Wireless Accelereo Gyro Magneto Sensor
Long Range IoT Wireless Accelerometer Gyroscope Magneto Temperature Sensor Product Manual
  • Industrial Grade Sensor with 3-axis Acceleration, 3-axis Angular Rate, 3-axis Magnetic Gauss and Temperature Output
  • Acceleration Range up to ±16g
  • Configurable Acceleration Resolution 0.061 to 0.732mg
  • Angular Rate Range up to  ±2000dps
  • Configurable Angular Rate Resolution 8.75 to 70dps
  • Magnetic gauss Range up to ±16gauss
  • Configurable Magnetometer Resolution 0.14 to 0.58mgauss
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless Accelerometer Gyroscope Magneto Temperature Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture. Incorporating a STMicro LSM9DS1 sensor, transmits highly accurate data at user-defined intervals. It samples 3-axis of Accelerometer, Gyroscope, Magnetometer and combines them with temperature sample into a packet at regular intervals while sleeping during the time when it is not measuring or sending data to minimize power consumption. Each sensor is highly configurable over the wireless channel to optimize it according to the application.
The long range, price, accuracy, battery life and security features of Wireless Accelerometer Gyroscope Magneto Temperature Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Wireless Navigation
  • Orientation Applications
  • Home Automation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x05
Reserved80x00
For future use
Accelerometer Data9/ X[0]
Accelerometer X-axis Data (24 bit Signed Output)
     Acceleration (mg) = ((X]0[<<16)+(X[1]<<8)+X[2])/100
(Saving directly to 32bit integer will give wrong result)
10/ X[1]
11/X[2]
12/Y[0]
Accelerometer Y-axis Data (24 bit Signed Output)
     Acceleration (mg) = ((Y]0[<<16)+(Y[1]<<8)+Y[2])/100
13/Y[1]
14/Y[2]
15/Z[0]
Accelerometer Z-axis Data (24 bit Signed Output)
     Acceleration (mg) = ((Z]0[<<16)+(Z[1]<<8)+Z[2])/100
16/Z[1]
17/Z[2]
Magnetometer Data
18/X[2]
Magnetometer X-axis Data (24 bit Signed Output)
     Mag (mgauss) = ((X]0[<<16)+(X[1]<<8)+X[2])/100
19/X[0]
20/X[1]
21/Y[2]
Magnetometer Y-axis Data (24 bit Signed Output)
    Mag (mgauss) = ((Y]0[<<16)+(Y[1]<<8)+Y[2])/100
22/Y[0]
23/Y[1]
24/Z[2]
Magnetometer Z-axis Data (24 bit Signed Output)
    Mag (mgauss) = ((Z]0[<<16)+(Z[1]<<8)+Z[2])/100
25/Z[0]
26/Z[1]
Gyroscope Data27/X[2]
Gyro X-axis Data (24 bit Signed Output)
     rate (mdps) = (X]0[<<16)+(X[1]<<8)+X[2]
28/X[0]
29/X[1]
30/Y[2]
Gyro Y-axis Data (24 bit Signed Output)
     rate (mdps) = (Y]0[<<16)+(Y[1]<<8)+Y[2]
31/Y[0]
32/Y[1]
33/Z[2]
Gyro Z-axis Data (24 bit Signed Output)
     rate (mdps) = (Z]0[<<16)+(Z[1]<<8)+Z[2]
34/Z[0]
35/Z[1]
Temperature Data36/T[0]
Temperature data (16 bit Signed Output)
     Temperature (°C) = (T[0]<<8)+T[1]
37/T[1]
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0005 F7
Command For COPY:  7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0005 0000 0004 F2
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0005 1234 5678 E1
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0005 02F2
Command For COPY:  7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0005 7CDE 99
Command For COPY:  7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0005 03EF
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0005 E3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0005 E2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0005 E1
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0005 E0
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0005 DF
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0005 FC
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0005 FB
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0005 0011 2211 2211 2211 2233 4433 4433 4433 4452
15. Set Acceleration Range
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0100 0005 01F9
16. Set Magnetometer Gain
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0200 0005 02F7
17. Set Gyroscope Scale
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0300 0005 01F7
18. Read Acceleration Range
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0400 0005 F7
19. Read Magnetometer Gain
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0500 0005 F6
20. Read Gyroscope Scale
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0600 0005 F5
B. Appendix
  2. Keep only the last 8 bits
