Wireless AC Current Monitor up to 600A
Monitor AC current over long range
NCD has a wide range of industrial wireless AC current sensors. These wireless current monitor products can used with Xbee wireless and come in a wide range in terms of number of channels, max current and max accuracy.
- Max Range upto 27Mile
- Works with Windows, Linux
- High Accuracy
- Split Core and Solid Core Current Sensors
- Industrial Grade Clamp Current Transducers
been an industry leader for more than 20 years
Monitoring Current is one of the most critical part of automation and NCD has developed a wide range of wireless AC current sensors. Using the Xbee S3B its possible to read current over a long distance. These wireless current sensors come in a variety of options from 1 to 6 channels. You can also choose the current range according to your requirement from10A up to 600A.  Using NCD wireless AC current sensors its possible to measure current of a pump in a field and keep a data log. These wireless current sensors can be used to keep a data log of current usages, which is used to determine the behavior of a device.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the relay like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
Local or Embedded
