Long Range IoT Wireless Temperature Humidity Sensor Product Manual
  • Industrial Grade Sensor with Range 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
  • Resolution 0.04% RH/0.025°C
  • Accuracy 4% RH/ 0.5°C
  • 256 Sensor Node per Network
  • Two modes of Operation
  • Improved reliability incorporating Retry feature in case of packet loss
  • Real time battery status
  • In House Temperature Humidity monitoring
  • Storage Unit Weather Monitoring System
  • Warehouse Temperature Humidity Monitoring System
  • Wireless Temperature Humidity Sensor For Crawl Space
  • Temperature Humidity Sensor For Device Control Application
  • Wireless Temperature Humidity Monitoring For Raspberry Pi/Arduino
  • Home Automation
Introducing NCD’s long-range wireless temperature humidity sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  Incorporating the Honeywell HIH9130 temperature humidity sensor, transmits highly accurate temperature and humidity samples at user-defined intervals.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 100% RH.  Powered by just 2 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered.
With an open communication protocol this IoT wireless temperature humidity product can be integrated with just about any control system or gateway.  Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Long Range Wireless Temperature Humidity Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  1. Power-up the Wireless Sensor and make sure its antenna is installed
Figure 3: LabVIEW Utility for Temp Humidity Sensor
Figure 4: LabVIEW Utility for Temp Humidity sensor showing incoming data
Modes of Operation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x01
Reserved80x00
For future use
Sensors DataMSB 9/ Data[0]0x00
Humidity data
    Humidity(usigned) = ((data[0] x 256) + data[1])/100
10/ Data[1]0x01F
11/ Data[2]0x00
Temperature data
    Temperature(signed) = (((data[2] x 256) + data[3])/100)°C
LSB 12/ Data[3]0xAA
Appendix A
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0001 FB
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0001 0000 0004 F6
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0001 1234 5678 E5
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0001 02F6
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0001 03F3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0001 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0001 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0001 00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0001 FF
Appendix B
  2. Keep only the last 8 bits
  • Industrial Grade Sensor with µs latency
  • Sleeps when no push input detected
Introducing NCD’s IoT Wireless Push Notification Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture.  It transmits highly accurate frames with low latency for every push input or at user-defined intervals.
The range, price, accuracy, battery life and security features of Wireless Push Notification Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with IoT Long Range Wireless 24V AC/DC Voltage Detection Sensor as well.
  • Push Notification
  • Wireless input change detection
  • Digital signal monitoring
  • Home Automation
battery powered iot push notification
  • Push Notification Type Iot Wireless Sensor (with power source Battery Or External DC)
  • Zigmo/Router for PC (One Router will work with Multiple Sensors)
  • ·         PC/Laptop with an OS installed or Any IoT Embedded Device
  • ·         LabVIEW Utility for displaying sensor data (available on our website for free)
  • Run Mode
(if any)
Header00x7FHeader to differentiate various type of packets
Firmware2–
LSB 4–
Packet Counter5–
MSB 70x02
Reserved80x00
For future use
Sensors Data9/Data[0]–Input 1 – High Input: 1, Low Input: 0
Sensors Data10/Data[1]–Input 2 – High Input: 1, Low Input: 0
Reserved110x00
120x00
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0002 FA
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0002 0000 0004 F5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0002 1234 5678 E4
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0002 02F5
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0002 7CDE 9C
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0002 03F2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0002 E6
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0002 E5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0002 E4
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0002 E3
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0002 E2
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0002 FF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0002 FE
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0002 0011 2211 2211 2211 2233 4433 4433 4433 4455
B. Appendix
Battery
Transmissions Per Hour
Expected Battery Life
