Two Channel Vibration Sensor Gen4 User Manual
Introducing NCD’s Two Channel Vibration Sensor Gen4. Lightweight rugged and reliable for accurate asset monitoring and boasting up to a 2-mile range using a wireless mesh networking architecture & Incorporating a 16-bit Vibration and integrated Temperature sensor.
This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range.  Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
  • Small & lightweight for ease of installation.
  • IP65 rated sealed enclosure for dust &
    moisture protection.
  • Metal probe housing for durability in harsh industrial environments.
  • A versatile user-configurable sample rate for slow or fast-running machines
  • Integrated temperature sensor in base.
  • In-Built Machine Learning optimizes power consumption.
  • Asset On-Time Calculator automatically tracks operational status.
  • Hardware Accelerator enhances vibration sampling accuracy.
  • Configurable Sample Rate – 100Hz to 25.6KHz
  • Available Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
  • Supports MESH networking via DigiMesh
  • Fully open Node-RED library for configuration and data ingestion
Hardware Controls
Power Switch
  • Battery Power
  • Off
  • External Power
Enclosure Type 1 -> Click to expand
Enclosure Type 2 -> Click to expand
RESET Button
CFG Button
Hardware Mode Selection
Factory Default/Reset
Using Buttons
  • Wait for 3-5 seconds
Using Magnetic Switches
  • Wait for 1 second
Timing Using Buttons
Click to enlarge
Default Configuration
ParameterDefault Value (Probe 1)Default Value (Probe 2)UnitNote
Output Data Rate1280012800Hz
Sampling Duration20 (1000msec)20 (1000msec)msec20*50 = 1000msec
*Sampling Duration depends on the ODR value
Low Pass Filter44
High Pass Filter20482048
Full Scale Range88g
Sampling Interval3030min
Filter StatusEnabledEnabled
Operation Mode3 - Smart3 - Smart
Data on Request Timeout11sec
Acceleration Dead Band2020mg
Acceleration Wake/Interrupt Threshold10 (500mg)10 (500mg)mg10*50 = 500mg
Payload Length180180bytes
Auto Raw IntervalDisabledDisabled
Auto Raw Destination Address0000FFFF0000FFFFhex
Smart Mode Skip Interval33
FLY Interval6060min
RPM Calculate StatusEnabledEnabled
Max Raw Sample40964096
Real-Time ClockDisabledDisabled
Clear Probe UptimersDisabledDisabled
Smart Mode Threshold10 (500mg)10 (500mg)mg10*50 = 500mg
Set Motion to Sampling Delay100 (5000msec)100 (5000msec)msec100*50 = 5000msec
*Apply for Firmware v6+
Set Max Number Motion Tx Per Interval1*Apply for Firmware v6+
Wireless Gateway Nodes
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
Wireless Gateway Sensor Data Message (Processed)
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "topic": "sensor_data",
  "payload": {
    "nodeId": 0,
    "firmware": 14,
    "battery": "3.28",
    "battery_percent": "98.56",
    "counter": 26,
    "sensor_type": 111,
    "sensor_data": {
        "mode":0,
        "msg_type": "regular",
        "s1_odr":"800Hz",
        "s1_temperature":23.67,
        "x1_rms_ACC_G": 0.001,
        "x1_max_ACC_G": 0.002,
        "x1_velocity_mm_sec": 0.03,
        "x1_displacement_mm": 0.04,
        "x1_peak_one_Hz": 5,
        "x1_peak_two_Hz": 6,
        "x1_peak_three_Hz": 7,
        "y1_rms_ACC_G": 0.008,
        "y1_max_ACC_G": 0.009,
        "y1_velocity_mm_sec": 0.1,
        "y1_displacement_mm": 0.11,
        "y1_peak_one_Hz": 12,
        "y1_peak_two_Hz": 13,
        "y1_peak_three_Hz": 14,
        "z1_rms_ACC_G": 0.015,
        "z1_max_ACC_G": 0.162,
        "z1_velocity_mm_sec": 1.63,
        "z1_displacement_mm": 1.64,
        "z1_peak_one_Hz": 165,
        "z1_peak_two_Hz": 166,
        "z1_peak_three_Hz": 256,
        "rpm_1": 167
        "s2_odr":"800Hz",
        "s2_temperature":23.67,
        "x2_rms_ACC_G": 0.001,
        "x2_max_ACC_G": 0.002,
        "x2_velocity_mm_sec": 0.03,
        "x2_displacement_mm": 0.04,
        "x2_peak_one_Hz": 5,
        "x2_peak_two_Hz": 6,
        "x2_peak_three_Hz": 7,
        "y2_rms_ACC_G": 0.008,
        "y2_max_ACC_G": 0.009,
        "y2_velocity_mm_sec": 0.1,
        "y2_displacement_mm": 0.11,
        "y2_peak_one_Hz": 12,
        "y2_peak_two_Hz": 13,
        "y2_peak_three_Hz": 14,
        "z2_rms_ACC_G": 0.015,
        "z2_max_ACC_G": 0.162,
        "z2_velocity_mm_sec": 1.63,
        "z2_displacement_mm": 1.64,
        "z2_peak_one_Hz": 165,
        "z2_peak_two_Hz": 166,
        "z2_peak_three_Hz": 256,
        "rpm_2": 167
    "sensor_name": "Two Channel Vibration Plus Gen4",
    "type": "sensor_data",
    "received": 1721424191583,
    "original": {...},
  "time": 1721424191584,
  "_msgid": "d7f3341ef39225df"
Processed Data msg.payload.sensor_data Breakdown
  • mode
    • The sensor works in one of 4 modes:
      • 0 – Processed – FFT is performed by the sensor and the measurement data is presented in condensed form (both time and frequency parameters)
      • 1 – Raw/time domain – the Raw/time domain data is gathered and transmitted and it is up to the client to perform the FFT if needed. This is a very large data packet.
      • 2 – Оn demand, sending Processed data regularly, with the option to request a Raw/time domain data packet
      • 3 – Smart – a cutting-edge operational setting. In this mode, the sensor delivers Processed Data (Overall Data) at user-defined intervals, with a Time Domain on Request option for requesting detailed Raw data packets, complemented by an Auto Raw Interval that dictates how often the sensor automatically transmits Raw measurement data for continuous insights. It features smart mode threshold, triggering data transmission when RMS acceleration exceeds a user-set value on any X, Y, or Z axis, alongside smart skip threshold, which intelligently skips sending data a specified number of times when vibrations fall below the threshold, optimizing efficiency, paired with 24/7 sampling to capture spontaneous issues—ideal for intermittent machine operation—ensuring real-time adaptability and comprehensive monitoring with precision.
  • msg_type
    • The message type:
      • regular – data sent over regular intervals
      • motion – data triggered by the vibration crossing a predefined threshold
  • s1_odr
    •  This is the Vibration sample rate in Hz
  • ts1_temperature
    •  The temperature measured by the temperature sensor in Celsius
  • x1_rms_ACC_G
    •  The RMS Acceleration over the X axis in G
  • x1_max_ACC_G
    •  The MAX Acceleration over the X axis in G
  • x1_velocity_mm_sec
    •  The Velocity over the X axis in mm/sec
  • x1_displacement_mm
    •  The Displacement over the X axis in mm
  • x1_peak_one_Hz
    •  The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
  • x1_peak_two_Hz
    •  The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
  • x1_peak_three_Hz
    •  The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
  • y1_rms_ACC_G
    •  The RMS Acceleration over the Y axis in G
  • y1_max_ACC_G
    •  The MAX Acceleration over the Y axis in G
  • y1_velocity_mm_sec
    •  The Velocity over the Y axis in mm/sec
  • y1_displacement_mm
    •  The Displacement over the Y axis in mm
  • y1_peak_one_Hz
    •  The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
  • y1_peak_two_Hz
    •  The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
  • y1_peak_three_Hz
    •  The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
  • z1_rms_ACC_G
    •  The RMS Acceleration over the Z axis in G
  • z1_max_ACC_G
    •  The MAX Acceleration over the Z axis in G
  • z1_velocity_mm_sec
    •  The Velocity over the Z axis in mm/sec
  • z1_displacement_mm
    •  The Displacement over the Z axis in mm
  • z1_peak_one_Hz
    •  The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
  • z1_peak_two_Hz
    •  The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
  • z1_peak_three_Hz
    •  The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
  • rpm_1
    • The rate of rotation of the machine in revolutions per minute
  • s2_odr
  • s2_temperature
  • x2_rms_ACC_G
  • x2_max_ACC_G
  • x2_velocity_mm_sec
  • x2_displacement_mm
  • x2_peak_one_Hz
  • x2_peak_two_Hz
  • x2_peak_three_Hz
  • y2_rms_ACC_G
  • y2_max_ACC_G
  • y2_velocity_mm_sec
  • y2_displacement_mm
  • y2_peak_one_Hz
  • y2_peak_two_Hz
  • y2_peak_three_Hz
  • z2_rms_ACC_G
  • z2_max_ACC_G
  • z2_velocity_mm_sec
  • z2_displacement_mm
  • z2_peak_one_Hz
  • z2_peak_two_Hz
  • z2_peak_three_Hz
  • rpm_2
Wireless Gateway Sensor Data Message (Raw/time domain)
  • nodeID
  • firmware
  • battery
  • battery_percent
  • counter
  • sensor_type
  • sensor_data
  • sensor_name
  • type
  • addr
  • received
  • original
  • modem_mac
  "payload": {
    "nodeId": 0,
    "firmware": 14,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 111,
    "sensor_data": {
        "mode":1,
        "probe": 1,
        "time_id":"0:20",
        "mac_address": "00:13:a2:00:42:53:64:53",
        "fsr": "8g",
        "odr": 827,
        "device_temp": 19.56,
        "fft_confidence": "100%",
        "data": {
           "x": [-0.07, 0.1, ...],
           "y": [0, 0, ...],
           "z": [0, 0, ...]
    "original": {...},
  • mode
  • msg_type
    • The message type:
  • probe
    • this value indicates which probe this reading was taken from
  • time_id
    •  The time when the reading was taken
  • mac_address
    •  The MAC address of the device (used to identify it on the network)
  • fsr
    • Full Scale Range of the sensor
  • odr
  • device_temp
    • The measured temperature in Celsius
  • fft_confidence
    • Definition: fft_confidence is a percentage metric that represents the completeness and integrity of a reconstructed Time-Domain data message. Because Time-Domain data is too large to fit into a single wireless transmission, the sensor fragments the data into multiple sequential packets. This value indicates how many of those packets were successfully received by the gateway versus how many were lost due to wireless interference.
      How it Works: Each transmission includes a “Current Packet” index and a “Total Expected Packets” count. The NCD Library waits for the final packet (where Current = Total) to trigger the reconstruction of the full data message.
      • If all packets are received, the confidence is 100%.
      • If packets are missed during transmission, the library still builds the message using the available data once the final packet arrives, but the confidence value will be lower.
      Calculation: fft_confidence = Total Packets Received \ Total Packets Expected * 100
      Why it Matters:
      Data Reliability: A high confidence value (90–100%) ensures that the resulting FFT analysis is based on a nearly complete dataset.
      Troubleshooting: A consistently low confidence value (e.g., 40%) suggests significant wireless interference or that the sensor is too far from the gateway, which may result in inaccurate or “gapped” vibration analysis.
  • data
    • data over each of the enabled axis in “g”. You will have multiple samples here depending on the chosen rate
Wireless Gateway RUN Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
    • Timestamp of the message
  "topic": "sensor_mode",
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "RUN",
    "lastHeard": 1721424191056
  "time": 1721424191056,
  "_msgid": "f41dad7923ece27c"
Wireless Gateway PGM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "PGM",
    "lastHeard": 1721424000999
  "time": 1721424000999,
  "_msgid": "36ac745134de68ee"
Wireless Gateway ACK Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "ACK",
    "lastHeard": 1721424002052
  "time": 1721424002052,
  "_msgid": "6eeb3e249c6b583d"
Wireless Gateway PUM Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "PUM",
    "lastHeard": 1721424000789
  "time": 1721424000789,
  "_msgid": "e361ba7bdfe0bc4b"
Wireless Gateway FLY Message
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  • reported_config
    • Contained the reported configuration parameter values
  • reported_config.firmware
    • Displays the current firmware version installed on the sensor
  • reported_config.destination_address
    • Shows the current destination address configured on the sensor. The default setting is broadcast mode “00:00:FF:FF”
  • reported_config.mode
    • Indicates the current operating mode configured on the sensor
  • reported_config.odr_1
    • Specifies the current number of samples the device captures per second for the 1st channel
  • reported_config.odr_2
    • Specifies the current number of samples the device captures per second for the 2nd channel
  • reported_config.sampling_duration_1
    • Reflects the amount of time over which the sample is taken for the 1st channel
  • reported_config.sampling_duration_2
    • Reflects the amount of time over which the sample is taken for the 2nd channel
  • reported_config.filter_status
    • Indicates whether the sensor’s filters are currently enabled or disabled
  • reported_config.lpf_coeff_1
    • Displays the current value assigned to the Low Pass Filter foe the 1st channel
  • reported_config.lpf_coeff_2
    • Displays the current value assigned to the Low Pass Filter foe the 2nd channel
  • reported_config.lpf_freq_1
    • Shows the current frequency for the Low Pass Filter, calculated as Frequency = ODR / Low Pass Coefficient, for the 1st channel
  • reported_config.lpf_freq_2
    • Shows the current frequency for the Low Pass Filter, calculated as Frequency = ODR / Low Pass Coefficient, for the 2nd channel
  • reported_config.hpf_coeff_1
    • Displays the current value assigned to the High Pass Filter for the 1st channel
  • reported_config.hpf_coeff_2
    • Displays the current value assigned to the High Pass Filter for the 2nd channel
  • reported_config.hpf_freq_1
    • Shows the current frequency for the High Pass Filter, calculated as Frequency = ODR / High Pass Coefficient for the 1st channel
  • reported_config.hpf_freq_2
    • Shows the current frequency for the High Pass Filter, calculated as Frequency = ODR / High Pass Coefficient for the 2nd channel
  • reported_config.sampling_interval
    • Indicates how often, in minutes, the sensor wirelessly transmits measurement data
  • reported_config.on_request_timeout
    • Specifies how long, in seconds, the device remains active while awaiting a Raw data request command before returning to sleep mode
  • reported_config.deadband
    • Represents the minimum acceleration threshold required for the sensor to register a measurement
  • reported_config.payload_length
    • Indicates the maximum size of the data payload (in bytes) transmitted by the sensor for Raw data transmissions
  • reported_config.fsr
    • Shows the maximum range of acceleration the device is capable of measuring
  • reported_config.rpm_compute_status
    • Indicates whether the RPM calculation feature is enabled or disabled
  • reported_config.auto_raw_destination_address
    • Displays the current destination address for Time Domain Data transmission. The default is the broadcast address “00:00:FF:FF”
  • reported_config.auto_raw_interval
    • Specifies the frequency, in minutes, at which Time Domain Data is transmitted
  • reported_config.smart_mode_skip_count
    • Shows the number of times the sensor will skip sending data if the vibration level falls below the smart mode threshold
  • reported_config.smart_mode_acc_threshold_probe_1
    • Indicates the minimum acceleration value required to trigger data transmission in Smart Mode for the 1st channel
  • reported_config.smart_mode_acc_threshold_probe_2
    • Indicates the minimum acceleration value required to trigger data transmission in Smart Mode for the 2nd channel
  • reported_config.uptime_counter_probe_1
    • The time the device has been up data has been gathered for the 1st channel
  • reported_config.uptime_counter_probe_2
    • The time the device has been up data has been gathered for the 2nd channel
  • reported_config.hardware_id
    • This value indicates the hardware version of the device
  • reported_config.reserved
    • Refers to a value reserved for future use or internal purposes
  • reported_config.tx_lifetime_counter
    • Tracks the total number of data packets transmitted by the CPU since the device first booted
  • reported_config.machine_values
    • The Raw data the sensor reports
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "FLY",
  "reported_config": {
    "firmware": 1,
    "destination_address": "00:00:ff:ff",
    "mode": "Smart",
    "odr_1": "800Hz",
    "odr_2": "800Hz",
    "sampling_duration_1": "1000ms",
    "sampling_duration_2": "1000ms",
    "filter_status": "Enabled",
    "lpf_coeff_1": 4,
    "lpf_coeff_2": 4,
    "lpf_freq_1": "200Hz",
    "lpf_freq_2": "200Hz",
    "hpf_coeff_1": 64,
    "hpf_coeff_2": 64,
    "hpf_freq_1": "12.5Hz",
    "hpf_freq_2": "12.5Hz",
    "sampling_interval": "15 Minutes",
    "on_request_timeout": "1 Seconds",
    "deadband": "20mg",
    "payload_length": "180 Bytes",
    "fsr": "8g",
    "rpm_compute_status": "Enabled",
    "auto_raw_destination_address": "00:00:ff:ff",
    "auto_raw_interval": "disabled",
    "smart_mode_skip_count": 3,
    "smart_mode_acc_threshold_probe_1": "500mg",
    "smart_mode_acc_threshold_probe_2": "500mg",
    "uptime_counter_probe_1": "1sec",
    "uptime_counter_probe_2": "1sec",
    "hardware_id": [...],
    "reserved": [...],
    "tx_lifetime_counter": 115,
    "machine_values": {
Wireless Gateway UPTHWRN Message
An UPTHWRN message indicates that the sensor’s threshold is set too low, causing it to trigger frequently. This can lead to battery drain.
An example UPTHWRN message can be found on the right.
  • topic
  • payload
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
  • payload.lastHeard
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "UPTHWRN",
    "lastHeard": 1721424191766
  "time": 1721424191767,
  "_msgid": "5f6f01b6651b2f82"
Wireless Gateway MOFF Message
A MOFF message indicates that, after a processed data transmission, if the sensor successfully receives a smart request Raw command within the specified timeout window and the sensor detects that the vibration level is below the Acceleration Wake/Interrupt Threshold, then the sensor transmits a MOFF message instead of the requested raw data. This message confirms the sensor’s assessment that the asset is not running, as the machine is considered to be “off.”
An example MOFF message can be found on the right.
  • topic
    • Indicates the type of message this is payload. Contains the primary data of the message
  • payload.mac
  • payload.type
  • payload.nodeId
  • payload.mode
    • Indicates the current mode of the sensor
  • payload.lastHeard
  • payload.data
    • Bytes for MOFF message
  "payload": {
    "type": 111,
    "nodeId": 0,
    "mode": "MOFF",
    "lastHeard": 1721424191766,
    "status": 255,
    "data": [77,79,70,70,0]
  • topic
  • payload
  • time
  "topic": "modem_mac",
  "time": 1721424259706,
  "_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
  1. Name
  2. Serial Device*
  3. Serial Device Edit Icon
Click to enlarge
Wireless Device Nodes
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.battery_percentage
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 111,
    "sensor_data": {
        "mode":0,
        "s1_odr":"800Hz",
        "rpm_1": 167
        "s2_odr":"800Hz",
        "rpm_2": 167
    "original": {...},
  "payload": {
        "mode":0,
        "s1_odr":"800Hz",
        "rpm_1": 167
        "s2_odr":"800Hz",
        "rpm_2": 167
  "_msgid": "48e99332fc104565"
Processed Data msg.payload Breakdown
  • mode
    • The sensor works in one of 3 modes:
  • msg_type
    • The message type:
  • s1_odr
  • ts1_temperature
  • x1_rms_ACC_G
  • x1_max_ACC_G
  • x1_peak_one_Hz
  • x1_peak_two_Hz
  • x1_peak_three_Hz
  • y1_rms_ACC_G
  • y1_max_ACC_G
  • y1_peak_one_Hz
  • y1_peak_two_Hz
  • y1_peak_three_Hz
  • z1_rms_ACC_G
  • z1_max_ACC_G
  • z1_peak_one_Hz
  • z1_peak_two_Hz
  • z1_peak_three_Hz
  • rpm_1
  • s2_odr
  • s2_temperature
  • x2_rms_ACC_G
  • x2_max_ACC_G
  • x2_peak_one_Hz
  • x2_peak_two_Hz
  • x2_peak_three_Hz
  • y2_rms_ACC_G
  • y2_max_ACC_G
  • y2_peak_one_Hz
  • y2_peak_two_Hz
  • y2_peak_three_Hz
  • z2_rms_ACC_G
  • z2_max_ACC_G
  • z2_peak_one_Hz
  • z2_peak_two_Hz
  • z2_peak_three_Hz
  • rpm_2
Wireless Device Node Sensor Data Message (Raw/time domain)​
  • topic
  • data
  • data.nodeID
  • data.firmware
  • data.battery
  • data.counter
  • data.sensor_type
  • data.sensor_data
  • data.sensor_name
  • data.type
  • data.addr
  • data.received
  • data.original
  • data.modem_mac
  • payload
  • time
  "data": {
    "nodeId": 0,
    "firmware": 3,
    "battery": "3.28",
    "counter": 26,
    "sensor_type": 111,
    "sensor_data": {
        "mode":1,
        "probe": 1,
        "time_id":"0:20",
        "fsr": "8g",
        "odr": 827,
        "data": {
           "y": [0, 0, ...],
           "z": [0, 0, ...]
    "original": {...},
  "payload": {
        "mode":1,
        "probe": 1,
        "time_id":"0:20",
        "en_axis": 7,
        "fsr": "8g",
        "odr": 827,
        "data": {
           "y": [0, 0, ...],
           "z": [0, 0, ...]
Raw/time domain Data msg.payload Breakdown
  • mode
  • msg_type
    • The message type:
  • probe
  • time_id
  • mac_address
  • fsr
  • odr
  • device_temp
  • fft_confidence
      Why it Matters:
  • data
  • topic
  • payload
  • payload.x
  • time
  • addr
  "topic": "Config Results",
  "payload": {
      "sent": [...]
      "sent": [...]
      "sent": [...]
    "network_id": true,
    "reboot_sensor": {
      "sent": [...]
  "time": 1721424010563,
  "_msgid": "c29c7695c93ae747"
  • topic
  • time
  "payload": {
    "config_enter_otn_mode": true
  "time": 1721424530709,
  "_msgid": "1014b31e53e5c7ac"
  • Name
    • Arbitrary name of this node
  • Serial Device*
    • For More information on the submenu the edit icon brings up see section ncd-gateway-config Nodes
  • Serial Device for Config
  • Mac Address
  • Sensor Type*
  • Auto Config
  • OTF Config
    • Checking the box next to this field AND having Auto Config checked tells Node-Red that the sensor(s) corresponding to this Wireless Device node should be configured when a FLY message is detected
*Required
General Sensor Configurations
  • Wait for Network Formation
  • Destination Address
  • Network ID
  • Node ID
  • Power
  • Retries
Probe 1: Set Acceleration Wake/Interrupt Threshold
Set a breakpoint for sensor to wake up and broadcast readings. This is an interrupt based configuration ideal for devices with minimal workload/uptime.
This will be an integer value that increments the interrupt threshold by 50mg. A value of 1 means turn the wake the sensor if acceleration is above 50mg, 2 means 100mg, etc.
Valid Input Range: 0 – 40
A value of 0 will disable this feature.
Probe 2: Set Acceleration Wake/Interrupt Threshold
Set On Request Timeout in seconds
This is how long the device will remain active and wait for a RAW data request command, before going inactive again.
Set RTC
Set the value for the Real Time Clock.
Full Scale Range
How large of a range the device can measure acceleration in. For example +/- 8g would mean that it would measure at most up to 8g and down to -8g.
Set Dead Band in mg
This value determines the minimum acceleration would have to be for it to be registered as a measurement. Values below the threshold it  would be perceived as 0.
For example, a value of 10 would mean that vibrations below 10mg would be considered as 0.
Payload Length
This is the max size of the data payload the sensor sends when it sends time domain data messages.
Probe 1: Output Data Rate (ODR)
The data rate of the output signal. This would determine how many samples the output data has, which is directly related to the highest frequency components that can be measured. In accordance with the Nyquist equation:
f_max = ODR/2.56 Hz
Sample Rate (ODR)Sample Duration Max
100Hz80sec
200Hz40sec
400Hz20sec
800Hz10sec
1600Hz5sec
3200Hz2.5sec
6400Hz1.26sec
12800Hz0.63sec
25600Hz0.31sec
Probe 2: Output Data Rate (ODR)
f_max = ODR/2.56 Hz
200Hz40Sec
400Hz20sec
800Hz10sec
1600Hz5sec
3200Hz2.5sec
6400Hz1.26sec
12800Hz0.63sec
25600Hz0.31sec
Probe 1: Set Sampling Duration
This determines the amount of time over which the samples are taken for the 1st channel.
Probe 2: Set Sampling Duration
This determines the amount of time over which the samples are taken for the 2nd channel.
Probe 1: Set Low Pass Filter
This setting will set the LPF freq to ODR divided by Selected Value
Example: ODR = 800 and Filter Coefficient = 64
LPF freq = 800/64 = 12.5Hz
Probe 2: Set Low Pass Filter
Probe 1: Set High Pass Filter
This setting will set the HPF freq to ODR divided by Selected Value
HPF freq = 800/64 = 12.5Hz
Probe 2: Set High Pass Filter
Mode
Select the mode of operation:
  • Processed – only processed data is sent, as in the example in this document
  • Raw – full time domain data is sent (very large not recommended for prolonged periods)
  • Processed + Raw on demand – same as the first mode, but with the option to generate a Raw packet on demand
  • Smart – in this mode the sensor automatically samples and sends a data packet if the vibration crosses a defined threshold level
Sampling Interval
How often will the sensor transmit measurement data wirelessly.
Possible values:
  • 1 minute
  • 5 minutes
  • 10 minutes (default)
  • 20 minutes
  • 30 minutes
  • 60 minutes
  • 120 minutes
  • 180 minutes
When the measured vibration is above a threshold value we can deduct that the machine is on and start a counter to measure the uptime. This setting will zero out the uptime value.
Set Auto Raw Interval
This interval is multiplied by the sample interval to determine how often the sensor should automatically transmit raw data. If the value is set to 1 and the sample interval is 30 minutes, Raw data will be sent every 30 minutes. If the value is set to 5, Raw data will be sent every 150 minutes.
Set Auto Raw Destination Address
This is the address where the Auto Raw data will be sent, we recommend setting this to your gateway address.
For example: 41D5EC37
You can find more info in the modem_mac message section.
Probe 1: Set Smart Mode Threshold
If RMS acceleration is above this in any axis, it will send data. This will be an integer value that increments the interrupt threshold by 50 mg. A value of 1 means to wake the sensor if acceleration is above 50 mg, 2 means 100 mg, etc.
Probe 2: Set Smart Mode Threshold
Set Smart Mode Skip Interval
Sensor will skip sending data this many times if vibration is below the smart threshold.
Set FLY Interval
Set the interval at which the sensor will send FLY packets. FLY packets are what allows Node-Red to reconfigure the sensor so this determines how often the sensor should check in for updated configurations.
Enable RPM Calculate Status
When a measurement sample is taken you can choose to not calculate the RPM, this will shorten the measurement time and save on battery.
Set Max Raw Sample
Defines the maximum number of samples the sensor captures for time-domain data, by reducing the sample duration.
Options:
– 1024 Samples.
– 2048 Samples.
– 4096 Samples.
– 6400 Samples.
– 8100 Samples.
Once motion is detected, the sensor will wait for the configured duration before sampling and computing vibration data.
1= 50msec, 2= 100msec, 100= 5000msec (5sec)
Default value: 100 (5000msec)
Set Max Number Motion Tx Per Interval​
Set Number of times it will send data due to motion triggers.
Default value: 1
Manual Configuration Process
OTF/Automatic Configuration
Check Sensor Power
Factory Reset Sensor
  1. Factory Reset the Sensor
    • Factory reset by pressing and release the RESET button, wait for a second, then press and hold the CONFIGURATION button, hold the CONFIGURATION button for more than 15 seconds, release CONFIGURATION button, then Wait for 3-5 seconds, finally press and release the RESET button.
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
  2. Import
  5. Expand Type 111 – Two Channel Vibration Plus Gen4
  8. Click on Import
Example Flows
