- Industrial Grade Sensor with 3-axis Accelerometer for Impact Detection
- Configurable Impact Detection Parameters
- Uses Interrupts for Impact detection with little power consumption
- Sends up to 2 extra samples with interrupt sample for acceleration history
- Configurable Acceleration Range ±2g to ±16g
- Configurable Interrupt Threshold ±16mg to ±15.3g
- Configurable Data Rate 1Hz to 5.37KHz
- Configurable Interrupt Duration 200us to 1sec
- Configurable In-built Interrupt disable time for maximizing battery life time (sends a packet after this interval to show impact detection enabled)
- Two modes of Operation
- Power efficient Built-in Sleep mode- User Configurable Sleep duration
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Impact Detection Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It incorporates a STMicro LIS3DH acceleration sensor for measuring acceleration changes. Utilizing the interrupt feature of this sensor, it is able to minimize power consumption by making most of the components go to sleep while waiting for the interrupt from the sensor.
User can configure the Impact Detection condition (interrupt settings) using the configuration mode. User can configure acceleration range, data rate, interrupt duration and interrupt threshold. Interrupt duration is dependent upon data rate. It is the duration for which an interrupt condition has to hold to generate a system interrupt and initiate data transmission to a nearby receiver. Interrupt threshold is dependent upon acceleration range and it is the acceleration in g which if exceeded causes interrupt to fire. Note that the absolute value of actual g reading is compared with it therefore it works for both positive and negative acceleration exceeding threshold.
Interrupts are fired only when the acceleration (absolute value) read form the sensor exceeds the threshold in the positive direction. All interrupts are combined with an OR gate. This allows impact detection (system interrupt) if an interrupt occurs for any axis (OR condition). User can also configure a delay time in seconds which disables the interrupt for that amount of time after a successful interrupt. This enables the user to make sure that the sensor does not drain its battery (with continuous transmissions) if an interrupt condition persists or a wrong condition is accidently programmed. This time is also used to send a periodic packet to a receiver with latest available data.
The device also sends two extra samples with the sample which caused interrupt. This enables the user to have a history of acceleration data prior and after the interrupt. In normal scenario, it will send 1 sample (n-1) prior to the interrupt sample (n) and 1 sample after the interrupt (n+1). However, if the data rate is too slow, the sensor does not wait for n+1 packet to arrive so as to save battery and instead sends 2 old samples (n-2, n-1) along with the third sample (n) which fired interrupt. It may happen that the duration and sleep delay combination is such that no old sample was saved after the last interrupt and at the time of interrupt the device may contain only 1 sample. In that case it sends 2 old samples from the last transmission along with third sample (n) being the interrupt sample. In case it has 1 old sample (n-1) and 1 interrupt sample (n), it will send the first sample (n-2) from the previously transmitted data.
The range, price, accuracy, battery life and security features of Wireless Impact Detection Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Wireless Impact Detection
- Abnormal Vibration detection
- Security Systems
- Home Automation
- IoT Long Range Wireless Acceleration and Impact Detection Sensor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x07 | ||||
| Reserved | 8 | 0x00 |
| Acceleration Data | 9/X1[0] | – | Accelerometer X-axis Data n-1 (16 bit Signed Output) Acceleration (mg) = X1[0]<<8)+X1[1] | ||
| 10/X1[1] | – | ||||
| 11/X2[0] | – | Accelerometer X-axis Data n (16 bit Signed Output) Acceleration (mg) = X2[0]<<8)+X2[1] | |||
| 12/X2[1] | – | ||||
| 13/X3[0] | – | Accelerometer X-axis Data n+1 (16 bit Signed Output) Acceleration (mg) = X3[0]<<8)+X3[1] | |||
| 14/X3[1] | – | ||||
| 15/Y1[0] | – | Accelerometer Y-axis Data n-1 (16 bit Signed Output) Acceleration (mg) = Y1[0]<<8)+Y1[1] | |||
| 16/Y1[1] | – | ||||
| 17/Y2[0] | – | Accelerometer Y-axis Data n (16 bit Signed Output) Acceleration (mg) = Y2[0]<<8)+Y2[1] | |||
| 18/Y2[1] | – | ||||
| 19/Y3[0] | – | Accelerometer Y-axis Data n+1 (16 bit Signed Output) Acceleration (mg) = Y3[0]<<8)+Y3[1] | |||
| 20/Y3[1] | – | ||||
| 21/Z1[0] | – | Accelerometer Z-axis Data n-1 (16 bit Signed Output) Acceleration (mg) = Z1[0]<<8)+Z1[1] | |||
| 22/Z1[1] | – | ||||
| 23/Z2[0] | – | Accelerometer Z-axis Data n (16 bit Signed Output) Acceleration (mg) = Z2[0]<<8)+Z2[1] | |||
| 24/Z2[1] | – | ||||
| 25/Z3[0] | – | Accelerometer Z-axis Data n+1 (16 bit Signed Output) Acceleration (mg) = Z3[0]<<8)+Z3[1] | |||
| 26/Z3[1] | – | ||||
| Temperature Data | 27/T[0] | – | Temperature data (16 bit Signed Output) Temperature (°C) = (T[0]<<8)+T[1] Note: The temperature output gives the change in temperature between two readings and does not provide temperature of the sensor or environment. | ||
| 28/T[1] | – |
															Command For COPY:
7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0007 F5
															Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0007 0000 0004 F0
															Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0007 1234 5678 DF
															Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0007 02F0
															Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0007 7CDE 97
															Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0007 03ED
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0007 E1
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0007 E0
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0007 DF
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0007 DE
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0007 DD
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0007 FA
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0007 F9
															Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0007 0011 2211 2211 2211 2233 4433 4433 4433 4450
15. Set Acceleration Range
															Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0100 0007 00F8
16. Set Data Rate
															Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0200 0007 07F0
17. Set Threshold
															Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0300 0007 01F5
18. Set Duration
															Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F4 0400 0007 01F4
19. Read Acceleration Range
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0500 0007 F4
20. Read Data Rate
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0600 0007 F3
21. Read Threshold
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0700 0007 F2
22. Read Duration
															Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0800 0007 F1
B. Appendix
- Keep only the last 8 bits
