- Industrial Grade 1 Channel 16 bit ADC 4-20mA Reveiver
- 15 bit 4-20mA Resolution
- ±0.68uA Absolute Accuracy
- Auto ADC sample transmission or on analog voltage change detection periodically (configurable duration in both cases)
- Configurable Analog voltage change detection percentage
- Up to 500,000 Transmissions from 4 AA Batteries
- Real time battery status
- Description
- Getting Started
- Modes of Operation
Introducing NCD’s IoT Industrial IoT Wireless High Resolution 4-20mA Receiver, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It incorporates a 1 channel 16 bit ADC that samples analog inputs at user defined intervals while sleeping during the time it is not sending data to minimize power consumption. It has an additional feature of detecting change in voltage at user defined detection time intervals and sending out ADC samples if the change in voltage on any channel is greater than user defined detection change percentage. This change detection feature can be enabled or disabled by user. To minimize power consumption, it sleeps during the time it is not checking for change in analog voltage. Both of these features work in parallel to support multiple application areas in one package.
Powered by just 4 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered.
The range, price, accuracy, battery life and security features of IoT Wireless Analog to Digital Converter makes it an affordable choice which exceeds the requirements for most of the industrial as well as consumer market applications.
Note: This manual is shared with Industrial IoT Wireless DC Voltage Monitor(0-10V), and IoT Long Range Wireless 0-24VDC Voltage Monitor as well.
Sensor Type == 45
- Industrial Sensor monitoring
- Analog Input To Digital Converter
- PLC and Automation Application
- Industrial Automation
- ADC type NCD IoT Wireless Sensor (with power source Battery Or External DC)
- Install the Alpha Station utility for the sensor you are working with. Run this utility.
- Run Mode
- Configuration Mode
Sensor Type 45 and 48
Wireless 1 Channel 4-20mA Receiver
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
Packet Counter | 5 | – |
Sensor Type | MSB 6 | 0x00 |
MSB 7 | 0x2D | ||||
Reserved | 8 | 0x00 |
Sensor Data | 9/ Data[0] | – | ADC 1 Counts ( Signed 16 bit int) ADC Counts = (Data[0] x 256) + Data[1] | ||
10/ Data[1] | – | ||||
11/ Data[0] | – | For Future Use | |||
12/ Data[1] | – |
Sensor Type 52
Wireless 2 Channel 4-20mA Receiver
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
MSB 7 | 0x34 | ||||
11/ Data[0] | – | ADC 2 Counts ( Signed 16 bit int) ADC Counts = (Data[0] x 256) + Data[1] | |||
12/ Data[1] | – |
Sensor Type 56
Wireless 2 Channel 0-10VDC Receiver
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
MSB 7 | 0x38 | ||||
12/ Data[1] | – |
Sensor Type 75 and 76
Custom Wireless 1 Channel 4-20mA Receiver
The detail for API packet received at PC end can be read from the X-bee manual available from Digi. The detail of the Payload section of the packet is shown in Table 3.
The typical response from the device in Run mode is shown in Figure 13 and Figure 14. The utility shown in Figure 14 can be downloaded from the website.
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
MSB 7 | 0x4B | ||||
11/ Data[2] | – | mA( Signed 16 bit int) = ((Data[2] x 256) + Data[3])/100
Velocity ( UnSigned 16 bit int) = ((Data[4] x 256) + Data[5])/100 | |||
12/ Data[3] | |||||
13/ Data[4] | |||||
14/ Data[5] | – |
ncd.io 4-20mA Labview UI can be used to configure the Sensor. While using this UI select 45 as sensor type on left side.
