Wireless Activity Detection Gen4 API Overview
Explore The Wireless Activity Detection Gen4
Introducing NCD’s Gen4 Industrial Wireless Activity Detector. Utilizing a wireless mesh networking architecture, this device offers an impressive wireless range of up to 2 miles. It incorporates a high-accuracy acceleration sensor that measures changes in acceleration to reliably detect mechanical movement (activity).
Upon detecting activity, the device immediately transmits a message to a remote gateway or modem, then returns to a sleep state for a pre-configured period. It makes extensive use of hardware interrupts to enter the lowest possible power state while sleeping, maximizing battery life. In addition to transmitting data when activity is detected, the sensor also sends regular “check-in” messages at set intervals. This ensures you always know the detector is online, fully operational, and actively monitoring.
Features:
  • Industrial Grade Accelerometer with 3-axis for Activity Detection
  • Configurable Activity Detection Parameters with Interrupts
  • Configurable Acceleration Range ±2g to ±16g
  • Configurable Interrupt Threshold
  • Configurable Data Rate
  • Configurable Interrupt Duration
  • Customizable Interrupt Types with Combinations
  • Wall-Mounted or Magnet
  • Mounted IP65 Rated Enclosure
  • Interface to Raspberry Pi, Microsoft® Azure®, Losant, and More
  • Power-Efficient Sleep Mode, Up to 10 Year Battery Life
Frame Structure
Figure 3 provides an outline of the frame structure at Power Up, where the bytes highlighted in Red denote which mode the device has started in (Run, Configuration or Factory Default). You can look up the corresponding codes in Table 2.
If we further examine the Payload, we can use the Node ID and Sensor Type fields to determine the exact sensor that is sending the data.
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A2 00 42 35 89 86 FF FE C2 7A 01 00 00 72 03 17 52 55 4E 00 00 00 00 00 00 79Example frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A200425364538Source Address
0xFFFE2Reserved
0xC21R. Option
0x7A1Header with Power Up value
0x001Node ID
0x001Separator
0x00182Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0x791Checksum
Configuration Mode Frame
7E 00 44 90 00 13 A2 00 42 35 89 86 FF FE C2 4F00 00 19 06 00 18 00 00 05 35 63 26 00 7F FF 00 00 FF FF 00 00 00 02 58 05 00 14 00 03 20 01 01 01 01 05 5FExample frame
0x7E1Delimiter
0x00442Length
0x901Frame Type
0xFFFE2Reserved
0xC21R. Option
4F1Header
00002Reserved
171Core Engine Version
0B1Firmware Version
007F2Sensor Type
000000014Tx Life Counter
633D003Hardware ID
7FFF2Network ID
0000FFFF4Destination Address
001Node ID
0000000A4Report Rate
051Output Data Rate
00142Motion Duration
001Logic Mode
03202Motion Threshold
011X Axis Enabled/Disabled
011Y Axis Enabled/Disabled
011Z Axis Enabled/Disabled
011Full Scale Range
051Max Transmission Per Interval
5F1Checksum
Factory Reset Mode Frame
7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 18 00 00 50 55 4D 00 00 00 00 00 00 D1Example frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0xC21R. Option
0x7A1Header
0x001Node ID
0x001Separator
0x00182Sensor Type
0x00002Separator
0x50554D3Mode Byte for Factory Reset Mode
0xD11Checksum
Sync Check In Frame
7E 00 44 90 00 13 A2 00 42 35 89 86 FF FE C2 6F 00 00 19 06 00 18 00 00 05 35 63 26 00 7F FF 00 00 FF FF 00 00 00 02 58 05 00 14 00 03 20 01 01 01 01 053EExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0x001R. Option
6F1Header
00002Reserved
0B1Firmware Version
00182Sensor Type
633D003Hardware ID
7FFF2Network ID
001Node ID
051Output Data Rate
001Logic Mode
011Full Scale Range
3E1Checksum
Sync Acknowledgment Frame
7E 00 44 90 00 13 A2 00 42 35 89 86 FF FE C2 5F 00 00 19 06 00 18 00 00 05 35 63 26 00 7F FF 00 00 FF FF 00 00 00 02 58 05 00 14 00 03 20 01 01 01 01 05 D6Example frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0x001R. Option
5F1Header
00002Reserved
0B1Firmware Version
00182Sensor Type
633D003Hardware ID
7FFF2Network ID
001Node ID
051Output Data Rate
001Logic Mode
011Full Scale Range
5F1Checksum
Assertion Reason Frame
77 00 00 00 6E 00 00 00 08 C3 61 70 70 5F 73 74 61 72 74 5F 66 6C 79 5F 74 69 6D 65 72 00 00 00 00 00 00 00 00 00Example frame
0x771Delimiter
0x002Node ID
0x00002Reserved
0x007F2Sensor Type
0x000008C34Line Number
0x00Function Name
Sensor Data Frame
Frame FieldOffset (Payload section)Fixed Value (if any)LengthDescription
Header00x7F1Header to differentiate various types of packets
Node ID10x001Node ID to differentiate up to 256 nodes in a network. User configurable values
Firmware20x011Used to determine firmware version programmed in the device
Battery VoltageMSB 30x032Battery Voltage = 0.00322*(03*FF+FE)
LSB 40xFEBattery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V
Packet Counter5-1It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets
Sensor TypeMSB 60x002Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end.
LSB 70x18Sensor Type 24
Error/Reserved byte80x001Bit 7: Reserved
Bit 6: Reserved
Bit 5: Reserved
Bit 4: Reserved
Bit 3: Reserved
Bit 2: Transmission Type
Bit 1: Status
Bit 0: Reserved
Acceleration X Axis9/ Data[0]
10/ Data[1]-
11/ Data[2]-
12/ Data[3]-4X Axis = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3]
Acceleration Y Axis13/ Data[0]
14/ Data[1]-
15/ Data[2]-
16/ Data[3]-4Y Axis = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3]
Acceleration Z Axis17/ Data[0]
18/ Data[1]-
19/ Data[2]-
20/ Data[3]-4Z Axis = Data[0] << 24 | Data[1] << 16 | << Data[2] << 8 | Data[3]
To put an NCD.io wireless sensor into manual configuration mode, you can do the following:
Using Buttons
1. Press and release the RESET button
2. Immediately press and hold the CONFIGURATION button
3. Hold the CONFIGURATION button for about 5–8 seconds
4. Release the CONFIGURATION button
Using Magnetic
1. Bring the magnet into close proximity to the designated RESET point on the device housing, then remove it immediately.
2. Immediately place the magnet against the designated CONFIGURATION activation point on the device housing and hold it in place.
3. Maintain the magnet’s position at the CONFIGURATION point for approximately 5 to 8 seconds.
4. Remove the magnet from the CONFIGURATION position.
CONFIGURATION SWITCHS
RESET SWITCHS
Figure 5: Communication Procedure - Configuration Mode
Sync Config Mode
This specific device also supports SYNC mode, which allows you to configure the sensor without needing physical access to it (no need to press buttons or trigger a magnetic switch).
By default, the device automatically enters SYNC mode every hour and transmits a SYNC packet (described below). This packet serves two main purposes:
  • Current Settings: It includes all the active settings, allowing you to easily verify or read the sensor’s current configuration.
  • Configuration Window: It signals that the sensor is temporarily in configuration mode. During this brief time window, you can transmit a Master Command to update the settings.
Once the time window closes, the device automatically returns to its normal operation (Run mode).
Example Configuration Command
The following is an example on how to read and change some of the parameters that affect the operation of the NCD Sensor.
Master Command
The Master Command is a comprehensive command that allows you to configure all of the device’s settings in a single transmission.
Below, you will find the structure of the master command, along with a detailed payload description for each byte.
					7E 00 38 10 01 00 00 00 00 00 00 FF FF FF FE 00 00 6C 00 00 7F FF 00 00 FF FF 00 00
00 01 2C 07 00 19 01 07 44 01 01 00 03 0A C9
Complete Payload
					6C 00 00 7F FF 00 00 FF FF 00 00 00 01 2C 07 00 19 01 07 44 01 01 00 03 0A
Master Command Payload Description
IndexByteSize (bytes)SettingValid OptionsDescription
[0]6C1 Header
[1:2]00 002 Reserved
[3:4]7F FF2 Network ID0x00 -- 0x7FFFNetwork ID Valid Range: 0-0x7FFF.
[5:8]00 00 FF FF4 Destination AddressDefault value: 0000FFFF for Broadcast Mode
Example of targeted address: 41D5EC37
Sets the Destination Address of the sensor.
The sensor will send Run mode Data packets to this Address
[9]001 Node ID0x00 -- 0xFFSets the Device node ID and Data Transmission Interval.
The node id value can go from 0-255 and The Data transmission value can go from 3-0xFFFFFF Seconds
[10]0E1 Output Data Rate0x01--1Hz
0x02--10Hz
0x03--25Hz
0x04--50Hz
0x05--100Hz (Default)
0x06--200Hz
0x07--400Hz
This would determine how many samples the output data has,
which is directly related to the highest frequency components that can be measured.
[11:12]001A2Motion DurationValid Range:
0x01 -- 0xFFFF
Sets the minimum amount of time in milliseconds that motion/impact must continuously persist before triggering an alert. This filters out single, brief vibrations or random background noise from causing false alarms.
[13]011Motion Trigger Logic0x00: OR(default)
0x01: AND
This setting determins how the sensor handles the X, Y, and Z axes to trigger an immediate sensor data transmission (motion). It allows you to choose whether a single axis or a combination of axes must cross your safety threshold before sending a Motion message.
[14:15]000A2Motion ThresholdValid Range:
0x01 -- 0x5C46
Set a motion detection threshold for the sensor to trigger a data transmission. This is an interrupt-based configuration.
[16]011Enable or Disable X axis0x00: Disable
0x01: Enable
[17]011Enable or Disable Y axis0x00: Disable
0x01: Enable
[18]011Enable or Disable Z axis0x00: Disable
0x01: Enable
[19]011Full Scale Range0x00: +- 2g(default)
0x01: +- 4g
0x02: +- 8g
0x03: +- 16g
Set how large of a range the device can measure acceleration in.
[20]011Max Motion Tx Per IntervalValid Range:
0x01 -- 0x1E
Set Number of times device will transmit a motion data message due to motion triggers per interval.
Read Sensor Settings
Sync
By using the SYNC packet, you can easily check the current settings configured on your sensor. The SYNC message includes the exact bytes that correspond to your active configuration values (you can find an example of a SYNC packet at the beginning of this document).
If you ever need to manually trigger a SYNC message, simply press the reset button. When you do this, the sensor will respond by sending a quick sequence of three messages: RUN, followed by sensor_data, and finally SYNC.
Additionally, the sensor will automatically transmit a SYNC message every hour by default to keep everything updated.
Read Sensor Power Command:
A. Sensor MAC Address
					00 13 A2 00 41 91 1B 83
B. Sensor Payload
C. Power Level
					0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
B. Complete Sensor Payload
C. Retries Number
					0x0A (data byte 23)
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
In order to successfully communicate over the API protocol, the checksum is of vital importance. The X-bee at either end of the link will reject packets if the checksum does not match.
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
