Wireless Activity Detection Gen4 User Manual
Explore The Wireless Activity Detection Gen4
Introducing NCD’s Gen4 Industrial Wireless Activity Detector. Utilizing a wireless mesh networking architecture, this device offers an impressive wireless range of up to 2 miles. It incorporates a high-accuracy acceleration sensor that measures changes in acceleration to reliably detect mechanical movement (activity).
Upon detecting activity, the device immediately transmits a message to a remote gateway or modem, then returns to a sleep state for a pre-configured period. It makes extensive use of hardware interrupts to enter the lowest possible power state while sleeping, maximizing battery life. In addition to transmitting data when activity is detected, the sensor also sends regular “check-in” messages at set intervals. This ensures you always know the detector is online, fully operational, and actively monitoring.
  • Industrial Grade Accelerometer with 3-axis for Activity Detection
  • Configurable Activity Detection Parameters with Interrupts
  • Configurable Acceleration Range ±2g to ±16g
  • Configurable Interrupt Threshold
  • Configurable Data Rate
  • Configurable Interrupt Duration
  • Customizable Interrupt Types with Combinations
  • Wall-Mounted or Magnet
  • Mounted IP65 Rated Enclosure
  • Interface to Raspberry Pi, Microsoft® Azure®, Losant, and More
  • Power-Efficient Sleep Mode, Up to 10 Year Battery Life
Hardware Controls
Power Switch
  • Battery Power (ON BATT)
  • Off
  • External Power (ON EXT)
Reset Button and Magnetic Switch
The RESET button and Magnetic Switch will power cycle the sensor. When the sensor first powers up it will send a sensor_mode message with the mode of RUN.
Configuration Button and Magnetic Switch
The Configuration Button (Labeled on board as CFG) and Magnetic Switch serves to test for the presence of power on the sensor. If the CFG button is pressed or Magnetic Switch is activated the TEST LED on the board will light up indicating that the board has power. If no LED comes on check that the Power Switch is in the correct position and that the battery/power supply is good.
Hardware Mode Selection
Run Mode is the default state of the sensor when powered up. No hardware interaction is necessary to enter this state other than power. Pressing the Reset button or activating Magnetic Switch will restart the sensor and put it in the RUN Mode state if no other buttons are pressed.
Sync/Configuration Mode
Configuration or Sync Mode is the state in which the sensor enters in order to change the sensor’s configurable parameters such as; Motion Threshold, Motion Duration, Reporting Interval, Transmission Power, Network ID,etc.
You can enter in this mode manually by pressing and releasing the RESET button or activating Magnetic Switch, device will enters RUN mode, then it will transmit sensor data and finally enters into configuration mode (sync mode). Sensor enters into configuration mode automatically every 1 hour.
This is a temporary mode that is not intended for long-term operation. device will returns automatically to Run mode after a successful configuration in order to resume normal operations.
Factory Default/Reset
A Factory Reset of the sensor will revert all changes and configurations made to the sensor to their default settings from the Factory. Immediately after a factory reset the sensor will go into Configuration Mode in order to be reconfigured with the desired settings. There are two option for Factory reset your sensor. You can either use the physical buttons or the magnetic switches. Refer to the appropriate section below for instructions on how to initiate the process for each case.
Using Buttons
  • Wait for 3-5 seconds
Using Magnetic Switches
  • Wait for 1 second
Default Factory Configuration
ParameterDefault ValueUnitNote
Motion Threshold200mgThe transmitted message will have a msg_type property of 'motion'.
Valid range: 0-23622mg.
Motion Duration20millisecondsValid range: 0-65535 msec
Max Motion Tx Per Interval1Valid Range: 1-30
Data Rate100Hz
Full Scale Range±2g
Enable AxesAll Enabled
Motion Trigger LogicOR ModeOR Mode (Any Axis): The sensor sends an alert if any single axis crosses the defined threshold.
AND Mode (All Selected Axes): The sensor sends an alert only if all enabled axes cross the threshold at the exact same time.
For more information and a general introduction on what Node-Red is and how it works you can view Node-Red’s official web site at https://nodered.org/.
All Enterprise Gateway we offer will come with Node-Red and our library running as a service by default to allow quick and easy access to Node-Red and the sensor data from our sensors. If you are using your own gateway or computer you will need a USB or Ethernet Modem, Node-Red, and our library @ncd-io/node-red-enterprise-sensors.
You can find our library on Node-Red with the name: @ncd-io/node-red-enterprise-sensors
Wireless Gateway Nodes
Wireless Gateway Ready State
When the Wireless Gateway Node’s status indicates “Ready”, as shown in the picture on the right, it means that the wireless network is successfully connected to Node-Red and is ready to receive data from the sensor(s).
Sensors that support SYNC messages can be automatically configured while in this mode if a corresponding Wireless Device node is configured to do so. See section Sensor Configuration Processes for more information.
Wireless Gateway in the Ready State
Wireless Gateway Failed to Connect State
Wireless Gateway node Failed to Connect State
Wireless Gateway Connecting State
Wireless Gateway Node Connecting State
Wireless Gateway No State
modem_mac Message
A modem_mac message indicates the unique address of the wireless module connected to the Wireless Gateway Node. This message is sent when Node-RED is deployed and when the Wireless Gateway is put into Configuration Mode or Ready Mode by using the embedded Wireless Gateway node button. An example modem_mac message can be found on the right.
  • topic
  • payload
  • time
    • Timestamp of the message
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "topic": "sensor_mode",
  "payload": {
    "type": 24,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway Processed Sensor Data Message
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
    • See section msg.payload.sensor_data Breakdown for more information
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 7,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 24,
    "sensor_data": {
      "status": "valid",
      "msg_type": "regular",
      "acc_x": 0,
      "acc_y": 0,
      "acc_z": 0
    "sensor_name": "Activity Detection",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
Wireless Gateway Processed Sensor Data Breakdown
  • status
    • Indicate the sensor status, it reports valid when success and invalid when sensor error.
  • msg_type
    • Indicates the sensor data message type:
      • regular – data sent at regular interval (defined by user – Data transmission interval).
      • motion – data triggered by the vibration crossing a predefined threshold.
  • acc_x
    • The RMS Acceleration over the X axis in G.
  • acc_y
    • The RMS Acceleration over the Y axis in G.
  • acc_z
    • The RMS Acceleration over the Z axis in G.
Wireless Gateway Sync Check In Message
This sync_check_in message reports sensor information and allows for sync initialization if configuration changes are necessary.
A sync_check_in message indicates that the sensor is in RUN mode, but is entering a temporary state where it can be configured. The sensor will send the sync_check_in message on boot (after RUN and sensor_data messages) and once an hour after boot to check in. Once the sensor sends a sync_check_in message Node-RED has 2 seconds to respond with a configuration Master Command.
If Node-RED has a Wireless Device node with Mac Address, Auto Config and OTF Config selected corresponding to the sensor that sent the sync_check_in message then Node-RED will begin to configure that sensor.
An example sync check-in message can be found on the right.
  • topic
    • Indicates the message is a sync message
  • payload
  • payload.type
    • Indicates the type of sync message.
  • payload.address
    • Indicates the unique address of the sensor sending the sync message
  •  payload.sensor_type
  • payload.human_readable object
    • It contains the human readable data, display configuration set up on the sensor at the time of the sync transmission.
  • payload.human_readable.core_version
    • Indicates the board core version.
  • payload.human_readable.firmware_version
    • The actual firmware version running on device.
  • payload.human_readable.sensor_type
    • Displays the sensor type.
  • payload.human_readable.tx_lifetime_counter
    • Tracks the total number of data packets transmitted by the CPU since the device first booted
  • payload.human_readable.hardware_id
    • This value indicates the hardware version of the device
  • payload.human_readable.network_id
    • This value indicates the network Id configured on the device, by default all ncd devices uses 0x7FFF.
  • payload.human_readable.destination_address
    • Shows the current destination address configured on the sensor. The default setting is broadcast mode “00:00:FF:FF”
  • payload.human_readable.node_id
  • payload.human_readable.report_rate
    • Specifies the data transmission interval in seconds.
  • payload.human_readable.output_data_rate
    • Specifies the how many samples the output data has.
  • payload.human_readable.motion_duration
    • Specifies the amount of time in milliseconds that motion/impact must continuously persist before triggering an alert.
  • payload.human_readable.motion_trigger_logic
    • Specifies how the sensor handles the X, Y, and Z axes to trigger an immediate sensor data transmission (motion).
  • payload.human_readable.motion_threshold
    • Specifies the threshold for the sensor to trigger a data transmission.
  • payload.human_readable.enable_axis_x
    • Specifies if x axis is enabled or disabled.
  • payload.human_readable.enable_axis_y
    • Specifies if y axis is enabled or disabled.
  • payload.human_readable.enable_axis_z
    • Specifies if z axis is enabled or disabled.
  • payload.human_readable.full_scale_range
    • Specifies the actual FSR configured
  • payload.human_readable.max_motion_tx_per_interval
    • Specifies the number of times device will transmit a motion data message due to motion triggers per interval.
  • payload.machine_values
    • The Raw data the sensor reports
  • description
    • Indicates information about the current sync message
  "topic": "sync",
  "payload": {
    "type": "sync_check_in",
    "address": "00:13:a2:00:42:35:89:86",
    "sensor_type": 24,
    "human_readable": {
      "core_version": 23,
      "firmware_version": 7,
      "sensor_type": 24,
      "tx_lifetime_counter": 13,
      "hardware_id": {
        "data": [ 99, 61, 0]
     "network_id": "7fff",
     "destination_address": "0000ffff",
     "node_id": 0,
     "report_rate": 900,
     "output_data_rate": "100Hz",
     "motion_duration": "20msec",
     "motion_trigger_logic": "OR Mode",
     "motion_threshold": "800mg",
     "enable_axis_x": "Enabled",
     "enable_axis_y": "Enabled",
     "enable_axis_z": "Enabled",
     "full_scale_range": "±4g",
     "max_motion_tx_per_interval": 5
    "machine_values": { ... }
  "description" : "...",
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
  "time": 1781217138869,
  "_msgid": "33fd88e3ea54492c"
Wireless Gateway Assertion Reason Message
A Assertion Reason message will be used for debugging purpose, It will show the code line number and function name.
An example Assertion Reason message can be found on the right.
  "topic": "assert_rsn",
  "payload": {
    "type": 24,
    "nodeId": 0,
    "line_number": 1435,
    "function_name": "app_start_fly_timer"
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
Wireless Node Configuration
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
    • For More information on the submenu this icon bring up see section ncd-gateway-config Nodes​
Wireless Device Nodes
Wireless Device Node Statuses
Running Mode
No Mode
FLY Mode
When the Wireless Sensor Node’s status indicates “FLY,” as shown in the picture to the right, it means the sensor has sent a sync message to check in for an Over-the-Air (OTA) configuration, and the synchronization process has been successfully completed.
Wireless Device Node Messages
Wireless Device Sensor Data Message
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
    • See msg.payload Breakdown for more information
  • time
  "data": {
    "nodeId": 0,
    "firmware": 10,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 24,
    "sensor_data": {
      "status": "valid",
      "acc_x": 0,
      "acc_y": 0,
      "acc_z": 0
    "original": {...},
  "payload": {
      "status": "valid",
      "acc_x": 0,
      "acc_y": 0,
      "acc_z": 0
  "_msgid": "48e99332fc104565"
Wireless Device Sensor Data Breakdown
  • status
  • msg_type
  • acc_x
  • acc_y
  • acc_z
  "topic": "sync",
  "payload": {
    "sensor_type": 24,
    "human_readable": {
      "core_version": 23,
      "sensor_type": 24,
      "hardware_id": {
     "node_id": 0,
     "report_rate": 900,
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Sync Acknowledgment Message
A sync acknowledgment is received from the sensor in response to a configuration command. This message provides the current sensor status or reports any errors encountered during the configuration process. You may verify the current sensor configuration by examining the human_readable property within the message.
An example of a Sync Acknowledgment message is provided for your reference on the right.
  "topic": "sync",
  "type": "sync_acknowledgment",
  "sensor_type": 24,
  "payload": {
    "sensor_type": 24,
    "response_bytes": [ ... ],
    "human_readable": { ... },
  "sent": [...],
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Sync End Message
Sync process finished. Sensor is reporting its new values after Sync and resuming normal operations.
User can find the new settings after sync into “human_readable” property.
  "topic": "sync",
  "type": "sync_end",
  "sensor_type": 24,
  "payload": {
    "type": "sync_end",
    "sensor_type": 24,
  "sent": [...],
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Sync Response Success Message
Indicates that the sync configuration is complete and displays the specific values and properties applied to the settings.
  "topic": "sync",
  "type": "sync_response",
  "sensor_type": 24,
  "payload": {
    "sensor_type": 24,
    "values": { ... },
    "pass": { ... },
    "status": "Success",
    "exit_otn_mode": { ... }
Sync Response Skip Message​
A “Sync Response Skip” message indicates that the settings currently active within the corresponding Wireless Device node already match the sensor’s actual configuration. Consequently, the library bypasses the synchronization process. This functionality allows the library to verify if the sensor’s reported configuration aligns with the desired parameters, thereby optimizing the process by skipping redundant updates.
If you encounter this message, it confirms that the sensor is already configured with the desired settings as defined in the sync message.
  "topic": "sync",
  "sensor_type": 24,
  "payload": {
    "sensor_type": 24,
    "info": "Reported configurations match desired configurations. Skipping Sync."
Configuration Options
Our Node-Red library lets you configure any of sensor easily, simply by adjusting a few fields in your Node-RED flow and triggering a configuration update waiting for a FLY (sync) message sent every hour during normal operations (or when the device is reset).
Primary Configurations
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes​
  • Serial Device for Config
  • Mac Address*
  • Sensor Type*
  • Auto Config
  • OTF Config
    • Checking the box next to this field AND having Auto Config checked tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when a FLY message is detected
NCD Activity Detection Sensor Gen4 Wireless Device Node
  • Wait for Network Formation
  • Destination Address
    • For more information on how to get the Address of the receiver module connected to Node-Red see section Wireless Gateway modem_mac Message
  • Network ID
  • Node ID
  • Power
  • Retries
Set Motion Threshold
Set a motion detection threshold for the sensor to trigger a data transmission. This is an interrupt-based configuration.
 • The transmitted message will have a msg_type property of ‘motion’.
 • Valid range: 0-23622mg.
Default value: 200mg.
NCD Activity Detect Sensor Motion Threshold
Set Motion Duration
Sets the minimum amount of time in milliseconds that motion/impact must continuously persist before triggering an alert. This filters out single, brief vibrations or random background noise from causing false alarms.
 • Valid range: 0-65535 msec.
Default value: 20 milliseconds.
Set Max Motion Tx Per Interval
Set Number of times device will transmit a motion data message due to motion triggers per interval.
Valid Range: 1-30
Default value: 1.
Data Rate
This would determine how many samples the output data has.
Default value: 100Hz.
NCD Activity Detect Sensor Data Rate
Set Full Scale Range
Set how large of a range the device can measure acceleration in.
Default value: ±2g.
NCD Activity Detect Sensor FSR
Set Enable Axes
Enable or Disable the individual Axes; X, Y or Z.
Default value: All Enabled.
Set Motion Trigger Logic
This setting determins how the sensor handles the X, Y, and Z axes to trigger an immediate sensor data transmission (motion). It allows you to choose whether a single axis or a combination of axes must cross your safety threshold before sending a Motion message.
Default value: OR Mode.
NCD Activity Detect Sensor Motion Trigger Logic
OTF Automatic Configuration
This sensor supports configuration while in Run Mode. We call this configuration OTF or On the Fly. This configuration is initiated by a SYNC message from the Sensor with the topic of sync. These messages are sent over the standard Run Mode wireless network so there is no need to change the Wireless Gateway nodes mode or manually manipulate the buttons on the sensor.
Sync messages are sent once an hour and on boot and tell Node-RED that the sensor is ready for configuration changes. Node-RED has two seconds to respond with a configuration command or extend this temporary configuration mode.
If you have a Wireless Device node with Mac address, Auto Config and OTF Config corresponding to the sensor that sent the sync message then Node-Red will begin configuring that sensor according to the settings entered on the Wireless Device node.
Example Auto Configuration Process​
If you have entered the sensor Mac Address, selected the Auto Config and OTF Config boxes, your sensor will pick up any configuration changes you have made to the Sensor Specific parameters and automatically apply them.
This process is not immediate and requires the device send a sync Message to the Gateway (this happens once every hour or when the device is reset).
Once the sync message has been received the device will enter OTN mode (indicated by a corresponding message) and update any parameters that have been changed.
Once done the device will continue its normal operating with the updated parameter values.
Let us look at an example to better illustrate how the process should work out.
Step 1
Draw and drop a Wireless Device node and connect a debug node at the Wireless Device node, then double click on Wireless Device node to access its properties. Enter the Mac Address of the target sensor, check the two boxes, the one next to “Auto Config” and the one next to “OTF Config”. This will allow the device to work in a mode where it will Automatically pick up the configuration changes.
Step 2
Select the parameter you want to modify.
Let’s go to the “Motion Threshold” and change its value. This parameter determines the motion detection threshold for the sensor to trigger a sensor data transmission.
The default value is 200mg, let’s change it to 400 mg.
Make sure you check the “Active” check box, this will let the sensor know that it needs to update this parameter.
Enter the value into text input, in this case 400.
Press the “Done” button to close the Wireless Device node.
Press the “Deploy” button so you can update the flow.
Step 3
Reset the sensor in order to trigger a sync message (configuration mode).
(this will speed things up so you don’t need to wait for the 1 hour automatic sync message time).
NCD Node-RED Flow Configuration Example
You will receive a series of messages into debug window, which are normally sent after deploy and the sensor starts (modem_mac, RUN, sensor_data, then sync_check_in).
NCD Activity Detect Sensor 24 Config Messages
The most important element here is the sync_check_in message, which reports the device’s current configuration at the moment it is transmitted. You can view an example of this message on the right for your reference.
Once the sensor sends a sync_check_in message, Node-RED receives it and compares the sensor’s current settings with your newly desired settings. If they do not match, Node-RED recognizes that an update is needed and automatically sends a master command to apply the new configuration.
For example, in this specific case, the sensor’s current motion_threshold is set to 200mg, but we want to update it to 400mg. Because Node-RED detects this difference, it will automatically initiate the sync configuration process to update your device.
  "topic": "sync",
  "payload": {
    "sensor_type": 24,
    "human_readable": {
      "core_version": 23,
      "sensor_type": 24,
      "hardware_id": {
     "node_id": 0,
     "report_rate": 900,
     "motion_threshold": "200mg", // THIS
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
  "topic": "sync",
  "sensor_type": 24,
  "payload": {
    "sensor_type": 24,
Once Node-RED sends the master command with the new desired settings, the sensor will respond with a sync_acknowledgment message, followed by a sync_end message, and finally a sync message with a “success” status. This sequence indicates that the configuration process is complete.
NCD Type 127 Configuration Example
Once the sync configuration has finished, you can verify the new sensor settings by expanding the sync_end message in the debug window. There, you can review the human-readable properties to see the actual configurations applied to the sensor. In this example, the motion_threshold will now show as 400mg.
  "topic": "sync",
  "payload": {
    "sensor_type": 24,
    "human_readable": {
      "core_version": 23,
      "sensor_type": 24,
      "hardware_id": {
     "node_id": 0,
     "report_rate": 900,
     "motion_threshold": "400mg", // THIS
  "packet_info": {
      "ack": 0,
      "broadcast": 0,
      "type": ""
Check Sensor Power
Press the CFG button on the sensor. If the TEST LED on the sensor lights up then the sensor has power. If the LED does not light up try swapping out the battery.
If the LED still doesn’t light up after changing the battery contact us for additional troubleshooting steps.
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Factory reset by pressing and release the RESET button, wait for a second, then press and hold the CONFIGURATION button, hold the CONFIGURATION button for more than 15 seconds, release CONFIGURATION button, then Wait for 3-5 seconds, finally press and release the RESET button.
  2. You should receive a sensor_mode message with the mode of PUM and then a second sensor_mode message with the mode of RUN
Multiple Gateways
Move Devices Closer
