- Industrial Grade Sensor with µs latency
- Sleeps when no push input detected
- 256 Sensor Node per Network
- Two modes of Operation
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Push Notification Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It transmits highly accurate frames with low latency for every push input or at user-defined intervals.
The range, price, accuracy, battery life and security features of Wireless Push Notification Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with IoT Long Range Wireless 24V AC/DC Voltage Detection Sensor, IoT Long range Motion Detection Sensor as well.
M12 Connection
Pin Number Description Cable Wire
1 IO2 Brown
2 3.3V White
3 IO1 Blue
4 COM Black
5 NC Gray
- Push Notification
- Wireless input change detection
- Digital signal monitoring
- Home Automation
- Push Notification Type Iot Wireless Sensor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
| Frame Field | Offset (Payload Section) | Fixed Value (if any) | Description | |
| Header | 0 | 0x7F | Header to differentiate various type of packets | |
| Firmware | 2 | – |
| Battery Voltage | MSB 3 | – | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V | |
| LSB 4 | – | |||
| Packet Counter | 5 | – |
| MSB 7 | 0x02 | |||
| Reserved | 8 | 0x00 |
| Sensors Data | 9/Data[0] | – | Input 1 – High Input: 1, Low Input: 0 | |
| Sensors Data | 10/Data[1] | – | Input 2 – High Input: 1, Low Input: 0 | |
| Reserved | – | – | ||
| 11 | 0x00 | |||
| 12 | 0x00 |
PIR Wireless Motion Detection Sensor
Sensor Type – 46
| Firmware | 2 | – |
| LSB 4 | – | |||
| MSB 7 | 0x2E | |||
| Sensors Data | 9/Data[0] | – | Input 1 – High Input: 1, Low Input: 0 High — Motion was detected Low — No Motion Detected | |
| Sensors Data | 10/Data[1] | – | Reserved | |
| 11 | 0x00 | |||
| 12 | 0x00 |
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0002 FA
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0002 0000 0004 F5
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0002 1234 5678 E4
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0002 02F5
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0002 7CDE 9C
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0002 03F2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0002 E6
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0002 E5
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0002 E4
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0002 E3
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0002 E2
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0002 FF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0002 FE
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0002 0011 2211 2211 2211 2233 4433 4433 4433 4455
15. Set PIR sensitivity Counter
The PIR sensor generates a pulse output when motion is detected. To avoid false monition or too frequent detection the Sensitivity can be increased or decreased.
For example is the sensitivity value is 10. In that it will send a notification when the PIR sensor sends 10 pulses to the MCU.
Example Command —
7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 01 00 00 2E 00 00 00 05 CC
F4 01 00 00 23 00 00 00 05
F4 — Command Header
01 — Sub command
00 — Node ID
00,23 – Sensor Type
00,00 — Reserved
00,05 — Sensitivity Counter value.
B. Appendix
- Keep only the last 8 bits
