IoT Relay Controller Modules For Raspberry Pi
Control Devices in minutes using Raspberry Pi and IoT Relay Controllers
- IoT Relay Module Compatible with Raspberry Pi 2,3
- IoT Relay controller Compatible with raspberry pi zero
- IoT Industrial High Power Relay Raspberry Pi With GPIO Digital I/O
- Daisy Chain Plug and Play connection
- Plug and Play sensor and control expansions
- Also Compatible with:
- Raspberry Pi 1
- Arduino
- Particle
- Many More
Take a look at our products and see why we've
been an industry leader for more than 20 years!
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples. We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform….
About I²C
IoT or Embedded?
IoT Options
- Onion Omega (built on linux, quick cloud connectivity)
Local or Embedded
