NCD's Long Range Industrial IoT Wireless PAR Sensor
- Photosynthetically Active Radiation Sensor
- PAR Sensor Measurement Resolution 1 μmol/m²·s
- PAR Sensor Measurement Accuracy ±5%FS
- Measurement Range 0-2000 um/m^*s
- Spectral Range 400-700nm
- Aluminum alloy housing
- Cosine correction: up to 80° incident angle
- * USB Modem is recommended for Calibration and Sensor Setup
- Environmental Science
- Green House
- Agriculture
- Indoor Grow House
Introducing NCD’s Industrial IoT Long Range Wireless Photosynthetically Active Radiation Sensor, boasting up to a 2 mile range using a secure wireless mesh networking architecture. It incorporates a high-resolution PAR Sensor that samples light Photosynthetic Photon Flux Density at user-defined intervals and transmits the result to remote modems and gateways.
The detection wavelength of the PAR sensor is 400-700nm. This transmitter will send beacons of high-accuracy (±5%FS) data at user-defined intervals with outstanding precision. The PAR sensor comes with a 5 meter long cable and has a mounting plate.
This Industrial IoT Long Range Wireless Photosynthetically Active Radiation Sensor does support user calibration. The calibration period depends on the usage of the equipment. The measurement range of this Photosynthetically Active Radiation Sensor is 0-2000uMol/m^2*s.
This Industrial IoT Long Range Wireless PAR Sensor is powered by just 4 AA batteries and has an operational lifetime of 300,000 wireless transmissions. 10 years of battery life can be expected, depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered, as it supports a 6-32 VDC external power supply.
- Industrial IoT Long Range Wireless pH and Temperature Sensor (with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
Sensor Type == 67
Wireless PAR Sensor
| Header | 0 | 0x7F |
| Firmware | 2 | – |
| LSB 4 | – | ||||
| Packet Counter | 5 | – |
| MSB 7 | 0x43 | ||||
| Reserved | 8 | error code |
DO | MSB 9/ Data[0] | – | PAR Value in umol/m2s PAR = (((Data[0]<<24)+(Data[1]<<16)+(Data[2]<<8)+Data[3])/100.0) | ||
| 10/Data[1] | – | ||||
| 11/Data[2] | – | ||||
| LSB 12/ Data[3] | |||||
| MSB 13/ Data[4] |
Appendix A
Configuration Commands
15. Sensor PAR Calibration
Set Multiplication Factor
7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4F 00 00 43 00 00 00 FA 74
Command — F4 4F 00 00 43 00 00 00 FA
0xF4 — Header
0x4F — Sub command
00 — Node ID
00,43 — Sensor type
00,00,00,0xFA — Set Multiplication factor to 2.5
Get Multiplication Factor
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 50 00 00 43 6D
Set Off Set Factor
7E 00 17 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 51 00 00 43 00 00 02 8A E0
Command — F4 51 00 00 43 00 00 02 8A
0xF4 — Header
0x51 — Sub command
00 — Node ID
00,03 — Sensor type
00,00,02,8A — Set offset value to 6.5
Get Offset Factor
7E 00 13 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F4 52 00 00 43 6B
PAR calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- Install the sensor and meter to same height
- Read PAR using sensor and Meter
- Note down these readings and take one more reading at a different light level
- using these 4 data points calculate the slope ( multiplication) and constant ( offset) of a linear equation
- Store these new offset and multiplication factor values in the sensor
16. Super Command
The super command can be used to configure some sensor parameters during run mode.
In order to set parameters like Delay, node id and other sensor related parameters the super command needs to be be enabled in the cfg mode.
Super command enable counter —
By sending this command users can set a counter after which sensor will stay awake for 2 sec and wait for a command from the user. if it does not get command withing 2 sec it will go back to sleep.
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 30 00 00 00 03 CA
In above command we are setting the super command enable counter to 3. After every 3 data transmission the sensor will stay awake for 2 sec and wait for any cfg command from the user.
Read super command counter Value
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 31 00 00 00 00 CC
Appendix B
- Keep only the last 8 bits
