Humidity Sensors
Sensors Made Simple
Our plug and play humidity sensor design allows you to connect any sensor with any platform. Arduino, Raspberry Pi, Onion and more with no soldering required. We have a full line of humidity sensors to fit your application’s needs. Our chainable design allows you to easily add additional monitoring and control hardware in seconds.
- Plug and Play I²C Communications
- Cross Platform Ready
- Chainable Sensor and Control Options
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
![](https://media.ncd.io/20180305162454/Humidity-Sensor.png)
Our I²C Humidity Sensors
We have a full line of humidity sensor options able to cover almost any application. We have humidity sensors with temperature and humidity sensors with barometric pressure. When it comes to sensors, we’ve got what you need.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform using the adapter. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the sensor like it was built into your platform.
About I²C
IoT or Embedded?
IoT Options
- Onion Omega (built on linux, quick cloud connectivity)
- Raspberry Pi (powerful platform, clouds: blink, IFTTT)
Local or Embedded
