- Device Overview
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Device Nodes
- ncd-gateway-config Nodes
- Examples
Introducing NCD’s Industrial Grade Bidirectional Differential Pressure Sensor, boasting up to a 28 Mile range using a 900MHz wireless mesh networking architecture or 1 Mile using 2.4GHz wireless mesh networking architecture. It processes temperature and pressure data and transmits this information wirelessly. This whole process is repeated at user defined intervals with low power sleep mode activated in between.
Powered by just 6 AA batteries this sensor can last up to 10 years, especially if you utilize the sleep feature efficiently. It can be integrated into any end-user system utilizing the open NCD Node-RED libraries. No vendor lock, you own your data and you can configure the device and process your data at the edge or on a cloud server.
The range, price, accuracy, battery life and security features of Industrial Wireless Differential Pressure Sensor makes it an affordable choice which exceeds the requirements for most of the Industrial as well as consumer market applications.
- Industrial Grade Bidirectional Differential Pressure Sensor with Temperature output
- A selection of probes with different pressure range and sensitivity:
- AMS5812-0150-D-B Amplified Pressure Sensor -1034 to +1034 mbar -15 to +15 PSI
- AMS5812-0050-D-B Amplified Pressure Sensor -344.7 to +344.7 mbar -5 to +5 PSI
- AMS5812-0001-D-B Amplified Ultra Low Pressure Sensor -10.34 to +10.34 mbar -0.150 to +0.150 PSI
- AMS5812-0003-D-B Amplified Low Pressure Sensor -20.68 to +20.68 mbar -0.30 to +0.30 PSII
- Operating Temperature Range -25 to +85 °C
- Temperature resolution 0.01°C
- Default Factory setting Restore option
- Real time battery status
Hardware Controls
Power Switch
- Battery Power
- Off
- External Power
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Ready State
Configuring State
Failed to Connect State
Connecting State
No incoming or outgoing data will be handled while in this state.Â
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 21,
"sensor_data": {
"pressure": 10,
"temperature": 25,
"sensor_name": "Differential Bidirectional Pressure Sensor",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
- pressure
- The measured differential pressure in PSI
- temperature
- The measured temperature in Celsius
Wireless Gateway RUN Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 21,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 21,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 21,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 21,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 21,
"nodeId": 0,
"mode": "FLY",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
- For More information on the submenu this icon bring up see section ncd-gateway-config Nodes​
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
- topic
- Â Indicates the type of message this is
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 21,
"sensor_data": {
"pressure": 10,
"temperature":25,
"original": {...},
"payload": {
"pressure": 10,
"temperature":25,
"_msgid": "48e99332fc104565"
- pressure
- temperature
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
- Name
- Arbitrary name of this node
- Serial Device*
- For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID and Delay
- Node ID
- Delay
- Node ID
- Power
- Retries
Sensor Specific Configurations​
Set Pressure Sensor Type (code)
This lets you select the specific pressure sensor type to use, where you have the following options:
D: differential/Relative
D-B: Bidirectional Differential
A: Absolute
B: Absolute (barometric)
Default Configuration​
| Network ID | 7F FF (HEX) |
| Node ID | 0 |
| Delay | 600 (DEC) seconds |
| Power | +24 dBm |
| Retries | 10 |
Serial Connection
- Name
- Modem Type
- Serial Port
- Baud Rate
- Network ID
- The default value is 7FFF
TCP Socket Connection
- Name
- Modem Type
- TCP Port
- IP Address
- Network ID
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
- See section Hardware Mode Selection for more information
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 21 – Differential Bidirectional Pressure Sensor
- Click on Import
Example Flows
