Standalone Smart Vibration Sensor Gen4 API Overview
Introducing NCD’s Explore the Standalone Smart Vibration Sensor Gen4 Capabilities. Lightweight rugged and reliable for accurate asset monitoring and boasting up to a 2-mile range using a wireless mesh networking architecture & Incorporating a 16-bit Vibration and integrated Temperature sensor.
This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range.  Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
Features:
  • Small & lightweight for ease of installation.
  • IP67 rated sealed enclosure for dust &
    moisture protection.
  • D-cell battery for long-lasting operation.
  • A versatile user-configurable sample rate for slow or fast-running machines
  • Integrated temperature sensor in base.
  • In-Built Machine Learning optimizes power consumption.
  • Asset On-Time Calculator automatically tracks operational status.
  • Hardware Accelerator enhances vibration sampling accuracy.
  • Configurable Sample Rate – 100Hz to 25.6KHz
  • Available Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
  • Supports MESH networking via DigiMesh
  • Fully open Node-RED library for configuration and data ingestion
Frame Structure
Figure 3: Communication Procedure - Power Up
Mode TypePAN ID set by Sensor (ASCII)Frame fieldOffset (Payload section)Value
RunID save by user / DefaultMode bytes70x52
80x55
90x4E
Configuration7BCDMode bytes70x50
80x47
90x4D
Factory Reset7FFFMode bytes70x50
80x55
90x4D
Run Mode Frame
FieldNumber of bytesDescription
7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 72 00 00 52 55 4E 00 00 00 00 00 00 CEExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type (Power Up)
0x0013A200425364538Source Address
0xFFFE2Reserved
0xC21R. Option
0x7A1Header with Power Up value
0x001Node ID
0x001Separator
0x00722Sensor Type
0x00002Separator
0x52554E3Mode Byte for Run Mode
0x0000000000006Reserved
0xCE1Checksum
Configuration Mode Frame
7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 72 00 00 50 47 4D 00 00 00 00 00 00 DFExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0xC21R. Option
0x7A1Header
0x001Node ID
0x001Separator
0x00722Sensor Type
0x00002Separator
0x50474D3Mode Byte for Configuration Mode
0xDF1Checksum
Factory Reset Mode Frame
7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 72 00 00 50 55 4D 00 00 00 00 00 00 D1Example frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0xC21R. Option
0x7A1Header
0x001Node ID
0x001Separator
0x00722Sensor Type
0x00002Separator
0x50554D3Mode Byte for Factory Reset Mode
0xD11Checksum
OTN Mode Frame
7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7A 00 00 00 72 00 00 4F 54 4E 00 00 00 00 00 00 D2Example frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0xC21R. Option
0x7A1Header
0x001Node ID
0x001Separator
0x00722Sensor Type
0x00002Separator
0x4F544E3Mode Byte for OTN Mode
0xD21Checksum
FLY Mode Frame
7E 00 3E 90 00 13 A2 00 42 53 64 53 FF FE C2 7F 00 01 00 00 00 00 72 01 46 4C 59 00 00 FF FF 03 0A 14 01 00 04 02 01 14 03 02 01 00 00 FF FF 00 03 0A 00 00 00 01 55 95 0B 00 00 00 00 00 00 00 73 1CExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0xFFFE2Reserved
0x001R. Option
0x7F1Header
0x001Node ID
0x011Firmware Version
0x00002Battery Voltage
0x001Counter
0x00722Sensor Type
0x001Reserved
0x464C593Mode Byte for FLY Mode
0x0000FFFF4Dest. Address
0x031Mode of operation
0x0A1ODR
0x141Sampling Duration
0x011Filter Status
0x001Low Freq SR
0x041High Freq SR
0x021Sampling Interval
0x011Raw on Request Timeout
0x141Dead Band
0x031Raw Packet Length
0x021FSR
0x011RPM Compute Status
0x0000FFFF4Auto Raw Dest. Address
0x001Auto Raw Interval
0x031Smart Mode Skip Counter
0x0A1Smart Mode Acceleration Threshold
0x000000014Uptime Counter
0x55950B3Hardware ID
0x000000004Reserved
0x000000734Tx Lifetime Counter
0x1C1Checksum
UPTHWRN Mode Frame
7E 00 1C 90 00 13 A2 00 42 53 64 53 FF FE C2 7F 00 0E 03 E9 12 00 72 00 55 50 54 48 57 52 4E 7AExample frame
0x7E1Delimiter
0x001C2Length
0x901Frame Type
0x0013A1004158C1CB8Source Address
0xFFFE2Reserved
0x001R. Option
0x7F1Header
0x001Node ID
0x0E1Firmware Version
0x03E92Battery Voltage
0x121Packet Counter
0x00722Sensor Type
0x001Reserved
0x5550544857524E7Mode Byte for UPTHWRN Mode
0x7A1Checksum
MOFF Mode Frame
7E 00 18 90 00 13 A1 00 41 58 C1 CB FF FE C1 7C 01 6F 00 72 08 FF 4D 4F 46 46 00 E9Example frame
0x7E1Delimiter
0x00182Length
0x901Frame Type
0xFFFE2Reserved
0xC11R. Option
0x7C1Header
0x001Node ID
0x6F1Separator
0x121Packet Counter
0x00722Sensor Type
0x08FF4D3Reserved
0x4F4646007Mode Byte for MOFF Mode
0xE91Checksum
Sensor Data Frame
Figure 4: Communication Procedure - Run Mode
As this sensor has two possible frame structures for the Processed and RAW mode, we are detailing each one below:
Processed Data Frame
Frame FieldOffset (Payload section)Fixed Value (if any)LengthDescription
Header00x7F1Header to differentiate various types of packets
Node ID10x001Node ID to differentiate up to 256 nodes in a network. User configurable values
Firmware20x011Used to determine firmware version programmed in the device
Battery VoltageMSB 30x032Battery Voltage = 0.00322*(03*FF+FE)
LSB 40xFEBattery Voltage = ((Battery Voltage MSB x 256) + Battery Voltage LSB) x 0.00322 V
Packet Counter5-1It is an 8-bit counter that increments with each packet transmission. It can be used to detect missing packets
Sensor TypeMSB 60x002Two bytes to determine sensor type. It can be used in conjunction with Node ID to create sensor networks of up to 256 nodes for a single type of sensor and multiple such networks can coexist and can be differentiated in processing software on PC end.
LSB 70x72Sensor Type 114
Error/Reserved byte80x001Bit 7: Reserved
Bit 6: Reserved
Bit 5: Reserved
Bit 4: 1 - Motion Report, 0 - Regular report
Bit 3: 1 - Dual-probe
Bit 2: Probe 2 Data invalid
Bit 1: Probe 1 Data invalid
Bit 0: Reserved
In Processed Packet.
Bit 4: Message Type:
- 1: Motion Report
- 0: Regular Report
Sensor Data9/ Data[0]0x001Mode of Operation:
0x00 - Processed
0x01 - Raw
0x02 - On Demand
0x03 - Smart
Output Data Rate10/ Data[0]-1Vibration Sample Rate:
0x08 - 200Hz
0x09 - 400Hz
0x0A - 800Hz
0x0B - 1600Hz
0x0C - 3200Hz
0x0D - 6400Hz
0x0E - 12800Hz
0x0F - 25600Hz
Temperature11/ Data[0]-2Temperature value (Unsigned 16 bit int)
12/ Data[1]-Temperature in Celsius = (Data[0] * FF + Data[1]) / 100
RMS ACC in X Axis in mg13/ Data[0]-2rms_acc_x_mg value
14/ Data[1]-rms_acc_x_mg = (Data[0] * FF + Data[1]) / 1000
MAX ACC in X Axis in mg15/ Data[0]-2max_acc_x_mg value
16/ Data[1]-max_acc_x_mg = (Data[0] * FF + Data[1]) / 1000
RMS Velocity in X Axis in mm/sec17/ Data[0]-2rms_vel_x_mm_sec value
18/ Data[1]-rms_vel_x_mm_sec = (Data[0] * FF + Data[1]) / 100
RMS Displacement in X Axis in mm19/ Data[0]-2rms_disp_x_mm value
20/ Data[1]-rms_disp_x_mm = (Data[0] * FF + Data[1]) / 100
Frequency of Highest Peak in X direction21/ Data[0]-2X1 Hz Value
22/ Data[1]-X1_Hz = (Data[0] * FF + Data[1])
Frequency of Second Highest Peak in X direction23/ Data[0]-2X2_Hz Value
24/ Data[1]-X2_Hz = (Data[0] * FF + Data[1])
Frequency of Third Highest Peak in X direction25/ Data[0]-2X3_Hz Value
26/ Data[1]-X3_Hz = (Data[0] * FF + Data[1])
RMS ACC in Y Axis in mg27/ Data[0]-2rms_acc_y_mg value
28/ Data[1]-rms_acc_y_mg = (Data[0] * FF + Data[1]) / 1000
MAX ACC in Y Axis in mg29/ Data[0]-2max_acc_y_mg value
30/ Data[1]-max_acc_y_mg = (Data[0] * FF + Data[1]) / 1000
RMS Velocity in Y Axis in mm/sec31/ Data[0]-2rms_vel_y_mm_sec value
32/ Data[1]-rms_vel_y_mm_sec = (Data[0] * FF + Data[1]) / 100
RMS Displacement in Y Axis in mm33/ Data[0]-2rms_disp_y_mm value
34/ Data[1]-rms_disp_y_mm = (Data[0] * FF + Data[1]) / 100
Frequency of Highest Peak in Y direction35/ Data[0]-2Y1 Hz Value
36/ Data[1]-Y1_Hz = (Data[0] * FF + Data[1])
Frequency of Second Highest Peak in Y direction37/ Data[0]-2Y2_Hz Value
38/ Data[1]-Y2_Hz = (Data[0] * FF + Data[1])
Frequency of Third Highest Peak in Y direction39/ Data[0]-2Y3_Hz Value
40/ Data[1]-Y3_Hz = (Data[0] * FF + Data[1])
RMS ACC in Z Axis in mg41/ Data[0]-2rms_acc_z_mg value
42/ Data[1]-rms_acc_z_mg = (Data[0] * FF + Data[1]) / 1000
MAX ACC in Z Axis in mg43/ Data[0]-2max_acc_z_mg value
44/ Data[1]-max_acc_z_mg = (Data[0] * FF + Data[1]) / 1000
RMS Velocity in Z Axis in mm/sec45/ Data[0]-2rms_vel_z_mm_sec value
46/ Data[1]-rms_vel_z_mm_sec = (Data[0] * FF + Data[1]) / 100
RMS Displacement in Z Axis in mm47/ Data[0]-2rms_disp_z_mm value
48/ Data[1]-rms_disp_z_mm = (Data[0] * FF + Data[1]) / 100
Frequency of Highest Peak in Z direction49/ Data[0]-2Z1 Hz Value
50/ Data[1]-Z1_Hz = (Data[0] * FF + Data[1])
Frequency of Second Highest Peak in Z direction51/ Data[0]-2Z2_Hz Value
52/ Data[1]-Z2_Hz = (Data[0] * FF + Data[1])
Frequency of Third Highest Peak in Z direction53/ Data[0]-2Z3_Hz Value
54/ Data[1]-Z3_Hz = (Data[0] * FF + Data[1])
Revolutions Per Minute (RPM)55/ Data[0]-2Revolutions Per Minute Value
56/ Data[1]-RPM = ((Data[0] <<8) + Data[1])
Raw Data Frame
Node ID10x00 (Factory Default)1Node ID to differentiate up to 256 nodes in a network. User configurable values
Error/Reserved byte80x001Bit 1: Validity of Data for sensor:
- 0: Data is valid.
- 1: Error in accessing sensor
In Time Domain Data (RAW) Packet.
- 1: Motion Report
- 0: Regular Report
Sensor Data9/ Data[0]0x011Mode of Operation:
00 - Processed
01 - Raw
02 - On Demand
03 - Smart
Output Data Rate10/ Data[0]-2Output Data Rate Value
11/Data[1]-ODR = (Data[0] * FF + Data[1])
Full Scale Range and Eabled Axis12/Data[0]-1Three MSB bit of the Axis byte to indicate FSR And 3 LSB bits indicates Axis
Hour13/Data[0]-1Hour = Data[0]
Minute14/Data[0]-1Minute = Data[0]
Device Temperature15/Data[0]-2Device Temperature Value
16/Data[1]-Temperature = (Data[0] * FF + Data[1]) / 100
Total Number of RF Packets17/Data[0]-2Total Number of RF Packets Value
18/Data[1]-Total Number of RF Packets = ((Data[0] << 8) + Data[1])
Current Packet Count value19/Data[0]-2Current Packet Count value
20/Data[1]-Current Packet Count = ((Data[0] << 8) + Data[1])
Time Domain Data Packets----
X1-Axis RAW ACC Data---X1= (01*0xFF+ 0xDE)*FSR coefficient
Y1-Axis RAW ACC Data---Y1= (01*0xFF+ 0x7A)*FSR coefficient
Z1-Axis RAW ACC Data---Z1= (3F*0xFF+ 0x8B)*FSR coefficient
Figure 5: Communication Procedure - Configuration Mode
The following set of commands are an example on how to change some of the parameters that affect the operation of the Standalone Smart Vibration Sensor Gen4 (these are parameters that are general in nature, more on a network protocol/device level than device specific). You can find them in Appendix together wit the Device/Application Specific commands.
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
00 13 A2 00 41 91 1B 83
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
Read Sensor Network ID
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
Read Sensor Destination Address​
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Set Sensor Destination to Broadcast ​
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Read Wireless Sensor Retries​
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep.  But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data.  If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep.  The Machine Uptime sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Set Wireless Sensor number of Retries ​
Complete Payload
F7 06 00 00 00 05
Complete Payload
5. In case you still can’t solve your issue head to our Community forum to get real time help from the NCD community of experts: https://community.ncd.io/
Appendix
Configuration Commands
1Set Broadcast Transmission 0XF70x01-0000FFFFThis will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets
7Read Sleep Interval0XF70x15-0x00,0x02,0x58Reads the stored Sleep Interval value from the sensor
8Read Power0XF70x16-0x04Reads the stored RF Power value from the sensor
9Read Retries0XF70x17-0x0AReads the stored Retries value from the sensor
10Read Destination Address0XF70x18-00,00,FF,FFReads the stored Destination value from the sensor
11Read PAN ID aka Network ID0XF70x19-0x7FFFReads the PAN ID aka Network ID
12Enable Encryption 0XF20x01-0x01Enables the Encryption of the Frame Transmitted from the Sensor
13Disable Encryption 0XF20x02--Disables the Encryption of the Frame Transmitted from the Sensor
Command Acknowledgement Data
No.CommandData bytesReserved bytesDataCalculation (if any)
1Set Broadcast Transmission 180xFF (OK)
2Set ID and Sleep Interval180xFF (OK)
3Set Destination Address180xFF (OK)
4Set Power180xFF (OK)
5Set PAN ID aka Network ID180xFF (OK)
6Set Retries 180xFF (OK)
7Read Sleep Interval36D0 MSB, D1, D2 LSBDelay = (D0 x 65536) + (D1 x 256) + D2
8Read Power18PowerDEC value
9Read Retries18RetriesDEC value
10Read Destination Address45A0 MSB, A1, A2, A3
11Read PAN ID aka Network ID27ID0 MSB, ID1
12Enable Encryption 180xFF (OK)
13Disable Encryption 180xFF (OK)
14Set Encryption Key180xFF (OK)
Application Specific Commands
No.CommandHeaderSub CommandReserve ByteProbe CommandCommand Code / ArgumentDescription
1Set Output Data Rate0xF40x4F0x65, 0x000x010x07--100Hz
0x08--200Hz
0x09--400Hz
0x0A--800Hz
0x0B--1600Hz
0x0C--3200Hz
0x0D--6400Hz
0x0E--12800Hz
0x0F--25600Hz
Set the frequency at which the sensor outputs data after it has been sampled.NOTE: These are based on Default Filter Setting. LOW and HIGH PASS Filters Can be used to Change These Ranges
2Get Output Data Rate0xF40x4F0x65, 0x010x010x07--100Hz
0x08--200Hz
0x09--400Hz
0x0A--800Hz
0x0B--1600Hz
0x0C--3200Hz
0x0D--6400Hz
0x0E--12800Hz
0x0F--25600Hz
3Set Sampling Duration0xF40x4F0x65, 0x020x01Valid Range:
0x01 -- 0x64
Period of samples in secondsmust be > 0Sample duration value is multiple of 50mS i.e. setting sample duration to 1 will set the duration time to 50mSec, setting duration to 2 will set sample duration time to 100msec and so on
4Get Sampling Duration0xF40x4F0x65, 0x030x01
5Set Sampling Interval0xF40x4F0x65, 0x060x08 -- Every 1 minutes
0x00 -- Every 5 minutes
0x01 -- Every 10 minutes
0x02 -- Every 15 minutes
0x03 -- Every 20 minutes
0x04 -- Every 30 minutes
0x05 -- Every 60 minutes
0x06 -- Every 120 minutes
0x07 -- Every 180 minutes
Set the amount of time between each measurement or sample taken by the sensor. It determines how often the sensor collects data on vibration levels (such as acceleration, velocity, or displacement) over a specific period.
6Get Sampling Interval0xF40x4F0x65, 0x070x08 -- Every 1 minutes
7Set RTC0xF40x4F0x65, 0x08Byte 1 -- Hours
Byte 2 -- Minutes
Byte 3 -- Seconds
Set the internal sensor RTC using the provided values for hours, minutes, and seconds.
8Set Operation Mode0xF40x4F0x00, 0x090x00 -- Processed Mode
0x01 -- Raw Mode
0x02 -- Processed + Raw on Request
0x03 -- Smart Mode
Set the operation mode that the sensor will use. The default mode is Processed Mode.
9Get Operation Mode0xF40x4F0x65, 0x0A0x00 -- Processed Mode
0x01 -- Raw Mode
0x03 -- Smart Mode
10Set Full-scale Range0xF40x4F0x65, 0x0B0x00 -- +/- 2g
0x01 -- +/- 4g
0x02 -- +/- 8g
0x03 -- +/- 16g
0x04 -- +/- 32g
0x05 -- +/- 64g
Set the maximum range of acceleration values the sensor can measure.
11Get Full-scale Range0xF40x4F0x65, 0x0C0x00 -- +/- 2g
0x01 -- +/- 4g
0x02 -- +/- 8g
0x03 -- +/- 16g
0x04 -- +/- 32g
0x05 -- +/- 64g
12Set Filters0xF40x4F0x65, 0x0D0x01 -- Enable
0x00 -- Disable
13Get Filters0xF40x4F0x65, 0x0E0x01 -- Enable
0x00 -- Disable
14Set On Request Timeout0xF40x4F0x00, 0x11Valid Range:
0x01 -- 0x0A
Value Range -- 1-10sec. Device will decide how long device will stay awake and wait for raw time domain request from command
15Get On Request Timeout0xF40x4F0x65, 0x12
16Set Dead Band Value in mg0xF40x4F0x00, 0x28Valid Range:
0x00 -- 0xFF
Value Range -- 0-255mg. Filters out acceleration values below the dead band threshold, treating them as noise.
17Get Dead Band Value in mg0xF40x4F0x65, 0x29
18Extend OTF Configuration Time0xF40x4F0x65, 0x32Extend OTF on time by 30sec
19Exit OTF Configuration Time0xF40x4F0x65, 0x33
20Set Motion Detection Threshold INT0xF40x4F0x50, 0x3C0x01Valid Range:
0x00 -- 0x28
The sensor will wake up and take samples when vibration goes above this threshold(Set threshold 400mg, Multiple of 50mg)
21Get INT Threshold0xF40x4F0x50, 0x3D0x01
22Request Time Domain Data - Regular0xF40x4F0x50, 0x130x01Once Sensor Receives This command it will Send Time Domain (Raw) data to Requester (Only apply for mode 2 and 3)
23Request Time Domain Data - Custom0xF40x4F0x00, 0x00, 0x00,0x540x01Sample Rate
0x07 -- 400sps (Range 6.25 – 100 Hz)
0x08 -- 800sps (Range 12.5 – 200 Hz)
0x09 -- 1600sps (Range 25 – 400 Hz)
0x0A -- 3200sps (Range 50 – 800 Hz)
0x0B -- 6400sps (Range 100 – 1600 Hz)
0x0C -- 12800sps (Range 200 – 3200 Hz)
0x0D -- 25600sps (Range 400 – 6400 Hz)
Sample Duration
Valid Range:
0x01 -- 0x64
Once Sensor Receives This command it will transmit Time Domain (Raw) data, but data will be based on sample rate (ODR) and sample duration parameters. (Only apply for mode 3 - Smart)
24Request Time Domain Data - Smart0xF40x4F0x65, 0x500x01Once Sensor Receives This command it will transmit Time Domain (Raw) data only if the motor is on, if the motor is off sensor will transmit motor is off. (MOFF) (Only apply for mode 3 - Smart)
25Set Acceleration Alert Threshold0xF40x4F0x00, 0x3EValid Range:
0x00 -- 0xFF
Set the minimum acceleration value to make LED indicator red.This will be an integer value that increments the threshold by 50mg. A value of 1 means turn the LED red if acceleration is above 50mg, 2 means 100mg, etc.**Only applies if LED Alert Mode is set to Acceleration.RED Alert Led Will Blink If the RMS acceleration readings go above this threshold(Set threshold 400mg, Multiple of 50mg)
26Get Acceleration Alert Threshold0xF40x4F0x00, 0x3F
27Set Velocity Alert Threshold0xF40x4F0x00, 0x40Valid Range:
0x00 -- 0xFF
Set the minimum velocity value to make LED indicator red.This will be an integer value that increments the threshold by 2mm/second. A value of 1 means turn the LED red if velocity is above 2mm/sec, 2 means 4mm/second, etc.**Only applies if LED Alert Mode is set to Velocity.RED Alert Led Will Blink If the RMS Velocity readings go above this threshold(Set threshold 20mm/sec, Multiple of 2mm/sec)
28Get Velocity Alert Threshold0xF40x4F0x00, 0x41
29Set Alert Mode to Acceleration0xF40x4F0x00, 0x42, 0x00Alert LED will blink if readings go above set Acceleration threshold
30Set Alert Mode to Velocity0xF40x4F0x00, 0x42, 0x01Alert LED will blink if readings go above set Velocity threshold
31Set Low Pass Filter0xF40x4F0x50, 0x340x010x00 -- 4 Filter Coefficient
0x01 -- 8 Filter Coefficient
0x02 -- 16 Filter Coefficient
0x03 -- 32 Filter Coefficient
0x04 -- 64 Filter Coefficient
0x05 -- 128 Filter Coefficient
0x06 -- 256 Filter Coefficient
0x07 -- 512 Filter Coefficient
0x08 -- 1024 Filter Coefficient
0x09 -- 2048 Filter Coefficient
This setting will set the LPF freq to ODR divided by Selected ValueExample: ODR = 800 and Filter Coefficient = 4LPF freq = 800/4 = 200Hz
32Get Low Pass Filter0xF40x4F0x50, 0x350x010x00 -- 4 Filter Coefficient
33Set High Pass Filter0xF40x4F0x50, 0x360x010x00 -- 4 Filter Coefficient
This setting will set the HPF freq to ODR divided by Selected ValueExample: ODR = 800 and Filter Coefficient = 64HPF freq = 800/64 = 12.5Hz
34Get High Pass Filter0xF40x4F0x50, 0x370x010x00 -- 4 Filter Coefficient
35Set Auto Raw Interval0xF40x4F0x50, 0x46Valid Range:
0x00 -- 0xFF
The interval is determined by the sample interval. If the value is set to 1 and the sample interval is 10 minutes, raw data will be sent every 10 minutes. If the value is set to 5, raw data will be sent every 50 minutes.
36Get Auto Interval0xF40x4F0x50, 0x47
37Set Auto Raw Destination0xF40x4F0x50, 0x48Valid Range:
0x00 -- 0xFFFFFFFF
Each time the sensor automatically transmits Time-Domain (raw) data, it will be sent either in broadcast mode or unicast mode (targeted address).Default value: 0000FFFF for Broadcast Mode
38Get Auto Raw Destination0xF40x4F0x50, 0x49
39Clear Probe Uptimers0xF40x4F0x50, 0x4BBy default, the sensor measures the total time the asset is on. This command will reset the internal uptime counter.
40Get Probe Uptimers0xF40x4F0x50, 0x4A
41Set Smart Mode Skip Interval0xF40x4F0x65, 0x4CValid Range:
0x00 -- 0xFF
Sensor will skip sending data this many times if vibration is below the smart threshold.
42GetSmart Mode Skip Interval0xF40x4F0x65, 0x4D
43Set Smart Mode Threshold0xF40x4F0x65, 0x4E0x01Valid Range:
0x00 -- 0xFFFE
If RMS acceleration is above this in any axis, it will send data. This will be an integer value that increments the interrupt threshold by 50 mg. A value of 1 means to wake the sensor if acceleration is above 50 mg, 2 means 100 mg, etc.
44Get Smart Mode Threshold0xF40x4F0x65, 0x4F0x01
45Set FLY Interval0xF40x4F0x65, 0x510x003C -- 1 Hour
0x0078 -- 2 Hours
0x00F0 -- 4 Hours
0x01E0 -- 8 Hours
0x02D0 -- 12 Hours
0x0438 -- 18 Hours
0x05A0 -- 24Hours
Set the interval at which the sensor performs Fly Mode transmissions.
46Get FLY Interval0xF40x4F0x65, 0x520x003C -- 1 Hour
0x0078 -- 2 Hours
0x00F0 -- 4 Hours
0x01E0 -- 8 Hours
0x02D0 -- 12 Hours
0x0438 -- 18 Hours
0x05A0 -- 24Hours
47Set Payload Lenght0xF40x4F0x50, 0x440x00 -- 55 Bytes
0x01 -- 100 Bytes
0x02 -- 150 Bytes
0x03 -- 180 Bytes
Set the amount of Time Domain Data included in each RAW transmission sent by the sensor.
48Get Payload Lenght0xF40x4F0x50, 0x450x00 -- 55 Bytes
0x01 -- 100 Bytes
0x02 -- 150 Bytes
0x03 -- 180 Bytes
49Enable RPM Calculate status0xF40x4F0x65, 0x550x01 -- Enable
0x02 -- Disable
Enable/disable whether the sensor calculates and reports the Rotations Per Minute (RPM) of a rotating machine or component during its measurements.
50Get RPM Calculate status0xF40x4F0x65, 0x560x01 -- Enable
0x02 -- Disable
51Set Max RAW Sample0xF40x4F0x65, 0x570x0400 -- 1024 Samples
0x8000 -- 2048 Samples
0x1000 -- 4096 Samples
0x1900 -- 6400 Samples
0x1FA4 -- 8100 Samples.
Defines the maximum number of samples the sensor captures for time-domain data
52Get Max RAW Sample0xF40x4F0x65, 0x580x0400 -- 1024 Samples
53Set Motion to Sampling Delay0xF40x4F0x65, 0x59Valid Range:
0x00 -- 0xFF
Once motion is detected, the sensor will wait for the configured duration before sampling and computing vibration data.
1= 50msec, 2= 100msec, 100= 5000msec (5sec).
Default value: 100 (5000msec)
**Only applies to sensor with firmware version 6 and above.
54Get Motion to Sampling Delay0xF40x4F0x65, 0x5A
55Set Max Number Motion Tx Per Interval0xF40x4F0x65, 0x5BValid Range:
0x01 -- 0xFF
Set Number of times it will send data due to motion triggers.
Default value: 1
Note: Setting this to a higher value will drain the battery.
56Get Max Number Motion Tx Per Interval0xF40x4F0x65, 0x5C
Sample Duration vs ODR
Sample Rate (ODR)Sample Duration Max
100Hz80sec
200Hz40sec
400Hz20sec
800Hz10sec
1600Hz5sec
3200Hz2.5sec
6400Hz1.26sec
12800Hz0.63sec
25600Hz0.31sec
Error Code Descriptions
Error NumberDescription
0x01Invalid command
0x02Sensor Type mismatch
0x03Node ID mismatch
0x04Apply change command failed during X-bee parameter update
0x05Invalid API packet command response received after Apply change command
0x06Write command failed during X-bee parameter update
0x07Invalid API packet command response received after Write command
0x08Parameter change command failed during X-bee parameter update
0x09Invalid Parameter change command response packet received after Write command
0x0AInvalid/Incomplete packet received
0x0FInvalid parameter for setup/saving
Calculation for transmission
					0x04
					0xFF-0x04=0xFB
Calculation for reception
1.     Not including the frame delimiter and length, add all the bytes including the received checksum
2.     Keep only the last 8 bits
3.      If the result is 0xFF, the checksum is correct and the packet can be processed.
Consider the example for the command Set Broadcast shown in APPENDIX A and see that the received packet checksum verifies since the result is 0xFF.
					0xFF
