- Industrial Grade Gas and Temperature Humidity Sensor
- High Resolution TVOC and CO2eq output
- TVOC output range 0 to 60,000 ppb
- CO2eq Output range 400 to 60,000 ppm
- Low long term drift ( 1.3% of measurement value)
- Industrial Grade Sensor with Range 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.04% RH/0.025°C
- Accuracy 2% RH/ 0.3°C
- 256 Sensor Node per Network
- Up to 300,000 Transmissions from 4 AA Batteries
- Improved reliability incorporating Retry feature in case of packet loss
- Real time battery status
- In House Temperature Humidity monitoring
- Hospital Air quality monitoring
- Indoor Gas monitoring
- HVAC application
- Storage Unit Weather Monitoring System
- Warehouse Health Monitoring System
- Home Automation
Introducing NCD’s long-range wireless TVOC and CO2eq Gas Sensor With temperature humidity sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture. Incorporating the SGPS30 and SHT30 temperature humidity sensor, transmits highly accurate TVOC, Co2eq, Raw Ethanol, H2, temperature and humidity samples at user-defined intervals.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 100% RH. Powered by just 4 AA batteries and an operational lifetime of 300,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered.
Output | Range | Resolution |
TVOC | 0 ppb – 2008 ppb | 1 ppb |
2008 ppb – 11110 ppb | 6 ppb | |
11110 ppb – 60000 ppb | 32 ppb | |
CO2eq | 400 ppm – 1479 ppm | 1 ppm |
1479 ppm – 5144 ppm | 3 ppm | |
5144 ppm – 17597 ppm | 9 ppm | |
17597 ppm – 60000 ppm | 31 ppm |
The Minimum data transmission interval for this TVOC and CO2eq Gas Sensor 1 min .
Sensor calibration / initial start up routine
Place the sensor in a cleanest possible area for first 60 seconds
- After the first boot
- After reset
- After changing batteries
- After power cycle
During the first 60 seconds sensor will self calibrate and will use these environment condition as base condition.
With an open communication protocol this IoT wireless TVOC and CO2eq Gas Sensor for Air Quality Monitoring product can be integrated with just about any control system or gateway. Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Long Range Wireless TVOC and CO2eq Gas Sensor for Air Quality Monitoring makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Sensor Type – 31
- IoT Wireless TVOC CO2eq Temperature Humidity Gas Sensor(with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
Packet Counter | 5 | – |
Sensor Type | MSB 6 | 0x00 |
MSB 7 | 0x1F | ||||
Reserved | 8 | error code |
Humidity | MSB 9/ Data[0] | – | Humidity data Humidity(usigned) = ((data[0] x 256) + data[1])/100 | ||
LSB 10/ Data[1] | – | ||||
Temperature | MSB 11/ Data[2] | – | Temperature data Temperature(signed) = (((data[2] x 256) + data[3])/100)°C | ||
LSB 12/ Data[3] | – | ||||
CO2eq in ppm | MSB 13/ Data[4] | – | CO2 eq (signed) = (((data[4] x 256) + data[5])) ppm | ||
LSB 14/ Data[5] | – | ||||
TVOC in ppb | MSB 15/ Data[6] | – | TVOC (signed) = (((data[6] x 256) + data[7])) ppb | ||
LSB 16/ Data[7] | – | ||||
Raw H2 | MSB 17/ Data[8] | – | H2 (signed) = (((data[8] x 256) + data[9])) | ||
LSB 18/ Data[9] | – | ||||
Raw Ethanol | MSB 19/ Data[10] | – | Ethanol (signed) = (((data[10] x 256) + data[11])) | ||
LSB20/ Data[11] | – |
Appendix A
Configuration Commands
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0001 0000 0004 F6
15. Force Sensor Clean
Command For Copy — 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 1A 00 00 00 E4
Appendix B
- Keep only the last 8 bits
WiNet Gateway Quick Start Guide
Jacob Youngblood, , Ethernet, Wireless, Communications, Quick Start Guide, WiNet Compatible, 0
Introduction Anyone Can Use It If you have ever used a web browser to surf the internet or check your Facebook, you will be able to use the WiNet. The WiNet Gateway is a stand-alone web server that allows you to control wireless relays using the web pages inside the WiNet Gateway. The WiNet allows you to control up to 16 wireless relay boards each capable of controlling 512 relays simply from a tab in your browser or smartphone. Combined wi...
IoT Wireless Push Notification Sensor Product Manual
techs, , Labview, Product Manual, Wireless, Product Manual, 0
Features Industrial Grade Sensor with µs latency Sleeps when no push input detected 1-Mile Range with 2.4GHz or 2 Mile Range with 900MHz On-Board Antenna Superior LOS Range of up to 28 miles with 900MHz High-Gain Antennas Interface to Raspberry Pi, Microsoft Azure, Arduino and More Example Software for Visual Studio and LabVIEW Wireless Mesh Networking using DigiMesh® 256 Sensor Node per Network Open Communication Protocol for custom interfacin...
IoT Wireless Activity Detection Sensor Product Manual
Features Industrial Grade Sensor with 3-axis Accelerometer for Activity Detection Configurable Activity Detection Parameters Uses Interrupts for Activity detection with little power consumption Configurable Acceleration Range ±2g to ±16g Configurable Interrupt Threshold ±16mg to ±15.3g Configurable Data Rate 1Hz to 5.37KHz Configurable Interrupt Duration 200us to 1sec Customizable Interrupt Types and Combinations for generating Activity condi...
IoT Wireless Asset Monitor Product Manual
Features Industrial Grade Sensor with 3-axis Accelerometer for Asset Monitoring Configurable Asset Monitoring Parameters Uses Interrupts to keep track of Assets with little power consumption Configurable Acceleration Range ±2g to ±16g Configurable Interrupt Threshold ±16mg to ±15.3g Configurable Data Rate 1Hz to 5.37KHz Configurable Interrupt Duration 200us to 1sec Customizable Interrupt Types and Combinations for generating Monitoring condit...
IoT Wireless Impact Detection Sensor Product Manual
techs, , Labview, Product Manual, Wireless, impact detection, Product Manual, 0
Features Industrial Grade Sensor with 3-axis Accelerometer for Impact Detection Configurable Impact Detection Parameters Uses Interrupts for Impact detection with little power consumption Sends up to 2 extra samples with interrupt sample for acceleration history Configurable Acceleration Range ±2g to ±16g Configurable Interrupt Threshold ±16mg to ±15.3g Configurable Data Rate 1Hz to 5.37KHz Configurable Interrupt Duration 200us to 1sec Config...
Installing LabVIEW USB RS232 RS485 Relay Controller Instrument Driver
techs, , Labview, ProXR & ProXR Lite, LabView, LabView ProXR, LabView ProXR Lite, Tutorial, 0
Installing LabVIEW USB RS232 RS485 Relay Controller Instrument Driver This Guide contains instructions for Installing LabVIEW USB RS232 RS485 Relay Controller Instrument Driver on your development environment. Please go through the following Steps to Install this driver: Download Instrument driver ZIP file from ProXR-labview-driver-v3 Extract this file and Copy ProXR folder. Paste this Folder in the instr.lib folder in your LabVIEW installation f...
Long Range IoT Wireless Sensor FAQ
Jacob Youngblood, , Labview, Product Manual, Wireless, Essential, Wireless Enterprise Line, 0
Wireless Sensor FAQ General Frequently asked questions How do I know if this Wireless sensor is working if there is no power light on it? We didn’t add a power led to save power, you can hit the reset button on the sensor and it will send two data packets. First data packet will indicate that the sensor is in run mode and the second data packet will contain all the sensor info, device info and sensor readings. You can find more about this i...
LabVIEW Relay switching and Status acquisition 2
LabVIEW Relay switching and Status acquisition 2 In this LabVIEW Relay switching article we will learn how read relay status, set relay status and relay grouping. These LabVIEW relay drivers will work with most of the ncd.io industrial relay controllers. which can be found over here Industrial Relay Controller For labview A) Read Relay Status for 8 Relays This guide shows how to read status of all 8 relays in currently selected relay bank. Relate...
