Temperature sensors are vital instruments for industrial applications as they provide a reliable and accurate method of measuring and monitoring temperatures. Temperature sensors are used to maintain a safe and efficient environment in a wide range of industrial applications, from food processing to HVAC systems, manufacturing, automotive, power plants, chemical processing, refineries, the pharmaceutical industry, and more.
Leveraging temperature sensors in industrial applications are necessary for peak performance and predictive maintenance. These sensors are critical in controlling the environment for guaranteeing safety, precision, and efficiency.
According to Senseye’s 2021 report, The True Cost Of Downtime, large industrial facilities lose 3.3 million hours a year, which equates to almost $1 Trillion, to machine failures. Risk remains intrinsically linked to maintenance failures due to using traditional maintenance models rather than predictive analytics to understand variables and patterns.
In 2021, several incidents of excessive heat impacted equipment, causing power outages in Denver and resulting in widespread disruption.
Now, easy-to-deploy IoT sensors are available with capabilities in the form of condition-based, machine learning-infused predictive maintenance, to address downtime challenges.
For example, NCD’s Industrial IoT Wireless Predictive Maintenance Sensor samples vibration, acceleration, velocity, displacement, frequency, RMS current, and temperature data wirelessly up to a two-mile range using a wireless mesh networking architecture.
This IoT Preventative Monitoring Sensor helps avoid costly repairs, machine downtime, and unexpected system failures by monitoring various parameters such as temperature, pressure, vibration, and flow rate. It can alert operators when readings exceed thresholds and can also provide real-time data analysis to enable proactive maintenance and optimize performance.
