force- close 0x08 — VBIAS Force- open 0x04 — Over and under Voltage |
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0004 F8
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0004 0000 0004 F3
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0004 1234 5678 E2
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0004 02F3
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0004 7CDE 9A
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0004 03F0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0004 E3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0004 E2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0004 E1
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0004 E0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0004 FD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0004 FC
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0004 0011 2211 2211 2211 2233 4433 4433 4433 4453
B. Appendix
- Keep only the last 8 bits
C. Hardware and Firmware Changes
Hardware
Status LED added.
LED blink Once — No error, and the last message was sent successfully
Led Blink Twice + One Time — Encountered an error while communicating to Thermocouple, and the last message was sent successfully
Led Blink Thrice — Encountered an error while communicating to Radio Module
Firmware
1. Supports multiple type of thermocouple ( K,J,T,N,S,E,B,R) Set Thermocouple Type Command -- K Type 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 53 00 00 1700 96 Paylod -- F4 53 00 00 17 00 F4 -- Command Header 53 -- Sub command 00,00,17 -- Reserved 00 -- Thermcouple type For K type Thermocouplt Type Byte is 00 Type K -> TC_TYPE_DEFAULT=0x00 Type J -> TC_TYPE_DEFAULT=0x10 Type T -> TC_TYPE_DEFAULT=0x20 Type N -> TC_TYPE_DEFAULT=0x30 Type S -> TC_TYPE_DEFAULT=0x40 Type E -> TC_TYPE_DEFAULT=0x50 Type B -> TC_TYPE_DEFAULT=0x60 Type R -> TC_TYPE_DEFAULT=0x70 2. Get Thermocouple Type Command 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 54 00 00 17 95 3. Set Filter 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 55 00 00 17 01 93 4. Get Filter 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 56 00 00 17 93 5. Set Cold Junction Resolution 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 57 00 00 17 80 12 6. Get Cold Junction Resolution 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 58 00 00 17 91 7. Set Internal sample Resolution to 16bit ( Supported resolution are 16bit,14bit and 12bit) 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 59 00 00 17 20 70 8. Get Internal sample Resolution 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 5A 00 00 17 8F 9. Set Number Of samples 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 5B 00 00 17 04 8A 10. Get Number Of samples 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 5C 00 00 17 8D 11. Sert Measurement Type 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 5F 00 00 17 02 88 12. Get Measurement Type 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 60 00 00 17 89
