- NCD's Long Range Industrial IoT Wireless Soil Moisture Temperature EC Sensor
- Description
- Getting Started
- Modes of Operation
- 3 Channel SDI Soil Moisture temperature EC Sensor — Type 77
- Appendix A
- 15. Sensor Soil Moisture Calibration
- 16. Sensor Soil Temperature Calibration
- 17. Sensor Soil EC Calibration
- 19. Super Command
- Wireless Soil Moisture Temperature EC Sensor for Indoor Outdoor Use
- Industrial Grade 1 Channel IoT Soil Moisture Temperature EC Sensor
- Temperature Range-30 ~ 70 ° C;0 ~ 100%( VWC)
- EC Range 0~20000μs/cm
- Probe Does Not Corrode Over Time and Insensitive to Salinity
- Measures Volumetric Water Content (VWC)
- * USB Modem is recommended for Calibration and Sensor Setup
- Environmental Science
- Green House
- Agriculture
- Indoor Grow House
Introducing NCD’s Long Range IoT Wireless Soil Moisture Temperature EC Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. This long range IoT wireless Soil Moisture Temperature EC sensor incorporates a stainless steel Soil probe that samples Soil Moisture Temperature EC level at user defined intervals and sends a wireless transmission to remote gateways and modems. After sampling, this device goes to sleep to minimize power consumption and prolong battery life. To minimize power consumption, it sleeps during the time it is not checking for change in soil moisture level. Both of these features work together, supporting multiple application areas in one package.
This wireless Soil Moisture Temperature EC sensor makes it possible to monitor soil moisture in multiple locations either outdoors or in greenhouses to monitor soil saturation conditions. The soil moisture measurement range is 0-100% and the EC measurement range is 0-20000us/cm. The included probe is 10cm and the included cable is 3 Meters in length.
Powered by just 4 AA batteries and an operational lifetime of 500,000 wireless transmissions, a 10 years battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered.
Note : EC Should be calibrated for different type of Soils.
- Industrial IoT Long Range Wireless pH and Temperature Sensor (with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
Sensor Type == 69
Wireless 1 Channel Soil Temp Moisture and EC Sensor
| Byte | Function | Value | Description | |
| 1 | Header | 0 | 7F | Header to differentiate various type of packets |
| 2 | Node ID | 1 | 0x00 Factory Default | Node ID to differentiate up to 256 nodes in a network. User configurable values |
| 3 | Firmware | 2 | – | Used to determine firmware version programmed in the device |
| 4 | Battery Voltage MSB | |||
| 5 | Battery Voltage LSB | MSB 3, LSB 4 | – | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V Use this equation to calculate battery %. Battery % = 0.537*ADC – 449.9 |
| 6 | Packet Counter | 5 | – | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| 7 | ||||
| 8 | Sensor Type | MSB 6, LSB 7 | 0x45 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| 9 | Reserved | 8 | – | For future use |
| 14 | Sensor Data/ Soil Moisture | 9/Data[0], 10/Data[1],11/Data[2], 12/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00 |
| 15 | Sensor Data/ Soil Temperature | 13/Data[4], 14/Data[5],15/Data[6], 16/Data[7] | – | Soil Temperature in C Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00 |
| 16 | Sensor Data/ Soil EC | 17/Data[8], 18/Data[9],19/Data[10], 20/Data[11] | – | Soil Electrical Conductivity Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00 |
| 17 | Sensor Data/ Soil Salinity | 21/Data[12], 22/Data[13],23/Data[14], 24/Data[15] | – | Soil Salinity Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00 |
Sensor Type == 71
Wireless 3 Channel Soil Temp Moisture and EC Sensor
| 7 | ||||
| 8 | Sensor Type | MSB 6, LSB 7 | 0x47 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| 18 | Sensor Data/ Soil Moisture 2 | 25/Data[0], 26/Data[1],27/Data[2], 28/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00 |
| 19 | Sensor Data/ Soil Temperature | 29/Data[4], 30/Data[5],31/Data[6], 32/Data[7] | – | Soil Temperature in C Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00 |
| 20 | Sensor Data/ Soil EC | 31/Data[8], 32/Data[9],33/Data[10], 34/Data[11] | – | Soil Electrical Conductivity Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00 |
| 21 | Sensor Data/ Soil Salinity | 35/Data[12], 36/Data[13],37/Data[14], 38/Data[15] | – | Soil Salinity Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00 |
| 22 | Sensor Data/ Soil Moisture 3 | 39/Data[0], 40/Data[1],41/Data[2], 42/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[0]<<24+Data[1]<<16+Data[2]<<8+ Data[3])/100.00 |
| 23 | Sensor Data/ Soil Temperature | 43/Data[4], 44/Data[5],45/Data[6], 46/Data[7] | – | Soil Temperature in C Soil Temp = ( Data[4]<<24+Data[5]<<16+Data[6]<<8+ Data[7])/100.00 |
| 24 | Sensor Data/ Soil EC | 47/Data[8], 48/Data[9],49/Data[10], 50/Data[11] | – | Soil Electrical Conductivity Soil EC = ( Data[8]<<24+Data[9]<<16+Data[10]<<8+ Data[11])/100.00 |
| 25 | Sensor Data/ Soil Salinity | 51/Data[12], 52/Data[13],53/Data[14], 54/Data[15] | – | Soil Salinity Soil SAL = ( Data[12]<<24+Data[13]<<16+Data[14]<<8+ Data[15])/100.00 |
Sensor Type == 72
Wireless 1 SDI Channel Soil Temp Moisture and EC Sensor
The detail for the API packet received at the PC end can be read from the X-bee manual available from Digi. The detail of the Payload section of the packet is shown in Table 3.
| 7 | ||||
| 8 | Sensor Type | MSB 6, LSB 7 | 0x48 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| 10 | Sensor Data/ Soil Temperature | 9/Data[0], 10/Data[1] | – | Soil Temperature in C Soil Temp = ( Data[0]<<8+Data[1]/100.00 |
| 12 | Sensor Data/ Soil Moisture | 11/Data[2], 12/Data[3] | – | Soil Moisture % Soil Moisture = ( Data[2]<<8+Data[3]/100.00 |
| 14 | Sensor Data/ Soil Bulk EC | 13/Data[4], 14/Data[5] | – | Soil Bulk EC uS/cm Soil Bulk EC = ( Data[0]<<8+Data[1] |
| 16 | Sensor Data/ Soil Pore EC | 15/Data[6], 16/Data[7] | – | Soil Pore EC uS/cm Soil Pore EC = ( Data[0]<<8+Data[1] |
| 18 | Sensor Data/ Soil Permittivity | 17/Data[2], 18/Data[3] | – | Soil Permittivity (1-100) Permittivity = ( Data[0]<<8+Data[1]/100.00 |
Sensor Type == 77
Wireless 3 SDI Channel Soil Temp Moisture and EC Sensor
| 7 | ||||
| 18 | Sensor Data/ Soil Permittivity | 17/Data[8], 18/Data[9] | – | Soil Permittivity (1-100) Permittivity = ( Data[0]<<8+Data[1]/100.00 |
| 20 | Sensor Data/ Soil Temperature | 19/Data[10], 20/Data[11] | – | Soil Temperature in C Soil Temp = ( Data[0]<<8+Data[1]/100.00 |
| 22 | Sensor Data/ Soil Moisture | 21/Data[12], 22/Data[13] | – | Soil Moisture % Soil Moisture = ( Data[2]<<8+Data[3]/100.00 |
| 24 | Sensor Data/ Soil Bulk EC | 23/Data[14], 24/Data[15] | – | Soil Bulk EC uS/cm Soil Bulk EC = ( Data[0]<<8+Data[1] |
| 26 | Sensor Data/ Soil Pore EC | 25/Data[16], 26/Data[17] | – | Soil Pore EC uS/cm Soil Pore EC = ( Data[0]<<8+Data[1] |
| 28 | Sensor Data/ Soil Permittivity | 27/Data[18], 28/Data[19] | – | Soil Permittivity (1-100) Permittivity = ( Data[0]<<8+Data[1]/100.00 |
| 30 | Sensor Data/ Soil Temperature | 29/Data[20], 30/Data[21] | – | Soil Temperature in C Soil Temp = ( Data[0]<<8+Data[1]/100.00 |
| 32 | Sensor Data/ Soil Moisture | 31/Data[22], 32/Data[23] | – | Soil Moisture % Soil Moisture = ( Data[2]<<8+Data[3]/100.00 |
| 34 | Sensor Data/ Soil Bulk EC | 33/Data[24], 34/Data[25] | – | Soil Bulk EC uS/cm Soil Bulk EC = ( Data[0]<<8+Data[1] |
| 36 | Sensor Data/ Soil Pore EC | 35/Data[26], 36/Data[27] | – | Soil Pore EC uS/cm Soil Pore EC = ( Data[0]<<8+Data[1] |
| 38 | Sensor Data/ Soil Permittivity | 37/Data[28], 38/Data[29] | – | Soil Permittivity (1-100) Permittivity = ( Data[0]<<8+Data[1]/100.00 |
Appendix A
Configuration Commands
Set Multiplication Factor
7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4F 00 00 45 01 00 00 00 FA 71
Command — F4 4F 00 00 45 01 00 00 00 FA
0xF4 — Header
0x4F — Sub command
00 — Node ID
00,45 — Sensor type
01 — Sub parameter
00,00,00,0xFA — Set Multiplication factor to 2.5
Get Multiplication Factor
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 50 00 00 45 01 6A
Set Off Set Factor
7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 51 00 00 45 01 00 00 02 8A DD
Command — F4 51 00 00 45 01 00 00 02 8A
0xF4 — Header
0x51 — Sub command
00 — Node ID
00,50 — Sensor type
01 — Sub parameter
00,00,02,8A — Set offset value to 6.5
Get Offset Factor
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 52 00 00 45 01 68
Soil Moisture calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- Install the sensor and meter to same height
- Read Soil Moisture using sensor and Meter
- Note down these readings and take one more reading at a different soil moisture level
- using these 4 data points calculate the slope ( multiplication) and constant ( offset) of a linear equation
- Store these new offset and multiplication factor values in the sensor
7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4F 00 00 45 02 00 00 00 FA 70
Command — F4 4F 00 00 45 02 00 00 00 FA
0xF4 — Header
0x4F — Sub command
00 — Node ID
00,45 — Sensor type
02 — Sub parameter
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 50 00 00 45 02 69
Set Off Set Factor
7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 51 00 00 45 02 00 00 02 8A DA
Command — F4 51 00 00 45 02 00 00 02 8A
0xF4 — Header
0x51 — Sub command
00 — Node ID
00,50 — Sensor type
02 — Sub parameter
Get Offset Factor
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 52 00 00 45 02 66
Soil temperature calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- Read Soil temperature using sensor and Meter
- Note down these readings and take one more reading at a different temperature level
7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4F 00 00 45 03 00 00 00 FA 6F
0xF4 — Header
0x4F — Sub command
00 — Node ID
00,45 — Sensor type
03 — Sub parameter
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 50 00 00 45 03 68
Set Off Set Factor
7E 00 18 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 51 00 00 45 03 00 00 02 8A CF
Command — F4 51 00 00 45 03 00 00 02 8A
0xF4 — Header
0x51 — Sub command
00 — Node ID
00,50 — Sensor type
03 — Sub parameter
Get Offset Factor
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 52 00 00 45 03 65
Soil EC calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- Read Soil EC using sensor and Meter
19. Super Command
The super command can be used to configure some sensor parameters during run mode.
In order to set parameters like Delay, node id and other sensor related parameters the super command needs to be be enabled in the cfg mode.
Super command enable counter —
By sending this command users can set a counter after which sensor will stay awake for 2 sec and wait for a command from the user. if it does not get command withing 2 sec it will go back to sleep.
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 30 00 00 00 03 CA
In above command we are setting the super command enable counter to 3. After every 3 data transmission the sensor will stay awake for 2 sec and wait for any cfg command from the user.
Read super command counter Value
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 31 00 00 00 00 CC
Appendix B
- Keep only the last 8 bits
