- Device Overview
- Frame Structure
- Read Sleep Duration
- Read Sensor Network ID
- Appendix
Introducing NCD’s Ultrasonic Long Range Wireless Tank Level Sensor, boasting up to a 2 Mile range using a wireless mesh networking architecture. Incorporating a corrosion resistant Ultrasonic proximity detection sensor, this wireless device transmits highly accurate tank levels as distance values at user-defined intervals. The Ultrasonic tank level sensor features 1mm resolution with a distance measurement range of 40 to 9999mm. Please note the recommended useful range is 500 to 9999mm for best reliability. The Ultrasonic tank level sensor is IP67 rated and comes with a 75 inch (1.9 Meter) probe while the transmitter has a IP65 rating.
Applications requiring 100% reading-to-reading reliability should not use Ultrasonic Tank Level Sensors at a distance closer than 500mm. Although many users have found a Ultrasonic Tank Level Sensor to work reliably from 0 to 50cm for detecting objects, it is not guaranteed to have operational reliability for objects closer than the minimum reported distance. Because of ultrasonic physics, these sensors are unable to achieve 100% reliability at close distances.
Feature
- Industrial Grade Ultrasonic Tank Level Sensor
- Reading-to-Reading stability of 1mm at 1 Meter (typical)
- 500 to 9999mm Measurement Range with 1mm Resolution
- 40 to 499mm Measurement Range with Reduced Reliability
- Target Size Compensation for Greater Consistency and Accuracy
- Fully Calibrated and Linearized with Temperature Compensation
- Long Range Wireless Range of Up to 2 Miles Line of Sight
- 128-Bit AES Encrypted Wireless Communications
- Standard Electrical 3/4 Inch PVC Pipe Fitting
- Supports Smart Percentage Detection Change Mode
- Validates and Retries on Lost Communication Packets
Frame Structure
| 8 | 0x55 | |||
| 9 | 0x4E | |||
| 8 | 0x47 | |||
| 9 | 0x4D | |||
| 8 | 0x55 | |||
| 9 | 0x4D |
Run Mode Power Up Frame
| 0x7E | 1 | Delimiter |
| 0x001C | 2 | Length |
| 0xFFFE | 2 | Reserved |
| 0x00 | 1 | R. Option |
| 0x01 | 1 | Node ID |
| 0x00 | 1 | Separator |
| 0x0001 | 2 | Sensor Type |
| 0x0000 | 2 | Separator |
| 0x0B | 1 | Checksum |
| 0x0E | 1 | Checksum |
Sensor Data Frame
Data Payload
| Field | Offset (Payload Section) | Value ( or Default ) | Length | Description |
| Header | 0 | 7F | 1 | Header to differentiate various type of packets |
| Node ID | 1 | 00 | 1 | User Defined ID |
| Firmware Version | 2 | 01 | 1 | Device Firmware Version |
| Battery Level | MSB 3, LSB 4 | - | 2 | Sampled battery voltage of the device. Battery Voltage=((Battery Voltage MSB x 256+Battery Voltage LSB) x 0.00322 V |
| Packet Counter | 5 | - | 1 | It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets. |
| Sensor Type | MSB 6, MSB 7 | 00, 0x22 | 2 | Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end |
| Error/Reserve Byte | 8 | 00 | 1 | error code = 1 ( data was not ready) |
| Sensor Data | MSB 9/ Data[0] | - | 2 | Tank Level in mm |
| 10/ Data[1] | - | Level(usigned) = ((Data[0]<<8)+(Data[1])) | ||
| 11/ Data[2] | not used | |||
| LSB 12/ Data[3] | not used |
Configuration Mode Frame
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05
Complete Payload
Appendix
Configuration Commands
Command Acknowledgement Data
| 14 | Set Encryption Key | 1 | 8 | 0xFF (OK) |
Application Specific Commands
| No. | Command | Sub Command | Command Code | Argument | Note |
| Set Sensor Temperature Offset Coefficient | F4 | 1E | 0x00, 0x00 | 35 00 04 | Set the offset to 4 degrees |
| Set Sensor Altitude Value | F7 | 1C | 0x00, 0x00 | 00 00 03 F6 | Set the Altitude to 03F6 {HEX] = 1014 DEC meters |
| Set Sensor Forced Calibration Value | F7 | 1F | 0x00, 0x00 | 00 01 BD | Set the force calibration value to 445 |
Error Code Descriptions
| 0x01 | Invalid command |
| 0x03 | Node ID mismatch |
Calculation for transmission
0x04
0xFF-0x04=0xFB
Calculation for reception
2. Keep only the last 8 bits
0xFF
