Contact Closure Push Notification Series
We offer more wireless protocol options than any other relay manufacturer! Our Industrial Relays offer a swappable communication interface. Simply select the relay controller you need and choose the desired wireless interface for it.
- Sends Push Notification on Sensor Change
- Compatible with any Contact Closure Sensor
- Compatible with WiFi Interface
- Compatible with TCP or UDP Protocols
- Read and React to Push Notifications from Server Software
- Send Push Notifications to a Specific Server or All Devices over a Local Network
- Compatible with USB and Serial Interfaces
- Read and React to Push Notifications from Connected Computer
- Reliable High Speed Sensor Monitoring
- Compatible with N-Button Software for Easy Automation
- Eight User-Defined Bytes in Data Transmission
Our Push Notification Boards
Flip a switch and send a SMS Text Message. Push a Button and Send an email. Trip a sensor and send a message to a server or computer to do just about anything you want. Log when sensors change state or control relays when switches are triggered.
Introducing our Push Notification series controllers, the easiest way to send alerts to servers and computers when a switch changes state. The Push Notification series make it easy for your application to know when a door is opened, a switch is flipped, or motion is detected… from anywhere in the world!
How It Works
Our Push Notification products send a byte stream out when the status of their inputs change. They can be configured to send this packet when the input is open/closed, opened, or closed.
Push notification series contact closure input detectors do not directly generate Emails or SMS text messages. Optional N-Button software or custom-developed server software is required for this functionality. The Push Notification Quick Start Guide will help you setup your Push Notification Controller for your particular application. You will need a computer to accept the packets and react to them to do what you need.
You can send these data packets over a USB, Serial Port, TCP or UDP Socket over WiFi. The TCP or UDP Socket options can work over a Local Area Network or over the Internet depending on the configuration.
Communication Options
WiFi Contact Closure Push Notification
The Push Notification Series with WiFi will let you choose between broadcasting the sensor data over the internet to a specific server or to all devices on a Local Area Network. Push Notification series devices operate over the internet or on a closed LAN connection. Multiple Push Notification controllers can report data from all over the world to a centralized server for data monitoring, logging, and evaluation. Both Local and Internet options give you access to send emails, text messages, and activate relays using N-Button or custom software.
USB Contact Closure Push Notification
USB Push Notification boards don’t require any configuration. Simply plug them in and start receiving notifications.
Push Notification series with USB send a message to the connected computer when inputs turn on or off. Push Notification series controllers are small and may be conveniently installed where you need them most. Supply any form of dry contact sensor and you will be notifying any computer of important real-world activity.
Serial Contact Closure Push Notification
Serial Push Notification boards don’t require any configuration. Simply plug them in and start receiving notifications.
Equipped with 1, 2, 4, or 8 Contact-Closure Inputs, Push Notification series with a Serial Interface sends a message to the connected computer when inputs turn on or off. Push Notification series controllers are small and may be conveniently installed where you need them most. Supply any form of dry contact sensor and you will be notifying any computer of important real-world activity.
