Long Range IoT Wireless AC Voltage Sensor Manual
  • Industrial Grade Wireless AC Voltage Sensor (RMS output)
  • 24 bit Output
  • Range 0-120V
  • Auto Time Delay based data sample transmission or on voltage change detection (configurable duration in both cases)
  • Configurable Voltage change detection bounds
  • Configurable Voltage Sensor Calibration over the wireless link
  • Two modes of Operation
  • Real time battery status
Introducing NCD’s Long Range IoT Wireless AC Voltage Sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture.  It works together with a split core voltage sensor. It samples voltage at a high data rate and calculates the RMS value. This process is repeated at user defined intervals while sleeping in between to minimize power consumption.
It has an additional feature of detecting change in voltage at user defined detection time intervals and sending out data if the voltage change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change. Both of these features work in parallel to support multiple application areas in one package.
The long range, price, accuracy, battery life and security features of Long Range IoT Wireless AC Voltage sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Industrial AC Voltage Monitoring
  • Voltage Abnormality detection
  • Handheld AC Voltage monitoring equipment
  • Home Automation
  • Wireless AC Voltage Sensor meter (with power source Battery Or External DC)
  • Zigmo/Router for PC (One Router will work with Multiple Sensors)
  • ·         PC/Laptop with an OS installed or Any IoT Embedded Device
  • ·         LabVIEW Utility for displaying sensor data (available on our website for free)
  2. Press the port configure button and select the PORT you identified in step 3. Select baud rate of 9600 and press OK.a
aa
st2
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
MSB 70x11
Reserved80x00
For future use
Current DataMSB 9/ Data[0]–
Voltage (unsigned) – mV
          Voltage (mV) = ((Data[0]<<16)+(Data[1]<<8)+Data[2])/1000
10/ Data[1]–
11/ Data[2]–
Reserved120x00
Figure 13: Run mode packet being received in a terminal along with power up packet along with run mode power up packet (Hex mode)
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0011 0000 0004 E6
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0012 0000 0004 E5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0011 1234 5678 D5
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0011 02E6
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0011 7CDE 8D
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0011 03E3
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0011 D7
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0011 D6
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0011 D5
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0011 D4
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0011 D3
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0011 F0
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0011 EF
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0011 0011 2211 2211 2211 2233 4433 4433 4433 4446
Command For COPY:
7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 0011 0014 0000 0AC7
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 0011 D2
17. Set Calibration
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F4 0100 0011 2710 B7
18. Read Calibration
Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0200 0011 ED
B. Appendix
  2. Keep only the last 8 bits
