Explore The Wireless Activity Detection Gen4
Introducing NCD’s Gen4 Industrial Wireless Activity Detector. Utilizing a wireless mesh networking architecture, this device offers an impressive wireless range of up to 2 miles. It incorporates a high-accuracy acceleration sensor that measures changes in acceleration to reliably detect mechanical movement (activity).
Upon detecting activity, the device immediately transmits a message to a remote gateway or modem, then returns to a sleep state for a pre-configured period. It makes extensive use of hardware interrupts to enter the lowest possible power state while sleeping, maximizing battery life. In addition to transmitting data when activity is detected, the sensor also sends regular “check-in” messages at set intervals. This ensures you always know the detector is online, fully operational, and actively monitoring.
Features:
- Industrial Grade Accelerometer with 3-axis for Activity Detection
- Configurable Activity Detection Parameters with Interrupts
- Configurable Acceleration Range ±2g to ±16g
- Configurable Interrupt Threshold
- Configurable Data Rate
- Configurable Interrupt Duration
- Customizable Interrupt Types with Combinations
- Wall-Mounted or Magnet
- Mounted IP65 Rated Enclosure
TEST LED blinks twice and then one more time – Message was sent successfully but there was an error in last sensor read.
TEST LED blinks thrice (quickly) – MCU is having issue communicating with the radio module.
TEST LED blinks once – Message was sent successfully and no error in last sensor read as well in data transmission.
| Width | 3.54" | |||
| Length | 4.52" | |||
| Height | 2.16" | |||
| Probe Operating Temperature | -40° C | 23° C | 85° C | As Tested by NCD Staff |
| Inputs | Digital, Acceleration, Magnetic, Current | |||
| Opto-input Voltage | 3.3 V | 24V | ||
| Reporting interval | 5 seconds | 600 seconds | 16777215 seconds | How often data is transmitted wirelessly |
| Range of counter values | 1 | 4294967295 | The maximum number of events the sensor can count to | |
| CT Current | 1.5% FS | FS | Minimum current read by the CT. CT range 100 to 1000Amp |
RF Module Specifications
- This device is Powered by a single D-cell (LR20) battery
While changing the batteries:
- Turn off the sensor
- Only use a new D-cell battery (obtain one from NCD, as it has a built in supercapacitor, this is not a regular battery).
- Make sure to align the connector in the proper orientation (this will assure you match the polarity)
- The battery should not be replaced in fire-risky areas
- Do NOT install a rechargeable battery
Head to the NCD store if you want to purchase the Wireless Activity Detection Gen4.
