- Industrial Grade Sensor Mass concentration range 0-1000 μg/m^3
- Mass concentration resolution 1 μg/m^3
- Mass concentration size range PM1.0, PM2.5,PM4.0,PM10.0
- Number concentration range 0 to 3000 1/cm^3
- Number concentration size range PM0.5, PM1.0, PM2.5,PM4.0,PM10.0
- Unique long-term stability upto 8 years
- Laser-based scattering principle and advanced algorithms.
- Inbuilt auto cleaning feature (after every 255 transmissions)
- Industrial Grade Sensor with Range 0 to 100% RH / -25°C [-13°F] to 85°C [185°F])
- Resolution 0.04% RH/0.025°C
- Accuracy 2% RH/ 0.3°C
- 256 Sensor Node per Network
- Up to 500,000 Transmissions from 4 AA Batteries
- Improved reliability incorporating Retry feature in case of packet loss
- Real time battery status
- In House Temperature Humidity monitoring
- Hospital Air quality monitoring
- HVAC application
- Storage Unit Weather Monitoring System
- Warehouse Health Monitoring System
- Home Automation
Introducing NCD’s long-range wireless Particulate Matter Sensor for Air Quality Monitoring With temperature humidity sensor, boasting up to a 28 Mile range using a wireless mesh networking architecture. Incorporating the SPS30 and SHT30 temperature humidity sensor, transmits highly accurate particle size, mass concentration, temperature and humidity samples at user-defined intervals.
PM2.5 and PM10 refer to particulate matter with particle diameter up to 2.5 microns and 10 microns, respectively, and are among the most dangerous air pollutants. Due to their small size, PM2.5 particles can travel deep into the human lung and cause a variety of health issues; for instance, by triggering asthma attacks or contributing to cardiovascular disease. The SPS30 will enable the implementation of innovative air quality monitoring devices that prevent air pollution damage. This sensor is designed to measure PM1.0,PM2.5,PM4.0 and PM 10.0.
Its measurement principle is based on laser scattering technology. This technology, together with high-quality and long-lasting components, enables accurate measurements from the device’s first operation and throughout its lifetime of more than eight years.
The on-board temperature sensor is rated for -25°C to 85°C or -13°F to 185°F and the humidity sensor is rated for 0 to 100% RH. Powered by just 4 AA batteries and an operational lifetime of 300,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered.
With an open communication protocol this IoT wireless Particulate Matter Sensor for Air Quality Monitoring product can be integrated with just about any control system or gateway. Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Long Range Wireless Particulate Matter Sensor for Air Quality Monitoring makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
- Industrial IoT Wireless Particulate Matter Sensor (with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x20 | ||||
| Reserved | 8 | error code |
Mass Concentration PM1.0 [µg/m³] | MSB 9/ Data[0] | – | Mass Concentration PM1.0 [µg/m³] PM1.0(usigned) = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0) | ||
| 10/ Data[1] | – | ||||
| 11/ Data[2] | – | ||||
| LSB 12/ Data[3] | – | ||||
| Mass Concentration PM2.5 [µg/m³] | MSB 13/ Data[4] | – | Mass Concentration PM2.5 [µg/m³] PM2.5(usigned) = (((Data[4]<<24)+(Data[5]<<16)+(Data[6]<<8)+Data[7])/100.0) | ||
| 14/ Data[5] | – | ||||
| 15/ Data[6] | – | ||||
| LSB 16/ Data[7] | – | ||||
| Mass Concentration PM4.0 [µg/m³] | MSB 17/ Data[8] | – | Mass Concentration PM4.0 [µg/m³] PM4.0(usigned) = (((Data[8]<<24)+(Data[9]<<16)+(Data[10]<<8)+Data[11])/100.0) | ||
| 18/ Data[9] | – | ||||
| 19/ Data[10] | – | ||||
| LSB 20/ Data[11] | – | ||||
| Mass Concentration PM10.0 [µg/m³] | MSB 21/ Data[12] | – | Mass Concentration PM10.0 [µg/m³] PM10.0(usigned) = (((Data[12]<<24)+(Data[13]<<16)+(Data[14]<<8)+Data[15])/100.0) | ||
| 22/ Data[13] | – | ||||
| 23/ Data[14] | – | ||||
| LSB 24/ Data[15] | – | ||||
| Number Concentration PM0.5 [#/cm³] | MSB 25/ Data[16] | – | Number Concentration PM0.5 [#/cm³] PM0.5(usigned) = (((Data[16]<<24)+(Data[17]<<16)+(Data[18]<<8)+Data[19])/100.0) | ||
| 26/ Data[17] | – | ||||
| 27/ Data[18] | – | ||||
| LSB 28/ Data[19] | – | ||||
| Number Concentration PM1.0 [#/cm³] | MSB 29/ Data[20] | – | Number Concentration PM1.0 [#/cm³] PM1.0(usigned) = (((Data[20]<<24)+(Data[21]<<16)+(Data[22]<<8)+Data[23])/100.0) | ||
| 30/ Data[21] | – | ||||
| 31/ Data[22] | – | ||||
| LSB 32/ Data[23] | – | ||||
| Number Concentration PM2.5 [#/cm³] | MSB 33/ Data[24] | – | Number Concentration PM2.5 [#/cm³] PM2.5(usigned) = (((Data[24]<<24)+(Data[25]<<16)+(Data[26]<<8)+Data[27])/100.0) | ||
| 34/ Data[25] | – | ||||
| 35/ Data[26] | – | ||||
| LSB 36/ Data[27] | – | ||||
| Number Concentration PM4.0 [#/cm³] | MSB 37/ Data[28] | – | Number Concentration PM4.0 [#/cm³] PM4.0(usigned) = (((Data[28]<<24)+(Data[29]<<16)+(Data[30]<<8)+Data[31])/100.0) | ||
| 38/ Data[29] | – | ||||
| 39/ Data[30] | – | ||||
| LSB 40/ Data[31] | – | ||||
| Number Concentration PM10.0 [#/cm³] | MSB 41/ Data[32] | – | Number Concentration PM10.0 [#/cm³] PM10.0(usigned) = (((Data[32]<<24)+(Data[33]<<16)+(Data[34]<<8)+Data[35])/100.0) | ||
| 42/ Data[33] | – | ||||
| 43/ Data[34] | – | ||||
| LSB 44/ Data[35] | – | ||||
| Typical Particle Size [µm] | MSB 45/ Data[36] | – | Typical Particle Size [µm] (usigned) = (((Data[36]<<24)+(Data[37]<<16)+(Data[38]<<8)+Data[39])/100.0) | ||
| 46/ Data[37] | – | ||||
| 47/ Data[38] | – | ||||
| LSB 48/ Data[39] | – | ||||
| Sensor Data | MSB 49/ Data[40] | – | Humidity data Humidity(usigned) = ((data[0] x 256) + data[1])/100 | ||
| 50/ Data[41] | – | ||||
| 51/ Data[42] | – | Temperature data Temperature(signed) = (((data[2] x 256) + data[3])/100)°C | |||
| LSB 52/ Data[43] | – |
Sensor Type 53 –
Air Quality CO2 Temperature Humidity Particulate Matter Sensor
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| MSB 7 | 0x35 | ||||
| 51/ Data[42] | – | ||||
| LSB 52/ Data[43] | – | ||||
| MSB 53/ Data[44] | – | CO2 Concentration in ppm CO2(usigned) = (((Data[44]>>24)+(Data[45]>>16)+(Data[46]>>8)+Data[47])/100.0) | |||
| 54/ Data[45] | – | ||||
| 55/ Data[46] | – | ||||
| LSB 56/ Data[47 | – |
Appendix A
Configuration Commands
Command For COPY: 7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0001 0000 0004 F6
15. Force Sensor Clean
Command For Copy — 7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 1A 00 00 00 E4
Appendix B
- Keep only the last 8 bits
