Introducing NCD’s Ultrasonic Long Range Wireless Tank Level Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a corrosion resistant Ultrasonic proximity detection sensor, this wireless device transmits highly accurate tank levels as distance values at user-defined intervals. The Ultrasonic tank level sensor features 1mm resolution with a distance measurement range of 40 to 9999mm. Please note the recommended useful range is 500 to 9999mm for best reliability. The Ultrasonic tank level sensor is IP67 rated and comes with a 75 inch (1.9 Meter) probe while the transmitter has a IP65 rating.
Applications requiring 100% reading-to-reading reliability should not use Ultrasonic Tank Level Sensors at a distance closer than 500mm. Although many users have found a Ultrasonic Tank Level Sensor to work reliably from 0 to 50cm for detecting objects, it is not guaranteed to have operational reliability for objects closer than the minimum reported distance. Because of ultrasonic physics, these sensors are unable to achieve 100% reliability at close distances.
Feature
- Industrial Grade Ultrasonic Tank Level Sensor
- Reading-to-Reading stability of 1mm at 1 Meter (typical)
- 500 to 9999mm Measurement Range with 1mm Resolution
- 40 to 499mm Measurement Range with Reduced Reliability
- Target Size Compensation for Greater Consistency and Accuracy
- Fully Calibrated and Linearized with Temperature Compensation
- Long Range Wireless Range of Up to 2 Miles Line of Sight
- 128-Bit AES Encrypted Wireless Communications
- Standard Electrical 3/4 Inch PVC Pipe Fitting
- Supports Smart Percentage Detection Change Mode
- Validates and Retries on Lost Communication Packets
Wireless Technology
Battery Life
| Batteries | - | 1 | - | The devices comes with a single 9000mAh battery |
The Truth About Battery Life
Applications & Use-cases
The Ultrasonic Long Range Wireless Tank Level Sensor is capable of monitoring key environmental metrics like CO2 levels, temperature, humidity in real-time. Such a sensor can be useful in various industries and sectors due to its ability to wirelessly transmit critical environmental data for analysis and decision-making.
Ultrasonic Long Range Wireless Tank Level Sensor Applications
Municipal Water Management
The sensor can be deployed in municipal water storage tanks to monitor water levels across different facilities. It enables central control rooms to maintain an efficient water supply and avoid unexpected shortages, part
Smart City Solutions for Waste Management
Smart cities can use this tank level sensor on liquid waste storage tanks to monitor fill levels and optimize collection schedules. By knowing which tanks are close to full, waste management companies can prioritize pickups, reducing transportation costs and minimizing overflow risks.
Oil and Gas Tank Monitoring
This sensor can be used to monitor crude oil, gasoline, or other petroleum product levels in storage tanks. Wireless data transmission allows operators in the oil and gas industry to monitor tank levels remotely, facilitating efficient inventory management and ensuring a stable supply chain.
Food and Beverage Industry for Ingredient Storage
In the food and beverage industry, tanks are used to store ingredients like oils, syrups, and other liquid ingredients. This sensor can help manufacturers monitor ingredient levels in real-time, automate restocking alerts, and maintain consistent production without manual checks.
Ultrasonic Long Range Wireless Tank Level Sensor Use-cases
Remote Water Tank Monitoring for Agricultural Irrigation
Farmers can install the tank level sensor on water storage tanks used for irrigation. The sensor can monitor the water level and transmit real-time data wirelessly to a control system or mobile device. This setup enables efficient water management, ensuring that tanks are refilled before depletion and automating irrigation schedules based on tank levels.
Fuel Tank Monitoring for Industrial Generators
In industries that rely on backup generators, fuel tanks must be monitored continuously to ensure an uninterrupted power supply during outages. This sensor can be mounted on generator fuel tanks to provide real-time fuel level data, helping maintenance teams manage fuel supply proactively and reducing the risk of generator downtime.
Chemical Storage Tank Monitoring in Manufacturing
Many manufacturing plants store various chemicals for production processes. Monitoring the levels of these chemicals is essential for safety and operational efficiency. This sensor can be used to track the levels of chemicals stored in large tanks, alerting operators to refill them when levels are low and avoiding potential disruptions in the production line.
Water and Wastewater Treatment Facilities Monitoring
Wastewater treatment plants have multiple tanks that require constant level monitoring to maintain balance in the treatment process. This ultrasonic sensor can monitor levels in treatment and holding tanks, enabling operators to manage inflow and outflow efficiently, reducing the risk of overflow or system failure.
