iot wireless light sensor
Long Range IoT Wireless Light Sensor Product Manual
  • Industrial Grade Wireless Ambient Light Sensor with 16 bit resolution
  • Ambient Light Range 0 to 65k lux
  • Resolution 1 lux
  • Ambient Light Sample Update rate of 2.5 samples/sec
  • Auto sample transmission on Ambient Light change detection periodically (configurable duration)
  • Configurable Ambient Light change detection percentage
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless Light Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  It incorporates TSL4531 Digital Ambient Light Sensor and a transceiver that sends data at user defined intervals while sleeping during the time it is not sending data to minimize power consumption.
It has an additional feature of detecting change in ambient light at user defined detection time intervals and sending out sample if the change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change in Ambient Light. Both of these features work in parallel to support multiple application areas in one package.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless Ambient Light Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Wireless Outdoor Lighting Control
  • Wireless Automotive Instrumentation
  • Industrial and Commercial Lighting Systems
  • Home Automation
Default Parameters programmed after Factory reset sequence
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x0A
Reserved80x00
For future use
 Sensor DataSensors Data9/ Data[0] –
Ambient Light data
Ambient Light Lux/Counts(unsigned)=(Data[1]<<)+Data[2])x1
10/ Data[1]
11/ Data[2]
12
Reserved
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 000A F2
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 000A 0000 0004 ED
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 000A 1234 5678 DC
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 000A 02ED
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 000A 7CDE 94
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 000A 03EA
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 000A DE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 000A DD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 000A DC
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 000A DB
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 000A DA
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 000A F7
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 000A F6
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 000A 0011 2211 2211 2211 2233 4433 4433 4433 444D
Command For COPY: 7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 000A 0014 0000 0ACE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 000A D9
B. Appendix
  2. Keep only the last 8 bits
