Cellular Micro Gateway Setup for MQTT
Shipping Delays due to Covid: PLEASE CLICK HERE. Dismiss
Mirror Pro Guide
TravisE NCD Technical Engineer, , Uncategorized, 0
Device Types Status LED Flashing Green(GOOD) Flashing Red(BAD) Global Settings Destination Address Buzzer Model Global Device Attributes Device Type S3B Address Point to Point Contact Closure One Way Overview Contact closure input transmitter board settings Mode(Transmitter) Transmit Interval Input Count Contact closure output receiver board settings Mode(Receiver) Timeout Output Count Transmitter Mode Return Status Point to Point Contact Closure...
How to Activate Verizon IoT Sim Card
Bhaskar, , Uncategorized, 0
How to Activate Verizon IoT SIM card NCD’s IoT Edge Computer supports various SIM cards from multiple companies. So far, we have tested the IoT Edge Computer with Verizon and Hologram SIM cards. Use this guide to set up your Verizon SIM card. 1. Go To ThingSpace ThingSpace is the Verizon IoT center. This is where you can purchase SIM cards, activate them, and find any other information related to Verizon SIM cards. Go to ThingSpace. Y...
Send IoT Sensor Data to Kosmos by Temboo!
Ryan, , Uncategorized, 0
Send IoT Sensor Data to Kosmos by Temboo! Temboo is an official partner of National Control Devices, and we have thoroughly reviewed their support and integration of our sensors into their cloud platform. Kosmos was designed with a built-in integration with NCD’s sensors which means that you can quickly set up and deploy applications in minutes – no coding required. It’s the easiest way to implement Industrial IoT applications at any scal...
WiFi Micro Gateway Setup for Microsoft Azure
Jacob Youngblood, , Product Manual, Quick Start Guide, Uncategorized, Wireless, Essential, 0
WiFi Micro Gateway for Microsoft® Azure® Setup Instructions Introduction The NCD WiFi Micro Gateway allows the complete line of NCD sensors to communicate over the internet to Microsoft Azure using a WiFi connection. The NCD Micro Gateway is very easy to use, as it only requires network connection credentials and an Azure Connection String. All sensors are fully encrypted using 128-bit AES encryption. WiFi communications is also fully enc...
NexGen WiFi Module User Guide
Introduction In this guide we will discuss the functionality and use of the NexGen modules. The NexGen module implements all the same functionality from our previously supplied WiFi Bluetooth and USB modules but adds additional functionality including a simple web interface for configuration, Bluetooth interface, USB interface, we built in web interface for rudimentary control of select relay products, and MQTT compatibility. We will now cove...
NCD Wireless Sensor Configuration Commands
Sending Configuration Commands – Overview Enter Configuration Mode Read Sleep Duration Set Sensor Node ID and Sleep Duration Read Sensor Network ID Set Wireless Sensor Network ID Read Sensor Destination Address Set Sensor Destination Address Set Sensor Destination to Broadcast Read Wireless Sensor Transmission Power Level Set Wireless Sensor Transmission Power Level Read Wireless Sensor Retries Set Wireless Sensor number of Retries Set Wire...
What is nodeLynk? The nodeLynk I2C Communications Standard
What is nodeLynk I²C Communication? https://media.ncd.io/20190612110234/NodeLynk-Vid-3.mp4 nodeLynk I²C is a physical I²C communications bus standard developed by National Control Devices in 2014. nodeLynk devices use I²C communications to communicate between an I²C Master device and a chain of I²C Node devices. nodeLynk I²C is a physical standard that does not alter the I²C communications protocol in any way. If you are already fa...
IoT Sensors vs IoT endNodes – What’s the Difference?
IoT Sensors vs. IoT endNodes As we continue to grow our pallet of IoT connected hardware, choosing the appropriate solution for your application might need a little context. You may find that we manufacture IoT endNodes and IoT Sensors that do the exact same thing, which could lead to some confusion. NCD engineers follow a rather large set of development guidelines for product classification and function. IoT endNodes and sensors seek to foll...
