- NCD's Long Range Industrial IoT Wireless pH ORP Temperature Sensor
- Description
- Getting Started
- Modes of Operation
- Appendix A
- 15. Sensor pH Calibration
- 16. Set pH Probe Warm up time
- 17. Set Temperature
- 17. Enable Disable Temperature Compensation
- 18. On Demand Data
- 19. Super Command
- 20. Sensor ORP Calibration
- Industrial Grade Wireless pH, ORP, and Temperature Sensor
- pH Measurement Accuracy ±2%pH and ±2°C temperature
- ORP Measurement Accuracy ±2%ORP and ±2°C temperature
- 3/4 inch NPT connector housing
- pH range: 0-14 pH
- ORP range: -1500mV to +1500mV
- 2 mile Line-of-Sight range with On-Board Antenna
- Superior LOS range of up to 28 miles with High-Gain Antennas
- Interface to Raspberry Pi, Microsoft®, Azure®, Arduino and More
- Operating temperature rated for 15°C to 60°C
- Can withstand a max pressure of 100 PSI
- Liquid pH
- Liquid ORP
- Temperature
- Green House
- Agriculture
- Water Quality
- Industry Standard Measurement
Introducing NCD’s Industrial IoT Long Range Wireless pH, ORP (Oxidation-reduction potential), and Temperature Sensor, boasting up to a 2 mile range using a wireless mesh networking architecture. It incorporates a high resolution pH probe and ORP probe, allowing the user to sample both liquid pH and ORP at customizable intervals. The results are then transmitted to remote modems and gateways.
These Industrial IoT Wireless pH and ORP probes each contain a built in temperature sensor. The transmitter will send beacons of high-accuracy (±2% pH, ±2% ORP, and ±2°C temperature) data at user-defined intervals. The pH and ORP probes come with a 5 meter long cable and has a 3/4 inch NPT housing. The probe is rated for 15°C to 60°C with max pressure of 100 PSI and can be left in a solution to give real time, changing data. The probe can stay submerged in the liquid during its entire life span.
This Industrial IoT Wireless pH ORP Temperature Sensor does require periodic calibration. The calibration period depends on the usage. If the probe is used in either an extreme acidic or base environment, it will require monthly calibration. The calibration process can be done in house and calibration steps can be found in the product manual.
This sensor is powered by just 6 AA batteries and has an operational lifetime of 300,000 wireless transmissions. 10 years of battery life can be expected depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered and has capabilities of supporting 6-32 VDC external power supply.
The long range, accuracy, precision, low price, battery life and security features of the Industrial IoT Long Range Wireless pH ORP Temperature Sensor makes it an affordable choice which exceeds the requirements for most of the industry as well as consumer market applications. This sensor can be applied to many fields of work when testing water quality in a variety of environments.
- Industrial IoT Long Range Wireless pH and Temperature Sensor (with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
Sensor Type == 61
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x3D | ||||
| Reserved | 8 | error code |
pH | MSB 9/ Data[0] | – | pH Data pH(signed) = (((Data[0]>>8)+Data[1])/100.0) | ||
| LSB 10/ Data[1] | – | ||||
| Temperature | MSB 11/ Data[2] | – | Temperature data Temperature(signed) = (((data[2] x 256) + data[3])/100)°C | ||
| LSB 12/ Data[3] | – |
Sensor Type == 62
Wireless ORP and Temperature Sensor
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| MSB 7 | 0x3E | ||||
ORP | MSB 9/ Data[0] | – | ORP Data in mV ORP(signed) = (((Data[0]>>8)+Data[1])) | ||
Sensor Type == 63
Wireless ORP,pH and Temperature Sensor
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| MSB 7 | 0x3F | ||||
ORP and pH | MSB 9/ Data[0] | – | ORP Data in mV ORP(signed) = (((Data[0]>>8)+Data[1])) pH Data pH(signed) = (((Data[0]>>8)+Data[1])/100.0) | ||
| MSB 11/ Data[2] | |||||
| LSB 12/ Data[3] | |||||
| Temperature | MSB 13/ Data[4] | – | Temperature data Temperature(signed) = (((data[2] x 256) + data[3])/100)°C | ||
| LSB 14/ Data[5] | – |
Appendix A
Configuration Commands
pH7 Calibration Command
7E 00 18 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 43 00 00 00 07 1B 58 09 C4 75
Command — F4 43 00 00 00 07 1B 58 09 C4
0xF4 — Header
0x43 — Sub command
00 — Node ID
00,00 — Sensor type
07 — pH 7 mid point calibration
1B,58 — pH value of the calibration Liquid*1000
09 C4 — Temperature of the calibration Liquid * 100
pH4 Calibration Command
7E 00 18 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 43 00 00 00 04 0F A0 09 C4 3C
pH10 Calibration Command
7E 00 18 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 43 00 00 00 0A 27 10 09 C4 AE
pH calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- The probe should be calibrated for the pH7 firs and then pH4 and pH10.
- Put the sensor in configure mode
- Put the pH probe in pH7 liquid and steer it
- Wait for a minute
- Send the pH7 calibration command
- Once the calibration is done sensor will send a response. This could take upto 30sec
- Take the probe out of the pH7 liquid and use water to clean it. We recommend steering in the water. Do not use cloth or paper towel to clean the probe.
- Repeat step 5,6,7 for pH4 and 10
Command For COPY: 7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 45 00 00 00 00 32 88
Above command is setting the Sensor warm up time to 50 sec.
pH electrodes has a settling time. This time can change from probe to probe. Generally this time is around 30 sec – 1 min.
17. Set Temperature
Command For COPY: 7E 00 16 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 41 00 00 00 00 17 70 37
Above command is setting the Temperature to 60’C.
Some pH probes come with in built temperature sensor but it might not be the most accurate and reliable. In such cases users can set the temperature and the pH sensor will use this temp value to compensate pH values.
0xF4 — Header
0x41 — Sub command
00 — Node ID
00,00 — Sensor type
17 70 — Temperature of the Liquid * 100
Read stored Temperature value –
7E 00 13 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 42 00 00 3D 80
Enable Command For COPY: 7E 00 14 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 46 00 00 00 01 B8
Disable Command For COPY: 7E 00 14 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 47 00 00 00 00 B8
The above commands can be used enable disable the Temperature Compensation
18. On Demand Data
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 32 00 00 00 01 CA
The Above command can be used to enable the on demand mode.
In on demand mode the devices stays power on all the time and waits for a command from the user. Once it gets the data request command from the user the sensor will compute the sensor values and responds with data.
This will drain the battery and only recommended when the device is powered up ll the time.
The on demand data request command-
Command For COPY: 7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 34 00 00 00 00 00 C9
On demand Disable –
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 32 00 00 00 00 CB
Command For COPY: Once sensor receives this command it will disable the on demand mode and go back to interval transmission mode.
19. Super Command
The super command can be used to configure some sensor parameters during run mode.
In order to set parameters like Delay, node id and other sensor related parameters the super command needs to be be enabled in the cfg mode.
Super command enable counter —
By sending this command users can set a counter after which sensor will stay awake for 2 sec and wait for a command from the user. if it does not get command withing 2 sec it will go back to sleep.
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 30 00 00 00 03 CA
In above command we are setting the super command enable counter to 3. After every 3 data transmission the sensor will stay awake for 2 sec and wait for any cfg command from the user.
Read super command counter Value
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 31 00 00 00 00 CC
ORP Calibration Command
7E 00 15 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 44 00 00 00 00 E1 DA
Command — F4 44 00 00 00 00 E1
0xF4 — Header
0x43 — Sub command
00 — Node ID
00,00 — Sensor type
00,E1 –ORP calue of calibration Liquid in mV
ORP calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- Put the ORP probe in ORP 225mV liquid and steer it
- Wait for a minute
- Send the ORP calibration command
Appendix B
- Keep only the last 8 bits
