Wireless Vibration, Ultrasound and Temperature Sensor Datasheet
Explore the Wireless Vibration, Ultrasound and Temperature Sensor Capabilities
Introducing NCD’s Wireless Vibration, Ultrasound and Temperature Sensor. Engineered for industrial predictive maintenance. They track 3-axis acceleration, vibration severity (RMS/Peak), temperature, and RPM. By capturing data up to 25.6kHz, they help detect mechanical faults (e.g., bearing wear, imbalance) before unexpected machine failures occur it also integrated ultrasound capabilities to capture high-frequency acoustic emissions.
This addition is critical because ultrasound detects the earliest stages of friction, lubrication starvation, and potential leaks long before detectable vibrations or temperature spikes occur. By combining both technologies, the sensor provides comprehensive visibility across the entire equipment degradation curve, allowing your team to identify and resolve anomalies weeks or months earlier than relying on vibration analysis alone.
Features:
  • It Helps to Detect: Misalignment, Looseness, Imbalance, Bearing wear, Gearbox wear, Lubrication.
  • Senses Vibration, Ultrasound and Temperature.
  • Analyzes On-Device: FFT, Time-Domain Data, Overall, RPM, Uptime.
  • Always-Listening Mode: Stays on to capture machines that cycle on and off.
  • Small & lightweight for ease of installation.
  • IP67 rated sealed enclosure for dust &
    moisture protection.
  • D-cell battery for long-lasting operation.
  • A versatile user-configurable sample rate for slow or fast-running machines.
  • In-Built Machine Learning optimizes power consumption.
  • Asset On-Time Calculator automatically tracks operational status.
  • Hardware Accelerator enhances vibration sampling accuracy.
  • Configurable Sample Rate – 100Hz to 25.6KHz
  • Available Wireless Transmission Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
  • Supports MESH networking via DigiMesh
  • Fully open Node-RED library for configuration and data ingestion
  • No Monthly Cost.
  • Total Data Owner Ship.
Figure 1: Device Overview
LED blinks once – Message was sent successfully and no error in last sensor read as well in data transmission.
LED blinks twice and then one more time – Message was sent successfully but there was an error in last sensor read.
LED blinks thrice – MCU is having issue communicating with the radio module.
Height85mm
Base diameter48mm
Weight225g
Enclosure RatingIP67
Mounting ¼-28 UNF thread
Magnetic mount
Temperature Rating-40° C23° C70° CComponent Rating
Tested Temperature0° C23° C40° CAs Tested by NCD Staff
Temperature Sensor Accuracy±1°C
Accelerometer Sampling Rate25.6 kHzVibration Sensor Data Rate
Accelerometer Full-Scale Range-16g+16g
Accelerometer Noise70 μg/ √Hz
Ultrasound Full Scale Range30dBuV120dBuV120dBuV
Ultrasound Sample rate83KHz
Support Ultrasound Time Domain data Max Sample16384
Sample Duration1sec1sec10secDevice will take readings for the set time and then send over wireless.
Max numbers 8100.
ParameterMinimumNominalMaximumNotes
Trace Width0.007 inch0.012 inch0.25 inchTrace Width depends on the Trace Type
Layer Count2L - RigidTop and Bottom Layer
Material TypeFR-4 TG170FR-4 TG170FR-4 TG180
Surface FinishENIG 2u"
IPC StandardIPC CLASS 2
Finished Copper Foil1.0/1.0 OZ
Finished Thickness0.062 inc
Fine line <4.0/4.0milNo
Blind & Burried ViasNo
Non-Conductive ResinNo
Conductive ResinNo
Alignment Indicator
Alignment Indicator Gen4
RF Module Specifications
Parameter868MHz900MHz2.4GHz
Frequency Band863 MHz to 870 MHz902 to 928 MHzISM 2.4 GHz
Transmitter PowerUp to 13 dBm ERPUp to 24 dBmUp to 8 dBm
Receiver Sensitivity-106 dBm at 80 Kbps-101 dBm at 200 Kbps-103 dBm at 250 Kbps
Range (dense urban)~1000ft~1000ft~300ft
Range (line of sight)~2 miles~2 miles~1 mile
Data Rate80 Kbps200 Kbps250 Kbps
Networking ProtocolDigi XBee® DigiMesh®Digi XBee® DigiMesh®Digi XBee® DigiMesh®
Encryption128-bit AES128-bit AES128-bit
Reliable Packet DeliveryRetries/acknowledgementsRetries/acknowledgementsRetries/acknowledgements
IDsPAN ID and addresses, cluster IDs and endpoints (optional)PAN ID and addresses, cluster IDs and endpoints (optional)PAN ID and addresses, cluster IDs and endpoints (optional)
CertificationCE/RED, ROHS CompliantFCC (America), IC (Canada), C-Tick (Australia), Anatel (Brazil), IDA (Singapore)FCC (America), IC (Canada), RCM (Australia), Anatel (Brazil), Teleck MIC (Japan), KCC (South Korea)
This device is Powered by a single D-cell (LR20) battery
While changing the batteries:
  1. Turn off the sensor
  2. Only use a new D-cell battery (obtain one from NCD, as it has a built in supercapacitor, this is not a regular battery).
  3. Make sure to align the connector in the proper orientation (this will assure you match the polarity)
  4. The battery should not be replaced in fire-risky areas
  5. Do NOT install a rechargeable battery
Batteries size16000mAhThis device has a single D-Cell (LR20) battery
Battery Life 1 TPD10 YearsTPD Transmissions per Day
Battery Life 12 TPD8 YearsTPD Transmissions per Day
Battery Life 24 TPD5 YearTPD Transmissions per Day
Battery Life 96 TPD3 YearTPD Transmissions per Day
