USPS Shipping Services, Including Worldwide Express are Experiencing Extended Service Delays.
We Strongly Advise Shipping using UPS for All Urgent Orders or setting up your freight collect options for your account. Dismiss
Use N-Button software to create A/D Meters as well as relays.
Here will show you how to use N-Button Lite software to create A/D Meter widget for NCD Analog to Digital Conversion controllers.
1. Connect a NCD A/D Analog to Digital board to your computer with USB or Ethernet interface.
2. Download, install, and launch N-Button Lite software, N-Button Lite Manager will be shown on your screen.
3. Click  Device Manager – New to add a device.
  • Input the name for the device: A/D Board
  • Select Manufacturer: National Control Devices
  • Select Device Type: AD1216
  • Select connection interface of the device
  • Click OK on Device Setting and Devices Manager, you will see 1 Device is added on N-Button Lite Manager.
4. Click A/D Meter button to show Properties – A/D Meter panel.
  • Input the name or keep the default
  • Select the Device: A/D Board
  • Select A/D ID
  • Input Caption or keep the default
  • Keep default Appearance or select  your favorite Style, Location, and Size
  • Click OK back to N-Button Lite Manager, A/D Meter is added to Widget panel
5. In the same way, click A/D Meter to add more A/D Meter widgets for different A/D inputs.
6. Click OK on N-Button Lite Manager, you will see the A/D Meter widgets showing on your desktop.  Right-click the A/D Meter widget to show the pop-up menu. You can choose to open Properties panel or N-Button Lite Manger panel to edit the widget.
All kinds of sensors, such as temperature, electric current, voltage, humidity, velocity, pressure, etc., can be connected to A/D inputs. By adding A/D Meter widgets, you will read the value of A/D inputs directly on your desktop.
The default value of A/D input is 0-255. The meter can map the value to different range, like 0-5, 0-12, or other value you want. You can choose to let the A/D Meter widgets updated the value at specific interval automatically or manually by clicking the refresh button beside the A/D Meter widget.
You can create up to 16 A/D Meter widgets with N-Button Lite software.
If you need more widgets, please use N-Button Pro version, which supports up to 255 widgets.
ncd.io
Made in the USA
5 Year Warranty
Log in with your credentials
or
Forgot your details?
Create Account
