NCD is Currently Experiencing Heavy Order Volumes. Order Processing Time is Now Between 5 and 10 Business Days. We Thank You for Your Patience and Support as We Work to Fulfill Customer Orders as Timely as Possible.
We will be closed Monday May 28th for Memorial Day. Dismiss
  • Industrial Grade Wireless Current Monitor (RMS output)
  • Range 0-100A
  • Auto Time Delay based data sample transmission or on current change detection (configurable duration in both cases)
  • Configurable Current change detection bounds
  • Configurable Current Sensor Calibration over the wireless link
  • 256 Sensor Nodes per Network
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless Current Monitor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  It works together with a split core current sensor. It samples current at a high data rate and calculates the current RMS value during that time. This process is repeated at user defined intervals while sleeping in between to minimize power consumption.
It has an additional feature of detecting change in current at user defined detection time intervals and sending out data if the current change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change. Both of these features work in parallel to support multiple application areas in one package.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless Current Monitor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Industrial Current Monitoring
  • Current Abnormality detection
  • Handheld Current monitoring equipment
  • Home Automation
  2. Press the port configure button and select the PORT you identified in step 3. Select baud rate of 9600 and press OK.
  • Run Mode
  • Configuration Mode
Figure 13: Run mode packet being received in a terminal along with power up packet along with run mode power up packet (Hex mode)
