- Industrial Grade Single Channel Counter with Reset Input
- 32 bit counter
- Minimum detectable pulse width 100 msec
- Highly Accurate Pulse Counting
- Low Latency Transmission
- Adjustable Counting Threshold for transmission (factory configurable)
- Two modes of Operation
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s Long Range IoT Wireless One Channel Counter with Reset, boasting up to a 28 Mile range using a wireless mesh networking architecture. It incorporates a low latency counter that never misses a pulse even during sleep. The device normally sleeps during no activity. If a pulse arrives at input, it wakes up, counts it and if the number of pulses counted is a multiple of Counting Threshold then it sends a packets with the total number of pulses detected until then. The reset input serves to reset the number of counts to 0 at any time.
Afterwards it goes back to sleep. It also wakes up periodically after user defined delay and sends latest number of pulse counts. Thus with both functions it maximizes power efficiency.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless One Channel Counter with Reset makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Pulse counting
- Relay on/off counting
- Home Automation
- IoT Long Range Wireless One Channel Counter Transmitter(with power source Battery Or External DC)
- Run Mode
- Configuration Mode
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
Packet Counter | 5 | – |
Sensor Type | MSB 6 | 0x00 |
MSB 7 | 0x23 | ||||
Reserved | 8 | 0x00 |
Sensors Data | 9/ Data[0] | – | Counter Counts Counts = (Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+(Data[3]) | ||
10/ Data[1] | – | ||||
11/ Data[2] | – | ||||
12/ Data[3] | – |
