- Device Overview
- Opening up the Sensor
- Hardware Controls
- Wireless Gateway Nodes
- Wireless Gateway Node Statuses
- Wireless Gateway Node Messages
- Wireless Gateway Sensor Data Message (Processed)
- Wireless Gateway Sensor Data Message (Raw/time domain)
- Wireless Gateway RUN Message
- Wireless Gateway PGM Message
- Wireless Gateway ACK Message
- Wireless Gateway PUM Message
- Wireless Gateway FLY Message
- Wireless Gateway UPTHWRN Message
- Wireless Gateway MOFF Message
- Wireless Gateway modem_mac Message
- Wireless Gateway Node Configuration
- Wireless Device Nodes
- Examples
Introducing NCD’s Explore the Standalone Smart Vibration Sensor Gen4 Capabilities. Lightweight rugged and reliable for accurate asset monitoring and boasting up to a 2-mile range using a wireless mesh networking architecture & Incorporating a 16-bit Vibration and integrated Temperature sensor.
This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
- Small & lightweight for ease of installation.
- IP67 rated sealed enclosure for dust &
moisture protection. - D-cell battery for long-lasting operation.
- A versatile user-configurable sample rate for slow or fast-running machines
- Integrated temperature sensor in base.
- In-Built Machine Learning optimizes power consumption.
- Asset On-Time Calculator automatically tracks operational status.
- Hardware Accelerator enhances vibration sampling accuracy.
- Configurable Sample Rate – 100Hz to 25.6KHz
- Available Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
- Supports MESH networking via DigiMesh
- Fully open Node-RED library for configuration and data ingestion
Device and Tooling
We recommend using the special Spanner Wrench we offer in our store, specifically designed to easily take apart the Standalone Smart Vibration Sensor Gen4.
It is possible to open it up using alternative tooling, however for best results we recommend using our Spanner Wrench.
Magnetic Attachment Base
Unscrewing the Sensor Base
Once you have removed the magnetic attachment base, you will expose the two indents that are used as mounting points for the spanner wrench. Insert is as per the image (adjusting it as needed to fit both holes) and rotate it anti-clockwise. You need to firmly grip the other end of the sensor in order for the bottom lid where the spanner wrench is mounted to start unscrewing. Once you have made a few rotations you should be able to use your hand instead of the spanner wrench to quickly unscrew it.
Separating the Enclosure from the Base
The base you just unscrewed is actually the portion of the device the electronics is attached to. If you pull the top portion (gripping the device around the plastic, orange ring) and the sensor base you will separate the cylindrical part of the enclosure and the base with the electronics attached to it.
At this point you will be able to access the physical buttons, board, RF module, antenna and battery.
Refer to the next section for a detailed image and explanation of the components.
Components Breakdown
Disconnecting the Battery
You should not need to replace the battery, for years. However, in case you need to disconnect it for some reason you can do this via the connector on the top of the PCB (refer to the image).
The connector is very solidly inserted, the best way to separate it is to pull on the wire itself, not the connector head, gently wiggling it out.
Hardware Controls
Powering on the sensor
The device comes with the battery installed and connected, it is powered on and already broadcasting with the default network settings.
The sensor comes in Always on mode and Always sampling mode, meaning it is constantly measuring data. This is useful in case where machines operate for brief intermittent periods or where you have a sudden increase in vibration.
This device can be set up to operate in a special Smart mode, where the device will learn the vibrational pattern of the machine in nominal operation and will only measure/transmit data if the vibration is above a user defined vibration level. It will periodically wake up and check and only transmit if need be. It will also send a sample every 10 wake-up periods, as a keep-alive more than a vibration measurement frame.
RESET / CONFIGURE the sensor
Magnetic RESET Switch
The Magnetic RESET Switch will power cycle the sensor. When the sensor first powers up it will send a sensor_mode message with the mode of RUN.
Magnetic CFG Switch
Magnetic CFG Switch serves two functions.
Hardware Mode Selection
Run Mode is the default state of the sensor when powered up. No hardware interaction is necessary to enter this state other than power. Triggering the Magnetic RESET Switch will restart the sensor and put it in the RUN Mode state if no other switches are triggered.
You can enter in this mode by briefly triggering the Magnetic RESET Switch and then immediately triggering and holding the Magnetic CFG Switch for ~5 seconds. Refer to the graph below for the precise timing of the Magnetic CFG timings.
Factory Default/Reset
Using Buttons
- Press and release the RESET button
- Wait for a second, then press and hold the CONFIGURATION button
- Hold the CONFIGURATION button for about 20 seconds
- Release the CONFIGURATION button
- Wait for 3-5 seconds
- Press and release the RESET button.
Using Magnetic Switches
- Move a magnet near the RESET switch and then move it away
- Wait for 1 second
- Hold the magnet near the CONFIGURATION switch for about 20 seconds
- Move the Magnet away from the CONFIGURATION switch
Timing Using Buttons
- Configuration Button Pressed and held 1 second after Reset for:
- < 5 second – device starts normally in RUN Mode
- 5 to 15 seconds – device goes into Configuration Mode
- Move a magnet near the Reset switch and then move it away
- Hold the magnet near the Configuration Switch for:
- Move the Magnet away from the Configuration Switch
Default Configuration
| Parameter | Default Value | Unit | Note |
| Output Data Rate | 12800 | Hz | |
| Sampling Duration | 20 (1000msec) | msec | 20*50 = 1000msec *Sampling Duration depends on the ODR value |
| Low Pass Filter | 4 | ||
| High Pass Filter | 2048 | ||
| Full Scale Range | 8 | g | |
| Sampling Interval | 30 | min | |
| Filter Status | Enabled | ||
| Operation Mode | 3 - Smart | ||
| Data on Request Timeout | 1 | sec | |
| Acceleration Dead Band | 20 | mg | |
| Acceleration Wake/Interrupt Threshold | 10 (500mg) | mg | 10*50 = 500mg |
| LED Accelerometer Threshold | 10 (500mg) | mg | 10*50 = 500mg |
| LED Velocity Threshold | 5 | mm/sec | |
| LED Alert Mode | Acceleration | ||
| Payload Length | 180 | bytes | |
| Auto Raw Interval | Disabled | ||
| Auto Raw Destination Address | 0000FFFF | hex | |
| Smart Mode Skip Interval | 3 | ||
| FLY Interval | 60 | min | |
| RPM Calculate Status | Enabled | ||
| Max Raw Sample | 4096 | ||
| Real-Time Clock | Disabled | ||
| Clear Probe Uptimers | Disabled | ||
| Smart Mode Threshold | 10 (500mg) | mg | 10*50 = 500mg |
| Set Motion to Sampling Delay | 100 (5000msec) | msec | 100*50 = 5000msec *Apply for Firmware v6+ |
| Set Max Number Motion Tx Per Interval | 1 | *Apply for Firmware v6+ |
Ready State
Configuring State
Failed to Connect State
Connecting State
No State
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- sensor_name
- type
- addr
- received
- original
- modem_mac
"topic": "sensor_data",
"payload": {
"nodeId": 0,
"firmware": 14,
"battery": "3.28",
"battery_percent": "98.56",
"counter": 26,
"sensor_type": 114,
"sensor_data": {
"mode":0,
"msg_type": "regular",
"odr":"800Hz",
"temperature":23.67,
"x_rms_ACC_G": 0.001,
"x_max_ACC_G": 0.002,
"x_velocity_mm_sec": 0.03,
"x_displacement_mm": 0.04,
"x_peak_one_Hz": 5,
"x_peak_two_Hz": 6,
"x_peak_three_Hz": 7,
"y_rms_ACC_G": 0.008,
"y_max_ACC_G": 0.009,
"y_velocity_mm_sec": 0.1,
"y_displacement_mm": 0.11,
"y_peak_one_Hz": 12,
"y_peak_two_Hz": 13,
"y_peak_three_Hz": 14,
"z_rms_ACC_G": 0.015,
"z_max_ACC_G": 0.162,
"z_velocity_mm_sec": 1.63,
"z_displacement_mm": 1.64,
"z_peak_one_Hz": 165,
"z_peak_two_Hz": 166,
"z_peak_three_Hz": 256,
"rpm": 167
"sensor_name": "Standalone Smart Vibration Sensor Gen4",
"type": "sensor_data",
"received": 1721424191583,
"original": {...},
"time": 1721424191584,
"_msgid": "d7f3341ef39225df"
Processed msg.payload.sensor_data Breakdown
- mode
- The sensor works in one of 4 modes:
- 0 – Processed – FFT is performed by the sensor and the measurement data is presented in condensed form (both time and frequency parameters)
- 1 – Raw/Time domain – the Raw/ time domain data is gathered and transmitted and it is up to the client to perform the FFT if needed. This is a very large data packet.
- 2 – On demand – sending Processed data regularly, with the option to request a RAW data packet
- 3 – Smart – a cutting-edge operational setting. In this mode, the sensor delivers Processed Data (Overall Data) at user-defined intervals, with a Time Domain on Request option for requesting detailed Raw data packets, complemented by an Auto Raw Interval that dictates how often the sensor automatically transmits Raw measurement data for continuous insights. It features smart mode threshold, triggering data transmission when RMS acceleration exceeds a user-set value on any X, Y, or Z axis, alongside smart skip threshold, which intelligently skips sending data a specified number of times when vibrations fall below the threshold, optimizing efficiency, paired with 24/7 sampling to capture spontaneous issues—ideal for intermittent machine operation—ensuring real-time adaptability and comprehensive monitoring with precision.
- msg_type
- The message type:
- regular – data sent at regular interval
- motion – data triggered by the vibration crossing a predefined threshold
- The message type:
- odr
- This is the Vibration sample rate in Hz
- temperature
- The temperature measured by the temperature sensor in Celsius
- x_rms_ACC_G
- The RMS Acceleration over the X axis in G
- x_max_ACC_G
- The MAX Acceleration over the X axis in G
- x_velocity_mm_sec
- The Velocity over the X axis in mm/sec
- x_displacement_mm
- The Displacement over the X axis in mm
- x_peak_one_Hz
- The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
- x_peak_two_Hz
- The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
- x_peak_three_Hz
- The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the X axis
- y_rms_ACC_G
- The RMS Acceleration over the Y axis in G
- y_max_ACC_G
- The MAX Acceleration over the Y axis in G
- y_velocity_mm_sec
- The Velocity over the Y axis in mm/sec
- y_displacement_mm
- The Displacement over the Y axis in mm
- y_peak_one_Hz
- The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
- y_peak_two_Hz
- The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
- y_peak_three_Hz
- The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the Y axis
- z_rms_ACC_G
- The RMS Acceleration over the Z axis in G
- z_max_ACC_G
- The MAX Acceleration over the Z axis in G
- z_velocity_mm_sec
- The Velocity over the Z axis in mm/sec
- z_displacement_mm
- The Displacement over the Z axis in mm
- z_peak_one_Hz
- The frequency at which the First Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
- z_peak_two_Hz
- The frequency at which the Second Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
- z_peak_three_Hz
- The frequency at which the Third Highest Energy/ Amplitude Peak occurs in Hz, over the Z axis
- rpm
- The rate of rotation of the machine in revolutions per minute
- nodeID
- firmware
- battery
- battery_percent
- counter
- sensor_type
- sensor_data
- See section Raw/time domain Data msg.payload.sensor_data Breakdown for more information
- sensor_name
- type
- addr
- received
- original
- modem_mac
"payload": {
"nodeId": 0,
"firmware": 14,
"battery": "3.28",
"counter": 26,
"sensor_type": 114,
"sensor_data": {
"mode":1,
"time_id":"0:20",
"mac_address": "00:13:a2:00:42:53:64:53",
"en_axis": 7,
"fsr": "8g",
"odr": 827,
"device_temp": 19.56,
"fft_confidence": "100%",
"data": {
"x": [-0.07, 0.1, ...],
"y": [0, 0, ...],
"z": [0, 0, ...]
"original": {...},
Raw/time domain msg.payload.sensor_data Breakdown
- mode
- 1 – Raw/time domain – the Raw/time domain data is gathered and transmitted and it is up to the client to perform the FFT if needed. This is a very large data packet.
- 2 – On demand, sending Processed data regularly, with the option to request a Raw/time domain data packet
- msg_type
- The message type:
- The message type:
- time_id
- The time when the reading was taken
- mac_address
- The MAC address of the device (used to identify it on the network)
- en_axis
- Number of enabled axis:
- 1 – X only
- 3 – X and Y
- 3 – X, Y, and Z
- fsr
- Full Scale Range of the sensor
- odr
- device_temp
- The measured temperature in Celsius
- fft_confidence
- Definition: fft_confidence is a percentage metric that represents the completeness and integrity of a reconstructed Time-Domain data message. Because Time-Domain data is too large to fit into a single wireless transmission, the sensor fragments the data into multiple sequential packets. This value indicates how many of those packets were successfully received by the gateway versus how many were lost due to wireless interference.
How it Works: Each transmission includes a “Current Packet” index and a “Total Expected Packets” count. The NCD Library waits for the final packet (where Current = Total) to trigger the reconstruction of the full data message.
- If all packets are received, the confidence is 100%.
- If packets are missed during transmission, the library still builds the message using the available data once the final packet arrives, but the confidence value will be lower.
Calculation: fft_confidence = Total Packets Received \ Total Packets Expected * 100
Why it Matters:
Data Reliability: A high confidence value (90–100%) ensures that the resulting FFT analysis is based on a nearly complete dataset.
Troubleshooting: A consistently low confidence value (e.g., 40%) suggests significant wireless interference or that the sensor is too far from the gateway, which may result in inaccurate or “gapped” vibration analysis.
- data
- data over each of the enabled axis in “g”. You will have multiple samples here depending on the chosen rate
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- Timestamp of the message
"topic": "sensor_mode",
"payload": {
"type": 114,
"nodeId": 0,
"mode": "RUN",
"lastHeard": 1721424191056
"time": 1721424191056,
"_msgid": "f41dad7923ece27c"
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 114,
"nodeId": 0,
"mode": "PGM",
"lastHeard": 1721424000999
"time": 1721424000999,
"_msgid": "36ac745134de68ee"
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 114,
"nodeId": 0,
"mode": "ACK",
"lastHeard": 1721424002052
"time": 1721424002052,
"_msgid": "6eeb3e249c6b583d"
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 110,
"nodeId": 0,
"mode": "PUM",
"lastHeard": 1721424000789
"time": 1721424000789,
"_msgid": "e361ba7bdfe0bc4b"
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
- reported_config
- Contained the reported configuration parameter values
- reported_config.firmware
- Displays the current firmware version installed on the sensor
- reported_config.destination_address
- Shows the current destination address configured on the sensor. The default setting is broadcast mode “00:00:FF:FF”
- reported_config.mode
- Indicates the current operating mode configured on the sensor
- reported_config.odr
- Specifies the current number of samples the device captures per second
- reported_config.sampling_duration
- Reflects the amount of time over which the sample is taken
- reported_config.filter_status
- Indicates whether the sensor’s filters are currently enabled or disabled
- reported_config.lpf_coeff
- Displays the current value assigned to the Low Pass Filter
- reported_config.lpf_freq
- Shows the current frequency for the Low Pass Filter, calculated as Frequency = ODR / Low Pass Coefficient
- reported_config.hpf_coeff
- Displays the current value assigned to the High Pass Filter
- reported_config.hpf_freq
- Shows the current frequency for the High Pass Filter, calculated as Frequency = ODR / High Pass Coefficient
- reported_config.sampling_interval
- Indicates how often, in minutes, the sensor wirelessly transmits measurement data
- reported_config.on_request_timeout
- Specifies how long, in seconds, the device remains active while awaiting a Raw data request command before returning to sleep mode
- reported_config.deadband
- Represents the minimum acceleration threshold required for the sensor to register a measurement
- reported_config.payload_length
- Indicates the size of the data payload (in bytes) transmitted by the sensor with each message
- reported_config.fsr
- Shows the maximum range of acceleration the device is capable of measuring
- reported_config.rpm_compute_status
- Indicates whether the RPM calculation feature is enabled or disabled
- reported_config.auto_raw_destination_address
- Displays the current destination address for Time Domain Data transmission. The default is the broadcast address “00:00:FF:FF”
- reported_config.auto_raw_interval
- Specifies the frequency, in minutes, at which Time Domain Data is transmitted
- reported_config.smart_mode_skip_count
- Shows the number of times the sensor will skip sending data if the vibration level falls below the smart mode threshold
- reported_config.smart_mode_acc_threshold
- Indicates the minimum acceleration value required to trigger data transmission in Smart Mode
- hardware_id
- This value indicates the hardware version of the device
- reserved
- Refers to a value reserved for future use or internal purposes
- reserved.tx_lifetime_counter
- Tracks the total number of data packets transmitted by the CPU since the device first booted
- machine_values
- The Raw data the sensor reports
"payload": {
"type": 114,
"nodeId": 0,
"mode": "FLY",
"reported_config": {
"firmware": 1,
"destination_address": "00:00:ff:ff",
"mode": "Smart",
"odr": "800Hz",
"sampling_duration": "1000ms",
"filter_status": "Enabled",
"lpf_coeff": 4,
"lpf_freq": "200Hz",
"hpf_coeff": 64,
"hpf_freq": "12.5Hz",
"sampling_interval": "15 Minutes",
"on_request_timeout": "1 Seconds",
"deadband": "20mg",
"payload_length": "180 Bytes",
"fsr": "8g",
"rpm_compute_status": "Enabled",
"auto_raw_destination_address": "00:00:ff:ff",
"auto_raw_interval": "disabled",
"smart_mode_skip_count": 3,
"smart_mode_acc_threshold": "500mg",
"uptime_counter": "1sec",
"hardware_id": [...],
"reserved": [...],
"tx_lifetime_counter": 115,
"machine_values": {
An UPTHWRN message indicates that the sensor’s threshold is set too low, causing it to trigger frequently. This can lead to battery drain.
An example UPTHWRN message can be found on the right.
- topic
- payload
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- payload.lastHeard
"payload": {
"type": 114,
"nodeId": 0,
"mode": "UPTHWRN",
"lastHeard": 1721424191766
"time": 1721424191767,
"_msgid": "5f6f01b6651b2f82"
A MOFF message indicates that, after a processed data transmission, if the sensor successfully receives a smart request Raw command within the specified timeout window and the sensor detects that the vibration level is below the Acceleration Wake/Interrupt Threshold, then the sensor transmits a MOFF message instead of the requested raw data. This message confirms the sensor’s assessment that the asset is not running, as the machine is considered to be “off.”
An example MOFF message can be found on the right.
- topic
- Indicates the type of message this is payload. Contains the primary data of the message
- payload.mac
- payload.type
- payload.nodeId
- payload.mode
- Indicates the current mode of the sensor
- payload.lastHeard
- payload.data
- Bytes for MOFF message
"payload": {
"type": 114,
"nodeId": 0,
"mode": "MOFF",
"lastHeard": 1721424191766,
"status": 255,
"data": [77,79,70,70,0]
- topic
- payload
- time
"topic": "modem_mac",
"time": 1721424259706,
"_msgid": "83ad39df1328dea7"
Wireless Gateway Edit Pane
- Name
- Serial Device*
- Serial Device Edit Icon
Wireless Device Node Statuses
Wireless Device Running Mode
Wireless Device No Mode
Wireless Device FLY Mode
Wireless Device Config Mode
Wireless Device Node Messages
Wireless Device Node Sensor Data Message (Processed)
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.battery_percentage
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 3,
"battery": "3.28",
"counter": 26,
"sensor_type": 114,
"sensor_data": {
"mode":0,
"odr":"800Hz",
"x_peak_one_Hz": 5,
"x_peak_two_Hz": 6,
"rpm": 167
"original": {...},
"payload": {
"mode":0,
"odr":"800Hz",
"x_peak_one_Hz": 5,
"x_peak_two_Hz": 6,
"rpm": 167
"_msgid": "48e99332fc104565"
Processed Data msg.payload Breakdown
- mode
- The sensor works in one of 3 modes:
- 1 – Raw/time domain – the Raw/time domain domain data is gathered and transmitted and it is up to the client to perform the FFT if needed. This is a very large data packet.
- 2 – On demand – sending Processed data regularly, with the option to request a Raw/time domain data packet
- 3 – Smart – cutting-edge operational setting. In this mode, the sensor delivers Processed Data (Overall Data) at user-defined intervals, with a Time Domain on Request option for requesting detailed Raw data packets, complemented by an Auto Raw Interval that dictates how often the sensor automatically transmits Raw measurement data for continuous insights. It features smart mode threshold, triggering data transmission when RMS acceleration exceeds a user-set value on any X, Y, or Z axis, alongside smart skip threshold, which intelligently skips sending data a specified number of times when vibrations fall below the threshold, optimizing efficiency, paired with 24/7 sampling to capture spontaneous issues—ideal for intermittent machine operation—ensuring real-time adaptability and comprehensive monitoring with precision.
- msg_type
- The message type:
- The message type:
- odr
- temperature
- x_rms_ACC_G
- x_max_ACC_G
- x_velocity_mm_sec
- x_displacement_mm
- x_peak_one_Hz
- x_peak_two_Hz
- x_peak_three_Hz
- y_rms_ACC_G
- y_max_ACC_G
- y_velocity_mm_sec
- y_displacement_mm
- y_peak_one_Hz
- y_peak_two_Hz
- y_peak_three_Hz
- z_rms_ACC_G
- z_max_ACC_G
- z_velocity_mm_sec
- z_displacement_mm
- z_peak_one_Hz
- z_peak_two_Hz
- z_peak_three_Hz
- rpm
Wireless Device Node Sensor Data Message (Raw/time domain)
- topic
- data
- data.nodeID
- data.firmware
- data.battery
- data.counter
- data.sensor_type
- data.sensor_data
- data.sensor_name
- data.type
- data.addr
- data.received
- data.original
- data.modem_mac
- payload
- time
"data": {
"nodeId": 0,
"firmware": 14,
"battery": "3.28",
"counter": 26,
"sensor_type": 114,
"sensor_data": {
"mode":1,
"time_id":"0:20",
"en_axis": 7,
"fsr": "8g",
"odr": 827,
"data": {
"y": [0, 0, ...],
"z": [0, 0, ...]
"original": {...},
"payload": {
"mode":1,
"time_id":"0:20",
"en_axis": 7,
"fsr": "8g",
"odr": 827,
"data": {
"y": [0, 0, ...],
"z": [0, 0, ...]
Raw/time domain msg.payload Breakdown
- mode
- 2 – On demand, sending Processed data regularly, with the option to request a RAW data packet
- msg_type
- The message type:
- The message type:
- time_id
- mac_address
- en_axis
- 1 – X only
- 3 – X and Y
- 3 – X, Y, and Z
- fsr
- odr
- device_temp
- fft_confidence
Why it Matters:
- data
- topic
- payload
- payload.x
- time
- addr
"topic": "Config Results",
"payload": {
"sent": [...]
"sent": [...]
"sent": [...]
"network_id": true,
"reboot_sensor": {
"sent": [...]
"time": 1721424010563,
"_msgid": "c29c7695c93ae747"
- topic
- time
"payload": {
"config_enter_otn_mode": true
"time": 1721424530709,
"_msgid": "1014b31e53e5c7ac"
Our Node-Red library lets you configure any of sensor easily, simply by adjusting a few fields in your Node-RED flow and triggering a configuration update either through the CFG button on the sensor or waiting for a FLY message sent every hour during normal operations (or when the device is reset).
- Name
- Arbitrary name of this node
- Serial Device*
- Serial Device for Config
- Mac Address
- Sensor Type*
- Auto Config
- OTF Config
General Sensor Configurations
- Wait for Network Formation
- Destination Address
- Network ID
- Node ID
- Power
- Retries
Probe 1: Set Acceleration Wake/Interrupt Threshold
Set a breakpoint for sensor to wake up and broadcast readings. This is an interrupt based configuration ideal for devices with minimal workload/uptime.
This will be an integer value that increments the interrupt threshold by 50mg. A value of 1 wakes the sensor if acceleration is above 50mg, 2 means 100mg, etc.
Valid Input Range: 0 – 40
A value of 0 will disable this feature.
Only applies to sensor with firmware version 24 and above.
Set the minimum acceleration value to make LED indicator red.
This will be an integer value that increments the threshold by 50mg. A value of 1 means turn the LED red if acceleration is above 50mg, 2 means 100mg, etc.
Set the minimum velocity value to make LED indicator red.
This will be an integer value that increments the threshold by 2mm/second. A value of 1 means turn the LED red if velocity is above 2mm/sec, 2 means 4mm/second, etc.
Output Data Rate (ODR)
The data rate of the output signal. This would determine how many samples the output data has, which is directly related to the highest frequency components that can be measured. In accordance with the Nyquist equation:
f_max = ODR/2.56 Hz
| Sample Rate (ODR) | Sample Duration Max |
| 100Hz | 80sec |
| 200Hz | 40sec |
| 400Hz | 20sec |
| 800Hz | 10sec |
| 1600Hz | 5sec |
| 3200Hz | 2.5sec |
| 6400Hz | 1.26sec |
| 12800Hz | 0.63sec |
| 25600Hz | 0.31sec |
Mode
Select the mode of operation:
- Processed – only processed data is sent, as in the example in this document
- Raw – full time domain data is sent (very large not recommended for prolonged periods)
- Processed + Raw on demand – same as the first mode, but with the option to generate a Raw packet on demand
- Smart – in this mode the sensor automatically samples and sends a data packet if the vibration crosses a defined threshold level
Set Auto Raw Interval
Set Auto Raw Destination Address
This is the address where the Auto Raw data will be sent, we recommend setting this to your gateway address.
For example: 41D5EC37
You can find more info in the modem_mac message section.
Set Smart Mode Threshold
If RMS acceleration is above this in any axis, it will send data. This will be an integer value that increments the interrupt threshold by 50 mg. A value of 1 means to wake the sensor if acceleration is above 50 mg, 2 means 100 mg, etc.
Enable RPM Calculate Status
When a measurement sample is taken you can choose to not calculate the RPM, this will shorten the measurement time and save on battery.
Note that RPM is calculated using acceleration Data. The device samples data at a slow rate for 3 seconds and finds the highest energy peak. If the Acceleration is below 30mg, the RPM will be 0.
OTF/Automatic Configuration
Example Auto Configuration Process
If you have selected the Auto Config and OTF Config boxes, your sensor will pick up any configuration changes you have made to the Sensor Specific parameters and automatically apply them.
This process is not immediate and requires the device send a FLY Message to the Gateway (this happens once every hour or when the device is reset).
Once the FLY message has been received the device will enter OTN mode (indicated by a corresponding message) and update any parameters that have been changed. For each parameter that has been updated an ACK message will be sent.
Once done the device will continue its normal operating with the updated parameter values.
Let us look at an example to better illustrate how the process should work out.
Step 1
Check the two boxes, the one next to “Auto Config” and the one next to “OTF Config”. This will allow the device to work in a mode where it will Automatically pick up the configuration changes.
Step 2
Select the parameter you want to modify.
Let’s go to the “Sampling Interval” and change its value. This parameter determines how often the sensor wakes up, performs a vibration measurement and transmits the data.
The default value is 30 minutes, let’s change it to 5 minutes (keep in mind this will drain the battery faster, but it is a good example as it is easy to observe the change).
Make sure you check the “Active” check box, this will let the sensor know that it needs to update this parameter.
Select the value from the drop down menu, in this case 5 minutes.
Press the “Done” button to close the Device node.
Press the “Deploy” button so you can update the flow.
Step 3
Reset the sensor in order to trigger a FLY message (this will speed things up so you don’t need to wait for the 1 hour autoptic FLY message time).
You will receive a series of messages which are normally sent after the sensor starts.
The more important things here is the FLY message, that reports the current configuration of the device, you can see an example one to the right.
"payload": {
"mac":"00:13:a2:00:42:61:99:bf",
"type":114,
"nodeId":0,
"mode":"FLY",
"lastHeard":1748522204064,
"reported_config":{
"firmware":5,
"destination_address":"00:00:ff:ff",
"mode":"Smart",
"odr":"12800Hz",
"sampling_duration":"1000ms",
"filter_status":"Enabled",
"lpf_coeff":4,
"lpf_freq":"3200Hz",
"hpf_coeff":2048,
"hpf_freq":"6.25Hz",
"sampling_interval":"5 Minutes",
"on_request_timeout":"1 Seconds",
"deadband":"20mg",
"payload_length":"180 Bytes",
"fsr":"8g",
"rpm_compute_status":"Enabled",
"auto_raw_destination_address":"00:00:ff:ff",
"auto_raw_interval":"disabled",
"smart_mode_skip_count":3,
"smart_mode_acc_threshold":"600mg",
"uptime_counter":"0sec",
"max_tx_raw_samples":4096,
"hardware_id":[99,61,0],
"reserved":[0,0,0,0],
"tx_lifetime_counter":2828,
"machine_values":{
"firmware":5,
"destination_address":"0000ffff",
"mode":3,
"odr":14,
"sampling_duration":20,
"filter_status":1,
"lpf_coeff":0,"hpf_coeff":9,
"sampling_interval":0,
"on_request_timeout":1,
"deadband":20,
"payload_length":3,
"fsr":2,
"rpm_compute_status":1,
"auto_raw_destination_address":"0000ffff",
"auto_raw_interval":0,
"smart_mode_acc_threshold":12,
"uptime_counter":[0,0,0,0],
"max_tx_raw_samples":[16,0],
"tx_lifetime_counter":[0,0,11,12]
The FLY message will be followed by an OTN message indicating that the configuration window has been extended in order for the sensor to receive the new settings.
"payload": {
"type":114,
"nodeId":0,
"mode":"OTN",
"lastHeard":1748522204297
A confirmation that the mode has been changed to OTN will be received next, followed by an ACK message confirming the parameter value change.
"payload": {
"config_enter_otn_mode":true
"payload": {
"type":114,
"nodeId":0,
"mode":"ACK",
"lastHeard":1748522205433,
"status":255
Finally, you should see the OTF message, followed by a Configuration Results message, reporting the the parameter/s have been changed successfully.
In this case the sampling interval has been changed and the sensor is exiting OTN mode.
"payload": {
"type":114,
"nodeId":0,
"mode":"OTF",
"lastHeard":1748522206029,
"reported_config":"Error parsing reported config. See log for details."
"payload": {
"sampling_interval_110":true,
"exit_otn_mode":true
Manual Configuration Process
Check Sensor Power
Factory Reset Sensor
- Factory Reset the Sensor
- Factory reset by pressing and release the RESET button, wait for a second, then press and hold the CONFIGURATION button, hold the CONFIGURATION button for more than 15 seconds, release CONFIGURATION button, then Wait for 3-5 seconds, finally press and release the RESET button.
Multiple Gateways
Move Devices Closer
Check Module Frequency - WIP
Examples
Dashboard
- Import
- Expand Type 114 – Standalone Smart Vibration Sensor Gen4
- Click on Import
Example Flows
