- Industrial Grade Wireless Current Monitor (RMS output)
- Range 0-100A
- Auto Time Delay based data sample transmission or on current change detection (configurable duration in both cases)
- Configurable Current change detection bounds
- Configurable Current Sensor Calibration over the wireless link
- 256 Sensor Nodes per Network
- Two modes of Operation
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Wireless Current Monitor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It works together with a split core current sensor. It samples current at a high data rate and calculates the current RMS value during that time. This process is repeated at user defined intervals while sleeping in between to minimize power consumption.
It has an additional feature of detecting change in current at user defined detection time intervals and sending out data if the current change is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change. Both of these features work in parallel to support multiple application areas in one package.
The range, price, accuracy, battery life and security features of Long Range IoT Wireless Current Monitor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Industrial Current Monitoring
- Current Abnormality detection
- Handheld Current monitoring equipment
- Home Automation
- IoT Long Range Wireless AC Current Monitor (with power source Battery Or External DC)
- Run Mode
- Configuration Mode
1 Channel Current Monitor
| Frame Field | Offset (Payload Section) | Fixed Value (if any) | Description |
| Header | 0 | 0x7F | Header to differentiate various types of packets |
| Node ID | 1 | 0x00 Factory Default | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| Firmware | 2 | – | Used to determine firmware version programmed in the device |
| Battery Voltage | MSB 3 | – | Sampled batter voltage of the device. Battery Voltage =((Battery Voltage MSB x 256)+Battery Voltage LSB) x 0.00322 V |
| LSB 4 | – | ||
| Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6 | 0x00 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 node for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| MSB 7 | 0x0D | ||
| Reserved | 8 | 0x00 | for future use |
| Sensors Data | MSB 9/ Data[0] | – | Current (unsigned) – mA Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 |
| 10/ Data[1] | – | ||
| 11/ Data[2] | – | ||
| Reserve | – |
2 Channel Current Monitor
| Frame Field | Offset (Payload Section) | Fixed Value (if any) | Description | |
| Header | 0 | 0x7F | Header to differentiate various types of packets | |
| Firmware | 2 | – |
| Battery Voltage | MSB 3 | – | Sampled batter voltage of the device. Battery Voltage =((Battery Voltage MSB x 256)+Battery Voltage LSB) x 0.00322 V | |
| LSB 4 | – | |||
| Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. | |
| LSB 7 | 0x13 | |||
| Sensors Data | MSB 9/ Data[0] | – | Current (unsigned) – mA Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 | |
| 10/ Data[1] | – | |||
| 11/ Data[2] | – | |||
| Reserve | – | |||
| Sensors Data | MSB 13/ Data[0] | – | Current (unsigned) – mA Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 | |
| 14/ Data[1] | – | |||
| 15/ Data[2] | – | |||
| Reserve | – |
3 Channel Current Monitor
| Firmware | 2 | – |
| LSB 4 | – | |||
| LSB 7 | 0x1C | |||
| Reserve | – | |||
| Reserve | – | |||
| Sensors Data | MSB 17/ Data[0] | – | Current (unsigned) – mA Current (mA) = ((Datata[0]<<16)+(Datata[1]<8)+Data[2])/1000 | |
| 18/ Data[1] | – | |||
| 19/ Data[2] | – | |||
| Reserve | – |
Figure 13: Run mode packet being received in a terminal along with power up packet along with run mode power up packet (Hex mode)
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 000D EF
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 000D 0000 0004 EA
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 000D 1234 5678 D9
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 000D 02EA
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 000D 7CDE 91
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 000D 03E7
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 000D DB
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 000D DA
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 000D D9
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 000D D8
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 000D D7
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 000D F4
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 000D F3
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 000D 0011 2211 2211 2211 2233 4433 4433 4433 444A
Command For COPY: 7E00 1810 0000 0000 0000 00FF FFFF FE00 00F7 0700 000D 0014 0000 0ACB
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1A00 000D D6
17. Set Calibration
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F4 0100 000D 2710 BB
18. Read Calibration
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F4 0200 000D F1
B. Appendix
- Keep only the last 8 bits
