Key Fob Relay Control
Key Fob Relay Controllers allow users to control relays from a hand-held remote up to 750 feet away. Each button can activate many different actions such as: turn on relay, turn off relay, toggle relay, and relay flashing.
- Securely Links to 40 Different Key Fob Remotes
- 750 and 1,000 Foot Range Key Fob Remotes are Available
- FCC Approved and Capable of Sending Any ProXR Relay Control Command
- Configure Key Fob Buttons for Relay On or Relay Off Operations
- Key Fob Buttons Support Toggle and Momentary Relay Control Functions
- Program Relays to Activate for a Duration of Time
- Configure Flashers to Flash a Relay On and Off
- Flasher Also Supports Flashing for a Period of Time
- 5, 10, 20 or 30 amp Mechanical Relays Available
- Control one relay at a time or all relays at once
- SPDT, SPST, and Solid State Relay versions available
Our Wireless Relays
Not to be confused with single function low-cost solutions, our Key Fob Reactor Relay Controllers are years ahead! You can now send the same commands to the board as our computer controlled relays with a key fob you hold in your hand! Use a button to activate a Relay, use another button to deactivate a relay. Use another button to toggle a relay. Use another button as a momentary switch. Key Fob Controllers allow you to configure your Key Fob Buttons using the same command set as our computer controlled relays.
Our Remote Control Key Fob Relay boards offer your choice of 5, 10, 20 or 30 amp relays and are available with Solid-State AC or DC relays. Key Fob relay boards operate at 12VDC with a on-board 2.1mm Barrel Connector or directly wire your own 12V power supply to the on-board screw terminals.
More on Key Fob Relays
Key Fob Relay Boards
Key Fob Relay Controllers allow long range remote controlled switching using a hand-held key fob. Key Fob buttons may be easily programmed for relay on/off, toggle, flash, pulse, momentary, and time delay functions. The KFX Key Fob receiver interface uses the Linx technologies RXM-418-LR series key fobs and receivers for full FCC approval. Up to 40 remotes can be securely linked to the Key Fob series relay controllers. Remote control ranges of 750 and 1,000 feet are available. The KFX module may be easily removed from the relay controller and installed into a ZigMo programmer, which allows you to configure the key fob button functions using easy to use Base Station software. We can even configure the key fob for you, just tell us what you need in the Comments section of your order.
Range of Operation
With a tiny Key Fob Remote Control, you can Take Control of your Relays up to 750 Feet of reliable operation away using the standard included antenna. You can pair up to 40 key fobs to a single controller or a single key fob can pair with multiple boards.
Why Choose NCD?
