NCD is Currently Experiencing Heavy Order Volumes. Order Processing Time is Now Between 5 and 10 Business Days. We Thank You for Your Patience and Support as We Work to Fulfill Customer Orders as Timely as Possible.
We will be closed Monday May 28th for Memorial Day. Dismiss
  • Industrial Grade Wireless Current Monitor (RMS output)
  • Range 0-100A
  • Auto Time Delay based data sample transmission or on current change detection (configurable duration in both cases)
  • Configurable Current change detection bounds
  • Configurable Current Sensor Calibration over the wireless link
  • Two modes of Operation
    1. User Configurable Sleep duration
    2. Up to 500,000 Transmissions from 2 AA Batteries
  • Real time battery status
  2. Press the port configure button and select the PORT you identified in step 3. Select baud rate of 9600 and press OK.
                                                    Long Range Industrial IoT Wireless Current Sensor Complete Manual Can be Found Over Here
ControlAnything.com and ControlEverything Site Migration Notes
©2018 National Control Devices, LLC
ncd.io
Made in the USA
5 Year Warranty
Log in with your credentials
or
Forgot your details?
Create Account
