IoT Predictive Maintenance Sensor Manual
  • Industrial Grade IoT Wireless Predictive Maintenance Sensor
  • AC Current Range 0-100A RMS Measurement
  • 3-axis Vibration Sensor with RMS, MAX and MIN
  • Calculates g Vibration Data Across ±16g Range with Low Pass Filter
  • Frequency Range (Bandwidth) up to 408 Hz Samples up to 952Hz
  • High Grade K type thermocouple Connector and Probe
  • Ideal Sensor For Machine Health Monitoring
  • Builtin Offset and Gravity vector removal filters
  • Up to 256 Sensor Nodes per Network
  • Multiple Modes of Operation (Configuration and Run mode)
  • Wireless Sensor and Radio Configuration feature
  • Default Factory settings Restore option
  • Power Efficient Built-in Sleep mode
  • Reliable Transmission incorporating packet Retries
  • Secure Transmission using AES-128 Encryption
  • Real time battery status
  • Industrial Current Monitoring
  • Pump, Motor,Generators Electrical Behavior Analysis
  • Future  Fail Detection In Machines
  • Ideal Component for Predicative Maintenance
  • Handheld Current monitoring equipment
  • Key component of predictive maintenance
  • Predictive Maintenance Data To Cloud Like AWS/Azure
Introducing NCD’s Long Range Industrial IoT Wireless Predictive Maintenance Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture.  This IoT Wireless Predictive Maintenance Sensor consist a Vibration Sensors, Thermocouple , AC Split Core Current Sensor and Ambient Temperature Sensor. This IoT Wireless Predictive Maintenance Sensor Samples the vibration, RMS current and temperature data and sends after a fixed user designed interval over the wireless network. The sensor comes with three 1.25 meter long split core current sensors, 1 Meter Long Vibration Probe and 1 Meter Long thermocouple probe which makes installation easy.
3-Axis Vibration Sensor Characteristics —  During Power-Up, this vibration sensor learns “normal” base-line vibration from the monitored device.  This base-line vibration is subtracted from regular sampled vibration readings to improve relevant vibration data.  Ideally, the monitored device should be off while the sensor is learning.  Once the sensor stabilizes and starts sending data, the device/machinery being monitored can be powered on.  This Industrial IoT wireless vibration sensor samples 3-axis of Vibration data for 500ms and then calculates RMS, Maximum, and Minimum vibration readings. This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range.  Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
Thermocouple  Sensor Characteristics — Long Range Industrial IoT Wireless Predictive Maintenance Sensor is capable of measuring extreme high and low temperatures.  This wireless thermocouple includes one 5SRTC-TT-K-24-36 K-Type thermocouple probe from Omega.com with a 1m, 24 AWG connection cable, rated for temperature measurement applications up to 260°C (500°F) with an accuracy of ±2.2°C. This wireless thermocouple device comes with K-Type connector, which can be used to connect higher temperature range thermocouple if needed. This sensor has in built hot and cold junction to provide highly accurate reading.  This wireless IoT thermocouple product is an ideal product for high temperature measurements, industrial boiler temperature measurements, liquid temperature measurement, and temperature monitoring of food storage units.  This Long Range Industrial IoT Wireless Predictive Maintenance Sensor product is designed to consume extremely low power and send data at extremely long distances of up to 2 miles line-of-light or up to 28 miles using high gain antennas.
Powered by just 4 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.
Wireless Vibration Sensor
The Wireless Predictive Maintenance Sensor and Zigmo/Router come pre-programmed and work out of the box. In this section we will setup a sensor and Zigmo link and start receiving data on our PC. Though this guide shows how to visualize data on LabVIEW utility, you can also use a simple serial terminal to see raw data by following these steps.
Note: The Wireless Sensor comes with external power enabled, for battery conservation during shipping. To enable battery power, open the enclosure and set the PS (power select) jumper which is parallel to the marking line on the board.
  2. Connect your Zigmo/Router to your PC. You can also use any other ncd modems and gateways.
Modes of Operation
  • Run Mode
  • Configuration Mode
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2–
Battery VoltageMSB 3–
LSB 4–
Packet Counter5–
Sensor TypeMSB 60x00
LSB 70x32
Reserved80x00
For future use
Vibration RMS 9/X[0]–
Vibration RMS X-axis Data (24 bit Signed Output)
        Vibration (mg) = ((X[0]<<16)+(X[1]<<8)+X[2])/100
(Saving directly to 32 bit integer will give wrong result
 10/X[1]–
 11/X[2]–
 12/Y[0]–
Vibration RMS Y-axis Data (24 bit Signed Output)
        Vibration (mg) = ((Y[0]<<16)+(Y[1]<<8)+Y[2])/100
 13/Y[1]–
 14/Y[2]–
 15/Z[0]–
Vibration RMS Z-axis Data (24 bit Signed Output)
        Vibration (mg) = ((Z[0]<<16)+(Z[1]<<8)+Z[2])/100
 16/Z[1]–
 17/Z[2]–
Vibration Max 18/X[0]–
Vibration Max X-axis Data (24 bit Signed Output)
 19/X[1]–
 20/X[2]–
 21/Y[0]–
Vibration Max Y-axis Data (24 bit Signed Output)
 22/Y[1]–
 23/Y[2]–
 24/Z[0]–
Vibration Max Z-axis Data (24 bit Signed Output)
 25/Z[1]–
 26/Z[2]–
Vibration Min 27/X[0]–
Vibration Min X-axis Data (24 bit Signed Output)
 28/X[1]–
 29/X[2]–
 30/Y[0]–
Vibration Min Y-axis Data (24 bit Signed Output)
 31/Y[1]–
 32/Y[2]–
 33/Z[0]–
Vibration Min Z-axis Data (24 bit Signed Output)
 34/Z[1]–
 35/Z[2]–
 Ambient Temperature data (16 bit Signed Output)
Temperature Data 36/T[0]–
  Temperature (°C) = (T[0]<<8)+T[1]
Temperature
Data 37/T[1]
 Temperature data (32 bit Signed Output)Temperature Data 38/T[0]–
Temperature data
Temperature(signed)
    (data[38]<<24)+(data[39]<<16)+(data[40]<<8)+(data[41])
                                         100
Temperature Data 39/T[1]–
Temperature Data 40/T[2]–
Temperature Data 41/T[3]–
Current data (24 bit Output)Current Data [42]
Current (unsigned) – mA
Current (mA) = ((Datata[42]<<16)+(Datata[43]<8)+Data[44])/1000
Current Data [43]
Current Data [44]
The UI, shown in Figure 16, can be used to configure the wireless sensor. At startup, it automatically changes the Zigmo PANID so that it can communicate with a sensor in configuration mode (indicated by the Led on the top right). Upon exit, the PANID of the Zigmo is restored to old value.
Individual settings can be programmed using the single command column.
The AUTO PROGRAMMING check option allows the user to setup multiple sensors with the same settings. In such a scenario, the user will be required to enable each check box for enabling a setting, enter the value for each setting if required and then check the auto programming check box. Afterwards, when a sensor is powered up and enters configuration mode, the PGM MODE DETECTED Led will flash and automatically program the checked settings. User can also program multiple settings by clicking the APPLY SELECTED button. Moreover, settings can be read using the individual buttons or all settings can be read using the READ ALL button.
Figure 16: Configuration mode User Interface
Appendix A
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0008 F4
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0008 0000 0004 EF
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0008 1234 5678 DE
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0008 02EF
Command For COPY: 7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0008 7CDE 96
Command For COPY: 7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0008 03EC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0008 E0
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0008 DF
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0008 DE
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0008 DD
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0008 DC
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0008 F9
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0008 F8
Command For COPY: 7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0008 0011 2211 2211 2211 2233 4433 4433 4433 444F
Appendix B
  1. Add all the bytes and keep the lower 8 bits of result (Excluding the frame delimiter and length)
  4. Append this byte at the end of the original packet for sending
  1. Add all the bytes including the received checksum (Exclude the frame delimiter and length)
  2. Keep only the last 8 bits
