NCD Will be Closed Friday, July 3rd for the Holidays.
USPS Shipping Services, Including Worldwide Express are Experiencing Extended Service Delays.
We Strongly Advise Shipping using UPS for All Urgent Orders or setting up your freight collect options for your account. Dismiss
  • Industrial Grade Tilt Sensor with Roll and Pitch Detection
  • Configurable Roll and Pitch Angle Parameters
  • Uses Interrupts for Tilt detection with little power consumption
  • Measuring range: Roll: ±90°, Pitch: ±90°
  • Angle detection resolution ±0.5° for high precision application
  • 256 Sensor Node per Network
  • Two modes of Operation
    • Up to 300,000 Transmissions from 2 AA Batteries
  • Real time battery status
Introducing NCD’s IoT Wireless Tilt and Inclinometer  Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It incorporates a MEMS acceleromter sensor to calculate roll and Pict angle with extremely high precision and accuracy .
User can configure the Tilt Detection condition using the configuration mode. User can configure roll angle, pitch angle. Note that the absolute value of actual tilt angle is compared with it therefore it works for both positive and negative angle exceeding threshold.
Powered by just 2 AA batteries and an operational lifetime of 300,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval.  Optionally, this sensor may be externally powered.
With an open communication protocol this Tilt and Inclinometer  Sensor sensor can be integrated with just about any control system or gateway.  Data can be transmitted to a PC, a Raspberry Pi, to Microsoft Azure® IoT, or Arduino. Sensor parameters and wireless transmission settings can be changed on the go using the open communication protocol providing maximum configurability depending on the intended application.
The long range, price, accuracy, battery life and security features of Wireless Tilt and Inclinometer  Sensor makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
  • Wireless Activity Detection
  • Security Systems
  • Home Automation
Any ncd modem or gateway can be used with any ncd wireless sensors.
Tilt and Inclinometer Sensor Type is 47.
Wireless Activity Detection Sensor
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:”Table Normal”;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:””;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin-top:0in;
mso-para-margin-right:0in;
mso-para-margin-bottom:8.0pt;
mso-para-margin-left:0in;
line-height:107%;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:”Calibri”,sans-serif;
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:”Times New Roman”;
mso-bidi-theme-font:minor-bidi;}
line-height:107%;
font-size:11.0pt;
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
line-height:107%;
font-size:11.0pt;
  1. Install the Alpha Station utility for the sensor you are working with. Run this utility.
Note:
Sensor Type of this sensor is 0x2F. The figures are for demonstration purposes only and might contain a different Sensor type or a different UI version than the latest version available for download.
The packet received from this Sensor will have its own sensor type in the Sensor type field.
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:”Table Normal”; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:””; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:8.0pt; mso-para-margin-left:0in; line-height:107%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:”Calibri”,sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:”Times New Roman”; mso-bidi-theme-font:minor-bidi;}
  • Run Mode
  • Configuration Mode
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
3. The detail for API packet received at PC end can be read from the X-bee manual available from Digi. The detail of Payload section of packet is shown in Table 3.
(if any)
Header00x7F
Node ID10x00 Factory Default
Firmware2
Battery VoltageMSB 3
LSB 4
Packet Counter5
Sensor TypeMSB 60x00
MSB 70x18
Reserved80x00
For future use
Tilt Angle Data9/Data[0]
Roll in Degree (16 bit Signed Output)
          Roll = (Data[0]<<8)+Data[1])/100
10/Data[1]
11/Data[0]
Pitch In Degree (16 bit Signed Output)
          Pitch = (Data[0]<<8)+Data[1]/100)
12/Data[1]
Wireless Tilt Sensor User Interface
Figure 14: Run mode packets being received in our free to use Alpha Station Software (For custom made utility for your specific requirements please contact support)
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
line-height:107%;
font-size:11.0pt;
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
line-height:107%;
font-size:11.0pt;
line-height:107%;
font-size:11.0pt;
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 0100 0018 E4
line-height:107%;
font-size:11.0pt;
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0200 0018 0000 0004 DF
line-height:107%;
font-size:11.0pt;
Command For COPY:
7E00 1710 0000 0000 0000 00FF FFFF FE00 00F7 0300 0018 1234 5678 CE
line-height:107%;
font-size:11.0pt;
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0400 0018 02DF
line-height:107%;
font-size:11.0pt;
Command For COPY:
7E00 1510 0000 0000 0000 00FF FFFF FE00 00F7 0500 0018 7CDE 86
line-height:107%;
font-size:11.0pt;
Command For COPY:
7E00 1410 0000 0000 0000 00FF FFFF FE00 00F7 0600 0018 03DC
line-height:107%;
font-size:11.0pt;
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1500 0018 D0
line-height:107%;
font-size:11.0pt;
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1600 0018 CF
line-height:107%;
font-size:11.0pt;
Command For COPY: 7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1700 0018 CE
line-height:107%;
font-size:11.0pt;
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1800 0018 CD
line-height:107%;
font-size:11.0pt;
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F7 1900 0018 CC
line-height:107%;
font-size:11.0pt;
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0100 0018 E9
line-height:107%;
font-size:11.0pt;
Command For COPY:  7E00 1310 0000 0000 0000 00FF FFFF FE00 00F2 0200 0018 E8
Command For COPY:
7E00 2410 0000 0000 0000 00FF FFFF FE00 00F2 0300 0018 0011 2211 2211 2211 2233 4433 4433 4433 443F
Wireless Tilt Sensor User Interface - Configuration Mode
Configuration Mode packets being received in our free to use Alpha Station Software (For custom made utility for your specific requirements please contact support)
14. Set Roll Angle Threshold
This command can be used to set roll angle threshold.  For example if this value is set to 1 then the sensor will sends wireless transmission contains all sensor info every time sensor roll tilts by 1′.
The set Roll angle value should be between 1′ and 90′.
7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 01 00 00 2F 00 01 CF
Command — F4 01 00 00 2F 00 01
F4 — Command Header
01 — Sub command
00 — Node ID
00 2F — Sensor Type
00 — Reserve
01 — Roll Angle Threshold Value
Sensor Response —
7E 00 1C 90 00 13 A2 00 41 A2 70 EA FF FE C1 7C 00 08 00 2F 00 00 FF 00 00 00 00 00 00 00 00 0D
Sensor response Payload — 7C 00 08 00 2F 00 00 FF 00 00 00 00 00 00 00 00
7C — Header
00 — Node ID
08 — Packet Counter
00 2F — Sensor Type
00 00 — Reserve
FF — Command was successfully executed
00 00 00 00 00 00 00 00 — Reserve
15. Read Roll Angle Threshold
This command can be used to read the set roll angle threshold.
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 02 00 00 2F CF
Command — F4 02 00 00 2F
F4 — Command Header
02 — Sub command
00 — Node ID
00 2F — Sensor Type
Sensor Response —
7E 00 1C 90 00 13 A2 00 41 A2 70 EA FF FE C1 7C 00 07 00 2F 00 00 00 01 00 00 00 00 00 00 00 0C
Sensor response Payload — 7C 00 07 00 2F 00 00 00 01 00 00 00 00 00 00 00
7C — Header
00 — Node ID
07 — Packet Counter
00 2F — Sensor Type
00 00 00  — Reserve
01 — Roll Threshold Angle
16. Set Pitch Angle Threshold
This command can be used to set pitch angle threshold.  For example if this value is set to 1 then the sensor will sends wireless transmission contains all sensor info every time sensor pitch tilts by 1′.
The set Pitch angle value should be between 1′ and 90′.
7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 03 00 00 2F 00 01 CD
F4 — Command Header
03 — Sub command
00 — Node ID
00 2F — Sensor Type
00 — Reserve
Sensor Response —
7C — Header
00 — Node ID
08 — Packet Counter
00 2F — Sensor Type
00 00 — Reserve
17. Read Pitch Angle Threshold
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 04 00 00 2F CD
Command — F4 04 00 00 2F
F4 — Command Header
04 — Sub command
00 — Node ID
00 2F — Sensor Type
Sensor Response —
7C — Header
00 — Node ID
07 — Packet Counter
00 2F — Sensor Type
00 00 00  — Reserve
01 — Pitch Threshold Angle
B. Appendix
line-height:107%;
font-size:11.0pt;
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
line-height:107%;
font-size:11.0pt;
  2. Keep only the last 8 bits
ncd.io
Made in the USA
5 Year Warranty
Log in with your credentials
or
Forgot your details?
Create Account
