NCD's Long Range Industrial IoT Wireless EC Temperature Sensor
- Industrial Grade Wireless EC and Temperature Sensor
- EC Measurement Accuracy ±2%FS and ±2°C temperature
- 3/4 inch NPT connector housing
- Stainless steel housing with Platinum Electrode
- EC Range 10-2000uS/cm
- Cell Constant K = 1 ( other ranges available as well)
- 2 mile Line-of-Sight range with On-Board Antenna
- Superior LOS range of up to 28 miles with High-Gain Antennas
- Interface to Raspberry Pi, Microsoft®, Azure®, Arduino and More
- Operating temperature rated for 15°C to 60°C
- Can withstand a max pressure of 100 PSI
- Liquid pH
- Liquid ORP
- Temperature
- Green House
- Agriculture
- Water Quality
- Industry Standard Measurement
Introducing NCD’s Industrial IoT Long Range Wireless Electrical Conductivity EC and Temperature Sensor, boasting up to a 2 mile range using a secure wireless mesh networking architecture. It incorporates a high resolution EC probe that samples liquid Electrical Conductivity at user defined intervals and transmits the result to remote modems and gateways.
The EC probe for this sensor contains a built-in temperature sensor that will give temperature readings along with the EC data. This transmitter will send beacons of high-accuracy (±2%EC and ±2°C temperature) data at user-defined intervals with outstanding precision. The EC probe comes with a 5 meter long cable and has a 3/4 inch NPT housing. The probe is rated for 15°C to 60°C and can withstand a max pressure of 100 PSI.
This Industrial IoT Long Range Wireless EC and Temperature Sensor does require periodic calibration. The calibration period depends on the usage of the equipment. The calibration process can be done in house and the calibration steps can be found in the product manual. The probe can stay submerged in the liquid during its entire life span.
This Industrial IoT Long Range Wireless EC and Temperature Sensor is powered by just 6 AA batteries and has an operational lifetime of 300,000 wireless transmissions. 10 years of battery life can be expected, depending on environmental conditions and the data transmission interval. Optionally, this sensor may be externally powered, as it supports a 6-32 VDC external power supply.
The long range, accuracy, precision, low price, battery life and security features of the Long Range Industrial IoT Wireless EC and Temperature Sensor makes it an affordable choice which exceeds the requirements for most of the industry as well as consumer market applications. This sensor can be applied to many fields of work when testing water quality in a variety of environments.
NOTE: The minimum data transmission interval is 2 minutes.
- Industrial IoT Long Range Wireless pH and Temperature Sensor (with power source Battery Or External DC)
- Alpha Station PC utility
Modes of Operation
- Run Mode
- Configuration Mode
Sensor Type == 64
Header | 0 | 0x7F |
Firmware | 2 | – |
LSB 4 | – | ||||
Packet Counter | 5 | – |
Sensor Type | MSB 6 | 0x00 |
MSB 7 | 0x40 | ||||
Reserved | 8 | error code |
pH | MSB 9/ Data[0] | – | EC Data EC(signed) = (((Data[0]>>8)+Data[1])/100.0) | ||
LSB 10/ Data[1] | – | ||||
Temperature | MSB 11/ Data[2] | – | Temperature data Temperature(signed) = (((data[2] x 256) + data[3])/100)°C | ||
LSB 12/ Data[3] | – |
Appendix A
Configuration Commands
15. Sensor EC Calibration
EC Dry Calibration Command
7E 00 13 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4B 00 00 00 B4
Command — F4 4B 00 00 00
0xF4 — Header
0x4B — Sub command
00 — Node ID
00,00 — Sensor type
Low Point Calibration Command
7E 00 17 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4D 00 00 00 00 00 39 6C 0D
Command — F4 4D 00 00 00 00 00 39 6C
0xF4 — Header
0x4D — Sub command
00 — Node ID
00,00 — Sensor type
00,00,39,6C — low point calib value * 100
Hi Point Calibration Command
7E 00 17 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4E 00 00 00 00 02 27 F4 94
Command — F4 4E 00 00 00 00 00 39 6C
0xF4 — Header
0x4E — Sub command
00 — Node ID
00,00 — Sensor type
00,02,27,F4 — high point calib value * 100
Clear All calibration points
7E 00 13 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 52 00 00 00 AD
EC calibration is an extremely important step. If calibration is not done properly it can lead to incorrect results.
Calibration steps —
- The probe should be calibrated for the dry first and then low and high points.
- Put the sensor in configure mode
- Put the EC probe in dry environment
- Wait for a minute
- Send the dry calibration command
- Once the calibration is done sensor will send a response. This could take upto 30sec
- Next submerge the probe in low EC liquid and calibrate for low point. We recommend steering in the solution. Do not use cloth or paper towel to clean the probe.
- Repeat step 7 for high point calib
16. Set Probe K Value
Command For COPY: 7E 00 17 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 49 00 00 00 00 00 00 64 52
Above command is setting the K value to 1.
If the probe K value is 10, then send 10*100 = 00 00 03 EB
0xF4 — Header
0x49 — Sub command
00 — Node ID
00,00 — Sensor type
00 00 00 64 — K value * 100
Read stored K value –
7E 00 13 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4A 00 00 00 B5
17. Set Temperature Compensation Source
Set temp source to probe Thermistor Command For COPY: 7E 00 14 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 53 00 00 00 01 AB
Set temp source to probe User defined value Command For COPY: 7E 00 14 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 53 00 00 00 00 AC
Set Temperature — 7E 00 17 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 F4 4F 00 00 00 00 00 09 C4 E3
18. On Demand Data
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 32 00 00 00 01 CA
The Above command can be used to enable the on demand mode.
In on demand mode the devices stays power on all the time and waits for a command from the user. Once it gets the data request command from the user the sensor will compute the sensor values and responds with data.
This will drain the battery and only recommended when the device is powered up ll the time.
The on demand data request command-
Command For COPY: 7E 00 15 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 34 00 00 00 00 00 C9
On demand Disable –
7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 32 00 00 00 00 CB
Command For COPY: Once sensor receives this command it will disable the on demand mode and go back to interval transmission mode.
19. Super Command
The super command can be used to configure some sensor parameters during run mode.
In order to set parameters like Delay, node id and other sensor related parameters the super command needs to be be enabled in the cfg mode.
Super command enable counter —
By sending this command users can set a counter after which sensor will stay awake for 2 sec and wait for a command from the user. if it does not get command withing 2 sec it will go back to sleep.
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 30 00 00 00 03 CA
In above command we are setting the super command enable counter to 3. After every 3 data transmission the sensor will stay awake for 2 sec and wait for any cfg command from the user.
Read super command counter Value
Command For COPY: 7E 00 14 10 00 00 00 00 00 00 00 FF FF FF FE 00 00 F7 31 00 00 00 00 CC
Appendix B
- Keep only the last 8 bits
