Custom IoT Electronic Design Services
Whether its custom firmware, circuit board modifications, metal enclosures, or industrial color printing, we can help you custom tailor our products to fit your exact needs.
What We Offer
NCD offers many custom IoT electronic design services to help tailor our product to your exact needs. Whether you are looking for custom firmware, circuit board modifications, metal enclosures, or industrial color printing, we can help you with a wide variety of design services.
Design Services Process
Most of our users purchase off-the-shelf hardware for initial testing. Once everything is working, they contact us to build a custom solution which may include specialized changes to the board, firmware, connectors, etc. Custom boards have many advantages such as reduced wiring, easy installation, small size, less power consumption, and in some cases, an overall reduction in product cost. Custom IoT Electronic Design Services will have your company name and logo on the board as well as the enclosure.
Customized IoT Electronics
NCD engineers can help build a customized solution for your particular application based on the designs you see on our website. We can combine devices onto a single board, change the shape, or even some of the components to meet your exact needs. We also provide turn-key metal enclosures with powder coating and full-color printing on the top side starting at just $500 for setup! We have more than 20 years of experience in electronics design and manufacturing. All of our products are designed and manufactured in the USA, so we are here to support the products we make. We only ask that our customers prototype their needs using our existing products before we customize.
Customization Guidelines
- Custom designs should be based on an existing product.
- We do not provide customization services if it involves the introduction of a new or untested technology.
- Custom engineering fees depend on your requirements, so please contact us for a quote!
- We maintain ownership of all designs, including our customized designs as they are based on our existing Design.
- We will only ship the customized product to you or your authorized agents.
- We have an NDA available if needed.
- The turn-around time is about 2-3 weeks.
- We specialize in low-volume designs, no quantity is too small!
- We have the ability to scale to large volumes as needed.
- Custom projects are Non Cancel-able, Non Returnable and Non Refundable
- Custom projects MOQ is 25 units
Getting Started with Product Customization
Contact us and we will walk you through the process from beginning to end, based on your individual needs.
Here are the general services we provide when we customize:
- We design the circuit board.
- We communicate with our customers throughout the customization and manufacturing process.
- We manufacture surface mount stencils and circuit boards.
- We program our pick and place machines to build your boards.
- We build a working sample.
- We test your custom IoT solution.
- Once it meets all your requirements, we will start production as needed.
- We work with our metal fabricators to design a metal enclosure if required.
- We will custom mill plastic enclosures if required.
- We will custom laser cut plastic components if required.
- You work with our graphics department to print the enclosure in full color with your company logo if desired.
*Once the design is finalized it won’t be possible to make changes during production (changes cost money and require us to repeat the above processes)
Our clients are surprised at how fast we finish CAD design (usually a few hours), but keep in mind, we still have to build your design, which takes considerably more time. A typical product customization requires the resources of our entire staff to complete.
