Energy Monitors
Sensors Made Simple
Our plug and play Energy Monitor design allows you to connect any sensor with any platform. Arduino, Raspberry Pi, Onion and more with no soldering required. We have a full line of Energy Monitors to fit your application’s needs. Our chainable design allows you to easily add additional monitoring and control hardware in seconds.
- Plug and Play I²C Communications
- Cross Platform Ready
- Chainable Sensor and Control Options
- Compatible with:
- Raspberry Pi
- Arduino
- Particle
- Many More
Our I²C Energy Monitors
We have a full line of Energy Monitor options able to cover almost any application. We have AC Current Sensors, DC Current Sensors, and Voltage Sensors. We have low power Energy Monitors and high power Energy Monitors and everything in between. Some of them are onboard sensors for a more condensed layout and some have off board for more flexible wiring. When it comes to sensors, we’ve got what you need.
Why Choose NCD?
How It Works
Our idea is simple. Pick a platform. Get an adapter for that platform (usually less than $2). Connect any of our boards to that platform using the adapter. That’s it. Hardware…done. All that’s left is some code to work for your specific application. To help with that we have an ever expanding bag of libraries and code samples.
We don’t add our own proprietary APIs to make things more complicated. You can just communicate to the sensor like it was built into your platform.
About I²C
I²C is a high speed communication bus popular in electronic monitoring and control applications. As it pertains to our devices you only need to worry about sending and receiving data. Each platform/language has its own library for communicating over I²C that will greatly simplify you application. Once you have that library imported you can start reading and writing data in a few minutes using our libraries and code samples as a basis.
IoT or Embedded?
IoT Options
- Raspberry Pi (powerful platform, clouds: blink, IFTTT)
Local or Embedded
