- Introduction
- Applications
- Hardware
- Receiving Sensor Data
- Software API Structure
- Sensor Type 84 Transmission Structure
- Sensor Transmission Structure RAW Mode
- Sensor Configuration Structure
- Enter Configuration Mode
- Read Sleep Duration
- Read Sensor Network ID
- Configuration Commands Table
- Sensor App Specific Configuration Commands Table
- Installation Guidelines
- Troubleshooting Guide
- Sensor Support Map
1
- Calculates RMS, MAX, and MIN g Vibration
- Noise Removal using Low-pass Filter
- Frequency Range (Bandwidth) up to 6400 Hz In Processed Mode
- Frequency Range (Bandwidth) up to 12,000 Hz In Time Domain Mode
- Sample Rate up to 25,600Hz
- Time Domain Data for FFT analysis
- Wake up on Motion Feature
- Local Alert indicator LED
- Over the Air Configuration
- Operating Temperature Range -40 to +70 °C
- Humidity Range 0-90%
- For Indoor and Outdoor Use
- Mounting Options- 1/4-28 UNF, 1/4 NPT, Magnet Mount
Product Link https://store.ncd.io/product/smart-industrial-iot-wireless-vibration-temperature-sensor/
This Industrial IoT wireless vibration sensor has two modes of operation.
Mode 1 –
Send Data after a user-defined interval
Mode 2 –
Send data when vibration goes above a user-defined threshold. This mode insures that you never miss any data when the machine is on.
Powered by just 2 AA batteries, ten years of battery life can be expected depending on environmental conditions and the data transmission interval, making it an ideal choice for wireless vibration monitoring systems for industrial equipment.
With an open communication protocol, this sensor transmits hardware encrypted data that can be integrated with any control system or gateway. Data can be sent simultaneously to a PC, a Raspberry Pi, Losant IoT cloud, Microsoft® Azure® IoT, and an embedded system. Sensor parameters and wireless transmission settings can be changed using our free LabVIEW® monitoring software on a desktop PC.
The long-range, price, accuracy, battery life, and security features of Wireless Vibration Sensor make it an affordable choice that exceeds the requirements for most industrial and consumer market applications.
NOTE – This product does NOT work with Alpha station. We recommend node-red.
Specifications
Specifications | Minimum | Nominal | Maximum | Notes |
Batteries | 2 | 2 | 2 | |
Diameter | 44mm | |||
Length | 100mm | |||
Enclosure Rating | IP67 | |||
Temperature Rating | -40° C | 23° C | 85° C | Component Rating |
Tested Temperature | 0° C | 23° C | 40° C | As Tested by NCD Staff |
X Vibration Range | -16g | +16g | ||
Y Vibration Range | -16g | +16g | ||
Z Vibration Range | -16g | +16g | ||
X Velocity Range | 0-655mm/sec | |||
Y Velocity Range | 0-655mm/sec | |||
Z Velocity Range | 0-655mm/sec | |||
X Displacement Range | 0-655mm | |||
Y Displacement Range | 0-655mm | |||
Sample Rate | 100hz | 1600hz | 25.6Khz | Vibration Sensor Data Rate |
Frequency Range ( Processed Mode) | 1.56hz | 400hz | 6400hz | Freq range should be equal or greater than machine RPM |
Frequency Range ( Time Domain Mode) | 0.56hz | 800hz | 12,000hz | |
Sample Duration | 1sec | 1sec | 10sec | Device will take readings for the set time and then send over wireless |
Time Domain Data | Yes | |||
Filters | Yes | |||
Mounting | 1/4 NPT 1/4-28 UNF Magnet Mount | |||
FFT | Yes |
Use Energizer Ultimate Lithium ONLY for Extreme Temperatures
All Ratings are for 2 Batteries
Actual Battery Life is Dependent On Transmission Interval
Battery Shelf Life Does Not Exceed 10 Years Therefore NCD Does Not Rate Battery Life Beyond the Shelf Life of Available Batteries
** Battery life will significantly reduce when time domain mode is enabled
3
- Wireless Industrial Machine Health Analysis
- Machine Fault detection
- Frequency Analysis of Vibration data
- Building and Structural Monitoring
Hardware
4
Sensor Hardware
The vibration sensor enclosure is made out of Aluminum. It has three mounting options such as 1/4 NPT, 1/4-28 UNF, and a magnetic Mount.
Sensor Diagram
Axis Marking
Temperature Sensor
The NCD V3 Vibration Sensor also includes a integrated temperature sensor. This temperature sensor serves two functions. First, this sensor is used to keep the integrated vibration sensor accurate over the operating temperature range. Second, this sensor may be used to monitor the temperature of machinery in select circumstances. Please keep in mind the integrated sensor is epoxy filled and the sensor must be saturated with heat (heat soaked) before the temperature measurements will be accurate for machine measurement. The time delay for heat transfer will greatly depend on the operating environment and machine attachment location. For machine temperature measurement applications, the magnetic attachment should not be used as it provides too great of a thermal insulator. For best results, thermal conductive compound should be used for faster temperature transfer to the sensor probe using the threaded fittings. This probe should not be used for temperature measurement applications if you require instantaneous machine temperature readings, a separate dedicated sensor probe is required for these applications (such as a thermocouple).
Sensor Power
This Sensor has two power options.
- Powered by AA batteries ( NCD recommends Energizer L91 batteries)
The L91 Batteries are non-rechargeable Li-Ion batteries.
While changing the batteries
- Turn off The sensor
- Only use new L91 batteries
- Checkout the Polarity marking on the Battery Holder and Batteries
- Batteries should not be replaced in fire risky areas
Sensor Radio Technology
NCD Long Range Wireless Sensors are available with many radio options, which should be carefully chosen based on the country of installation. NCD uses Digi radios exclusively because of their best-in-class range, reliability, wide operating temperature, and low power operation. Please note that not all options are legal for use in all areas, so it’s important to make the right selection during purchase. NCD manufactures sensors based on the radio options chosen, we do not typically restrict radios to certain countries so please check local laws BEFORE purchase. Here, we will explain the radio options in greater detail to help guide users into the correct radio based on installation country.
900MHz for Use in the United States
If NCD sensors will be installed within the United States, the 900MHz (North America) option is the best choice, offering the longest possible range of up to 2 Miles Line of Sight and up to 28 Miles using High-Gain Antennas. This option can typically work up to 1,000 feet indoors (depending on building materials, concrete and steel building typically reduce the operational range significantly). This option is typically not legal for use outside North America.
868MHz for Use in Europe
If NCD sensors will be installed in Europe, the 868MHz (Europe Only) option is the best choice, offering the longest possible range of up to 14.5km Line of Sight. This option is typically not legal for use outside of Europe.
2.4GHz for Worldwide Use
The 2.4GHz Option is generally legal for use in most countries, including Europe and the United States and offers a range of up to 2 Miles (3200 Meters) Line of Sight or up to 300 feet (about 90 Meters) indoors. Because of the widespread use of 2.4GHz, the rated ranges are rarely achieved. The 900MHz and 868MHz communication modules are a far better choice for users in the United States and Europe respectively. Users who may require worldwide compliance should use the 2.4GHz option, but this option should be considered if the above options are not legal for use.
Sensor Internal Overview
The Vibration Sensor has two Indicator LEDs.
Blue Status LED – The status LED indicates errors or other sensor diagnostics.
LED Blink Once – The message was sent successfully, and no error in the last sensor read as well in data transmission
LED Blink Twice and then One more time — Message was sent successfully, but there was an error in the last sensor read
LED blink Thrice — MCU is having an issue communicating with Radio Module
RED Alert LED will blink twice when the vibration goes above the user’s set threshold.
5
NCD IoT Sensors require a receiving device to receive sensor telemetry. Since NCD IoT sensors broadcast sensor data, any number of receivers may be used to receive sensor telemetry. Similarly, multiple types of receiving devices may be used for different applications. For instance, modems may be used for receiving sensor data on a local computer. The same installation may also benefit from having a Micro Gateway for forwarding sensor telemetry directly to a popular cloud platform such as AWS, Azure, or MQTT. The same installation may also benefit from having a IoT Edge Computer for localized data processing and forwarding data using LTE Cellular Connectivity. All of these receivers may be used simultaneously, redundantly, or individually, depending on application requirements. In this section, we will discuss the different types of receivers, how to use them, and when to use them.
Good to Know!
Regardless of your application requirements, no less than one USB modem should always be available for troubleshooting, sensor configuration, and recovery of sensor settings. Please be sure to have a USB modem available as a basic requirement for using the NCD ecosystem of IoT Sensors. We also advise using Alpha Station to help with basic sensor configuration and troubleshooting. Alpha Station is available as a free download from https://ncd.io/alpha.
Using Modems
Modems allow local computers to receive NCD Sensor Telemetry from a range of up to 2 Miles Line of Sight. Data from the sensor will arrive at the wireless modem as raw bytes of data that must be parsed into meaningful sensor values. Alpha Station software makes it easy to view sensor data in both raw and parsed format. Alpha Station includes source code that provides meaningful samples for how data should be parsed and converted into real-world values.
Modems are useful in applications that require a local PC to receive and handle data. They also offer a low-cost connectivity option for users who wish to integrated their own software into the NCD ecosystem of long range wireless sensors. Because there are many connectivity options for interface to a PC, NCD offers several modem options with popular interface technologies such as USB, RS-232, Ethernet, Wi-Fi, Bluetooth, and RS-485.
There is no limit to the number of sensors that may be used with a single modem. However, if you plan to send data frequently from one or more sensors, the wireless bandwidth will become congested and data packet loss may occur. In applications where each sensor is set to transmit every 10 minutes or longer, we recommend using one modem for every 128 sensors. Using the Pan ID features of the Modem and Sensors, groups may be defined allowing multiple groups of 128 sensors.
Experienced users may use modems as a cloud connectivity option. NCD does not actively support this configuration as NCD Gateways are a much better choice for integrating NCD sensors directly to cloud platforms. However, modems make a lot of sense for installations that already have a gateway and need a simple interface solution to the NCD ecosystem of long range wireless sensors.
USB Modem Requirement
As mentioned above, the USB Modem is an essential tool for device configuration, diagnostics, and recovery. Regardless of your application, at some point a USB Modem is likely to be needed and should be considered a requirement to have at least one on hand when working with NCD sensors.
The USB Modem mounts as a virtual COM port on your PC and uses a FTDI chip for Serial to USB conversion. Drivers are available here if required, but most PCs recognize the USB Modem and will install drivers automatically. While Alpha Station may be used to examine sensor data, raw data is available to the user by simply displaying all bytes received when opening the Virtual Com Port at 115.2K Baud, 8 Data Bits, 1 Stop Bit, No Parity. Since data is transferred as byte values, terminal windows such a HyperTerminal are not an ideal choice for viewing incoming data unless as these terminals are designed to display ASCII text. Some terminal software may offer settings for viewing raw byte values. We still recommend using Alpha Station as a learning tool for NCD wireless sensors as users will have the ability to display raw data as well as parsed data.
For specific instructions on using each modem, please review the relevant modem documentation below:
The above video demonstrates the USB Modem and how it may be used with NCD Long Range Wireless Sensors.
The above video demonstrates the Ethernet Modem and how it may be used with NCD Long Range Wireless Sensors.
Sensor
2-Mile Range
Modem
Raw Sensor Data
USB, Ethernet, Wi-Fi,
Bluetooth, RS-232, RS-485
Interface to PC
Using Gateways
NCD Gateways were designed to work directly with popular cloud technologies such as AWS, Azure, and MQTT. NCD Gateways receive Long Range Wireless Sensor data, Parse Incoming data, and Publish the converted results directly to your favorite cloud platform. While the underlying protocol for communications to the cloud is MQTT, each cloud provider uses a different authentication method. Each gateway supports the authentication method implemented by each cloud provider. The MQTT Gateway includes standard authentication protocols implemented by most MQTT brokers.
Unlike Modems, NCD Micro Gateways may need periodic firmware updates to keep up with the latest NCD sensors. Gateways exclusively use Wi-Fi for communications to popular cloud platforms. Like modems, Gateways work up to 2 miles from the sensor (line of sight) depending on user-selected communication options. Gateways offer a low-cost method of communicating to the cloud. While there is no hard limit as to the number of supported sensors by a single Micro Gateway, we recommend using gateways in applications where 20 or less sensors are installed in a local area. For larger installations, the IoT Edge Computer should be used to provide the needed horsepower.
Sensor
2-Mile Range
Gateway
Interpreted Sensor Data
Wi-Fi Interface
AWS, Azure, MQTT,
or Losant Cloud
Using IoT Edge Computers
The NCD IoT Edge Computer offers the most powerful interface available for NCD Long Range Wireless Sensors. Like modems and gateways, the NCD Edge is capable of receiving sensor telemetry up to 2 miles away. The Edge is a small Linux computer pre-loaded with Node-RED and NCD sensor libraries. Raw sensor data is fed into Node-RED for processing, allowing the development of custom flows for a wide range of localized processing applications.
Integrated hardware makes it easy to send NCD sensor telemetry to AWS, Azure, Losant, or MQTT using Ethernet, Wi-Fi, or LTE communications. Integrated OLED display indicates connection status while integrated USB port may be used sensor data logging to a thumb drive.
Experience with Node-RED is a requirement for most users; however, NCD will consult with customers to provide custom Node-RED flows for specialized applications at additional cost.
While the NCD IoT Edge Computer is commonly thought of as programmable interface technology for NCD Long Range Wireless Sensors, this device may also be used to communicate to USB, Wireless, and Ethernet relay controllers for sensor monitoring and control applications. With additional customization, most of the NCD ecosystem of hardware may be controlled or monitored.
Sensor
2-Mile Range
IoT Edge Computer
Running Node-RED
Wi-Fi, Ethernet, LTE
AWS, Azure, MQTT,
or Losant Cloud
6
Field | Value ( or Default ) | Payload | Length | Description |
Header | 7F | 1 | API Data Header ( its not the API Header) | |
Node ID | 00 | 1 | User Defined ID | |
Firmware Version | 01 | 1 | Device Firmware Version |
Battery Level | 03,FE | 2 | Battery Voltage = 0.00322*(03*FF+FE) | |
Packet Counter | DE | 1 | Wireless Transmission Counter |
Sensor Type | 00,0x51 | 2 | Sensor Type 80 | |
Error/Reserve Byte | 00 | 1 | bit 0: OTF Ready (Ignored in this app as we do not depend on the common code for OTF) bit 1: (Validity of Data for sensor 1 , 0 means data is valid, 1 means error in accessing sensor) bit 2: (Validity of Data for sensor 2 , 0 means data is valid, 1 means error in accessing sensor) bit 3: Sensor 2 indicator bit (only in dual probe) , if this bit is set it means the packet has data for sensor 2. In Raw mode/Raw on Rqst, this bit is set only when raw data is coming from sensor 2, if not , then it is coming from sensor 1 In Processed mode, this bit is set to indicate that the packet includes data from sensor 1 and 2 bit 4 - 7 : Unused |
Mode Of Operation | 00 | 0 | 1 | 00- Processed 01- Raw 02 - On Demand |
Data Rate | 0A | 1 | 1 | Vibration Sample Rate |
Temperature | MSB,LSB | 2,3 | 2 | Temp in C = (MSB*FF+LSB)/100 |
RMS ACC in X Axis in mg | MSB,LSB | 4,5 | 2 | rms_acc_x_mg = MSB*FF+LSB |
MAX ACC in X Axis in mg | MSB,LSB | 6,7 | 2 | max_acc_x_mg = MSB*FF+LSB |
RMS Velocity in X Axis in mm/sec | MSB,LSB | 8,9 | 2 | rms_vel_x_mm_sec = (MSB*FF+LSB)/100 |
RMS Displacement in X Axis in mm | MSB,LSB | 10,11 | 2 | rms_disp_x_mm = (MSB*FF+LSB)/100 |
Frequency of Highest Peak in X direction | MSB,LSB | 12,13 | 2 | X1_Hz = (MSB*FF+LSB) |
Frequency of Second Highest Peak in X direction | MSB,LSB | 14,15 | 2 | X2_Hz = (MSB*FF+LSB) |
Frequency of Third Highest Peak in X direction | MSB,LSB | 16,17 | 2 | X3_Hz = (MSB*FF+LSB) |
RMS ACC in Y Axis in mg | MSB,LSB | 18,19 | 2 | rms_acc_y_mg = MSB*FF+LSB |
MAX ACC in Y Axis in mg | MSB,LSB | 20,21 | 2 | max_acc_y_mg = MSB*FF+LSB |
RMS Velocity in Y Axis in mm/sec | MSB,LSB | 22,23 | 2 | rms_vel_y_mm_sec = (MSB*FF+LSB)/100 |
RMS Displacement in Y Axis in mm | MSB,LSB | 24,25 | 2 | rms_disp_y_mm = (MSB*FF+LSB)/100 |
Frequency of Highest Peak in Y direction | MSB,LSB | 26,27 | 2 | Y1_Hz = (MSB*FF+LSB) |
Frequency of Second Highest Peak in Y direction | MSB,LSB | 28,29 | 2 | Y2_Hz = (MSB*FF+LSB) |
Frequency of Third Highest Peak in Y direction | MSB,LSB | 30,31 | 2 | Y3_Hz = (MSB*FF+LSB) |
RMS ACC in Z Axis in mg | MSB,LSB | 32,33 | 2 | rms_acc_z_mg = MSB*FF+LSB |
MAX ACC in Z Axis in mg | MSB,LSB | 34,35 | 2 | max_acc_z_mg = MSB*FF+LSB |
RMS Velocity in Z Axis in mm/sec | MSB,LSB | 36,37 | 2 | rms_vel_z_mm_sec = (MSB*FF+LSB)/100 |
RMS Displacement in Z Axis in mm | MSB,LSB | 38,39 | 2 | rms_disp_z_mm = (MSB*FF+LSB)/100 |
Frequency of Highest Peak in Z direction | MSB,LSB | 40,41 | 2 | Z1_Hz = (MSB*FF+LSB) |
Frequency of Second Highest Peak in Z direction | MSB,LSB | 42,43 | 2 | Z2_Hz = (MSB*FF+LSB) |
Frequency of Third Highest Peak in Z direction | MSB,LSB | 44,45 | 2 | Z3_Hz = (MSB*FF+LSB) |
Field | Description | Comment |
Header | 7F | API Data Header ( its not the API Header) |
Node ID | 00 | User Defined ID |
Firmware Version | 01 | Device Firmware Version |
Battery Level | 03,FE | Battery Voltage = 0.00322*(03*FF+FE) |
Packet Counter | DE | Wireless Transmission Counter |
Sensor Type | 00,0x51 | Sensor Type 80 |
Error/Reserve Byte | 00 | |
01 | Mode Of Operation | |
0A | ODR | |
07 | Three MSB bit of the Axis byte to indicate FSR And 3 LSB bits indicates Axis | |
13 | Hour | |
0B | Minute | |
00,00 | Device Temperature | |
77 | Total Number of RF Packets | |
01 | Current Packet Count value | |
01 DE | X1-Axis RAW ACC Data | X1= (01*0xFF+ 0xDE)*FSR coefficient |
FF 7A | Y1-Axis RAW ACC Data | Y1= (01*0xFF+ 0x7A)*FSR coefficient |
3F 8B | Z1-Axis RAW ACC Data | Z1= (01*0x3F+ 0x8B)*FSR coefficient |
01 DF | X2-Axis RAW ACC Data | X1= (01*0xFF+ 0xDF)*FSR coefficient |
FF 7B | Y2-Axis RAW ACC Data | Y2= (01*0xFF+ 0x7B)*FSR coefficient |
3F 8C | Z2-Axis RAW ACC Data | Z2= (01*0x3F+ 0x8C)*FSR coefficient |
The following guide demonstrates the fundamental configuration commands required to configure NCD Enterprise Low-Power Long Range Wireless Sensors. A Wireless USB Modem will be required to configure NCD wireless sensors over a wireless connection. The examples shown below assume prior knowledge of DigiMesh® API Packet Structure, including MAC addresses and checksum calculations. We STRONGLY ADVISE using NCD Alpha Station software to configure sensors; however, if integration of sensor configuration is absolutely required, the commands shown below may be used.
Please note the MAC address MUST be changed (shown in the API frames below as 00 13 A2 00 41 91 1B 83) to match the MAC address of a remote sensor. The checksum must also be re-calculated (the last byte of the API frame) to include the new MAC address. Additionally, the PAN ID must be set to 0x7BCD. This PAN ID is reserved for configuration ONLY, and may not be used for daily operation.
A working sample of configuration with source code is available by downloading Alpha Station software. Alpha Station includes an installer but also runs as editable source code under Microsoft Visual Studio Community Edition, a FREE download from Microsoft. Alpha Station handles all configuration commands automatically and is capable of configuring every device that has been discovered.
The commands shown below are explained in greater detail within product manuals, this guide is a summary overview of all configuration command samples. Also note that configuration commands cannot be sent to NCD wireless sensors while in run mode. Each sensor must be placed in configuration mode, which will drain the battery very quickly. Be SURE to execute these commands quickly and return each sensor to RUN mode to preserve battery life. Optionally, select NCD wireless sensors may be powered from a external power supply during configuration.
Step 1 : Power up the sensor.
Step 2: Every sensor has 2 buttons: Reset and Configuration (RST and CFG). Enter configuration mode by holding both buttons down. Next, release the reset button. Wait 6 seconds and release the CFG button. The sensor will send a Configuration API frame, indicating configuration mode is active. The API frame will look similar to this:
7E 00 1C 90 00 13 A2 00 41 91 1B 83 FF FE C2 7A 00 00 00 23 00 00 50 47 4D 00 00 00 00 00 00 0A
Above command contains the sensor MAC address. This MAC address may be used to send future targeted commands to this particular sensor.
In the above case, the MAC address is:
Note: Throughout this guide we will be sending data in broadcast mode and sensors ID and node ID will be set to 0. This is done to make these commands work with all the sensors and all the nodes. These commands may be used with all the sensors without any change.
For optimal performance keep only one sensor in config mode at a time.
Reminder: During configuration mode, the sensor PAN id needs to be set as 0x7BCD. When using Alpha Station software, this operation is completed automatically during configuration.
Warning: Batteries will drain quickly in configuration mode. Be sure to exit configuration mode as soon as possible by pressing and releasing the Reset (RST) Button on the sensor once configuration changes have been completed.
When the magnet is near the reset button, the red LED at the top of the sensor will glow faintly. However, when the magnet is near the configuration (cfg) button, the blue LED will light up brightly.
Read Sleep Duration
Read Sleep Duration Command
00 00 00 00 00 00 FF FF
A. Sensor MAC address
B. Sensor Over-all Payload
C. Delay Value
Payload
F7 02 00 00 00 01 00 01 2C
A. Node ID
0x01 (Byte 23)
B. New Delay Value
A. Sensor MAC Address
B. Complete Sensor Payload
C. Network ID
0x07FF (data bytes 23 and 24)
F7 05 00 00 00 7C DE
0x0000FFFF
A. Complete Sensor Payload
B. Sensor MAC address
C. Destination Address
Complete Payload
F7 03 00 00 00 12 34 56 78
Complete Payload
F7 01 00 00 00
Read Sensor Power Command:
B. Sensor Payload
C. Power Level
0x04 (data byte 23)
Lets say the number of retires is set to 5. In a normal case, the sensor will wake up, gather data, send data to the modem, and go back to sleep. But due to some environmental issues (lets say a few trucks were driving by and they came in between the sensor and the modem) the modem didn’t receive the data. In that case, the sensor will try 4 more times to send the data. If the modem still doesn’t get the data after all 5 tries, the sensor will quite trying and will go back to sleep. The sensor will wake up after the predefined sleep time and will try again.
C. Retries Number
0x0A (data byte 23)
Complete Payload
F7 06 00 00 00 05
Complete Payload
No. | Command | Header | Sub Command | Parameter Field | Default Value | Description |
1 | Set Broadcast Transmission | 0XF7 | 0x01 | – | 0000FFFF | This will set the address to Broadcast mode. All the receiver with same ENY key and PAN ID will get the data packets |
2 | Set ID and Sleep Interval | 0XF7 | 0x02 | NODE ID, D0 MSB,D1, D2 LSB | 0x00,0x00,0x02,0x58 | Sets the Device node ID and Data Transmission Interval. The node id value can go from 0-255 and The Data transmission value can go from 3-0xFFFFFF Seconds |
3 | Set Destination Address | 0XF7 | 0x03 | A0 MSB, A1, A2, A3 | 00,00,FF,FF | Sets the Destination Address of the sensor. The sensor will send Run mode Data packets to this Address |
4 | Set Power | 0XF7 | 0x04 | Power ( range 1-4) | 0x04 | Sets the RF power of the Sensor Radio |
5 | Set PAN ID aka Network ID | 0XF7 | 0x05 | ID0 MSB, ID1 LSB | 0x7FFF | Sets the PAN ID aka Network ID in the sensor. Only sensors, Gateway, and Modes with Same ID can communicate with each other |
6 | Set Retries | 0XF7 | 0x06 | Retries | 0x0A | Sets the number of Retries after unsuccessful transmission for the Sensor Radio |
7 | Read Sleep Interval | 0XF7 | 0x15 | – | 0x00,0x02,0x58 | Reads the stored Sleep Interval value from the sensor |
8 | Read Power | 0XF7 | 0x16 | – | 0x04 | Reads the stored RF Power value from the sensor |
9 | Read Retries | 0XF7 | 0x17 | – | 0x0A | Reads the stored Retries value from the sensor |
10 | Read Destination Address | 0XF7 | 0x18 | – | 00,00,FF,FF | Reads the stored Destination value from the sensor |
11 | Read PAN ID aka Network ID | 0XF7 | 0x19 | – | 0x7FFF | Reads the PAN ID aka Network ID |
12 | Enable Encryption | 0XF2 | 0x01 | – | 0x01 | Enables the Encryption of the Frame Transmitted from the Sensor |
13 | Disable Encryption | 0XF2 | 0x02 | – | – | Disables the Encryption of the Frame Transmitted from the Sensor |
14 | Set Encryption Key | 0XF2 | 0x03 | 00,K0 MSB, K1,K2,K3,K4,K5,K6,K7,K8,K9,K10,K11,K12,K13,K14,K15 | 55AA55AA55AA55AA55AA55AA55AA55AA | Sets the 128 bit AES Encryption Key |
COMMAND | COMMAND | SUB COMMAND | COMMAND CODE | ARGUMENT |
SET OUTPUT DATA RATE | F4 | 4F | 0x00 | 100sps (Range 1.56 – 25 Hz) 0x07 200sps (Range 3.125 – 50 Hz) 0x08 400sps (Range 6.25 – 100 Hz) 0x09 800sps (Range 12.5 – 200 Hz) 0x0A 1600sps (Range 25 – 400 Hz) 0x0B 3200sps (Range 50 – 800 Hz) 0x0C 6400sps (Range 100 – 1600 Hz) 0x0D 12800sps (Range 200 – 3200 Hz) 0x0E 25600sps (Range 400 – 6400 Hz) 0x0F NOTE: These are based on Default Filter Setting. LOW and HIGH PASS Filters Can be used to Change These Ranges |
GET OUTPUT DATA RATE | F4 | 4F | 0x01 | 100sps (Range 1.56 – 25 Hz) 0x07 200sps (Range 3.125 – 50 Hz) 0x08 400sps (Range 6.25 – 100 Hz) 0x09 800sps (Range 12.5 – 200 Hz) 0x0A 1600sps (Range 25 – 400 Hz) 0x0B 3200sps (Range 50 – 800 Hz) 0x0C 6400sps (Range 100 – 1600 Hz) 0x0D 12800sps (Range 200 – 3200 Hz) 0x0E 25600sps (Range 400 – 6400 Hz) 0x0F NOTE: These are based on Default Filter Setting. LOW and HIGH PASS Filters Can be used to Change These Ranges |
SET SAMPLING DURATION | F4 | 4F | 0x02 | Period of samples in seconds must be > 0 Sample duration value is multiple of 50mS i.e. setting sample duration to 1 will set the duration time to 50mSec, setting duration to 2 will set sample duration time to 100msec and so on |
GET SAMPLING DURATION | F4 | 4F | 0x03 | |
SET AXES ENABLE | F4 | 4F | 0x04 | Bit 0 —> X-axis Bit 1 —> Y-axis Bit 2 —> Z-axis Bit Set – Axis enabled Bit Cleared – Axis disabled |
GET AXES ENABLE | F4 | 4F | 0x05 | |
SET SAMPLING INTERVAL | F4 | 4F | 0x06 | Every 5 minutes 0x0 Every 10 minutes 0x01 Every 15 minutes 0x02 Every 20 minutes 0x03 Every 30 minutes 0x04 Every 60 minutes 0x05 Every 120 minutes 0x06 |
GET SAMPLING INTERVAL | F4 | 4F | 0x07 | |
SET RTC | F4 | 4F | 0x08 | Byte 1 : Hours Byte 2 : Minutes Byte 3 : Seconds |
SET OPERATION MODE | F4 | 4F | 0x09 | 0x00 — Processed Mode 0x01 — Raw mode 0x02 — Processed +Raw on Request |
GET OPERATION MODE | F4 | 4F | 0x0A | |
SET FULL-SCALE RANGE | F4 | 4F | 0x0B | +/- 2g 0x00 +/- 4g 0x01 +/- 8g 0x02 +/- 16g 0x03 |
GET FULL-SCALE RANGE | F4 | 4F | 0x0C | +/- 2g 0x00 +/- 4g 0x01 +/- 8g 0x02 +/- 16g 0x03 |
SET FILTERS | F4 | 4F | 0x0D | 0x01 — Enable 0x00 — Disable |
Get FILTERS | F4 | 4F | 0x0E | |
Set Measurement Mode one | F4 | 4F | 0x0F | 0x00 — Device will send processed data, acc in mg, velocity in mm/sec and displacement in mm 0x01 — Device will send processed data, acc in ms^2, velocity in inch/sec and displacement in milli |
Get Measurement Mode | F4 | 4F | 0x10 | |
Set On Request Timeout | F4 | 4F | 0x11 | Value Range — 0-20sec. Device will decide how long device will stay awake and wait for raw time domain request from command |
Get On Request Timeout | F4 | 4F | 0x12 | |
Set Dead band Value in mg | F4 | 4F | 0x29 | Value Range — 0-255mg. default value is 35mg. Sensor will not consider acc values below dead band values as noise |
Get Dead band Value in mg | F4 | 4F | 0x29 | |
Extend OTF Configuration Time | F4 | 32 | Extend OTF on time by 30sec | |
Exit OTF Configuration Time | F4 | 33 | ||
Set INT Threshold | F4 | 3C | 0x08 | The sensor will wake up and take samples when vibration goes above this threshold(Set threshold 400mg, Multiple of 50mg) |
Get INT Threshold | F4 | 3D | ||
Set Acceleration Alert Threshold | F4 | 3E | 0x08 | RED Alert Led Will Blink If the RMS acceleration readings go above this threshold(Set threshold 400mg, Multiple of 50mg) |
Get Acceleration Alert Threshold | F4 | 3F | ||
Set Velocity Alert Threshold | F4 | 40 | 0x0A | RED Alert Led Will Blink If the RMS Velocity readings go above this threshold(Set threshold 20mm/sec, Multiple of 2mm/sec) |
Get Velocity Alert Threshold | F4 | 41 | ||
Set Alert Mode to Acceleration | F4 | 42 | 0x00 | Alert LED will blink if readings go above set acceleration threshold |
Set Alert Mode to Velocity | F4 | 43 | 0x01 | Alert LED will blink if readings go above set Velocity threshold |
REQUEST Raw Data from One Channel Sensor | F4 | 4F | 0x13 | Once Sensor Receives This command it will Send RAW data to Requester |
REQUEST Raw Data from Two Channel Sensor Probe One | F4 | 4F | 0x13, 0x01 | Once Sensor Receives This command it will Send Probe One RAW data to Requester |
REQUEST Raw Data from Two Channel Sensor Probe Two | F4 | 4F | 0x13, 0x02 | Once Sensor Receives This command it will Send Probe Two RAW data to Requester |
Low Pass Filter | F4 | 34 | 00 | Set this value to set LPF cut off freq. The range of this parameter is 0-9. If its set to 0, it will set the LPF freq to ODR/4 set to 1 LPF freq = ODR/8 set to 2 LPF freq = ODR/16 set to 9 LPF freq = ODR/2048 |
High Pass Filter | F4 | 36 | 00 | Set this value to set HPF cut off freq. The range of this parameter is 0-9. If its set to 0, it will set the HPF freq to ODR/4 set to 1 HPF freq = ODR/8 set to 2 HPF freq = ODR/16 set to 9 HPF freq = ODR/2048 |
Low Pass Filter Probe Two | F4 | 38 | 00 | Set this value to set LPF cut off freq. The range of this parameter is 0-9. If its set to 0, it will set the LPF freq to ODR/4 set to 1 LPF freq = ODR/8 set to 2 LPF freq = ODR/16 set to 9 LPF freq = ODR/2048 |
High Pass Filter Probe Two | F4 | 3A | 00 | Set this value to set HPF cut off freq. The range of this parameter is 0-9. If its set to 0, it will set the HPF freq to ODR/4 set to 1 HPF freq = ODR/8 set to 2 HPF freq = ODR/16 set to 9 HPF freq = ODR/2048 |
7
Vibration Sensor installation is an extremally critical step to ensure the best results sensor mounting guidelines should be followed.
A. Sensor Main Body Mount — During mounting, make sure
- Install the main sensor box as high as possible to avoid any object which might come in between the sensor and the modem/gateway
- The antenna should not be installed inside any metal box.
B. Sensor Mounting — This is the part that measures vibration. There are three mounting options. if magnets are being used to mount the sensor
- The magnet should be flat to the surface
- Remove any oil, paint, or dirt between the sensor Magnet and the installation surface
- The sensor can be installed in any position while installed. Ensure cables are appropriately managed and there is no stress on the sensor.
There are several ways to mount a vibration sensor, depending on the specific sensor and the application it will be used for. Here are some general steps for mounting a vibration sensor:
Determine the best location for the sensor. Consider factors such as the type of equipment being monitored, the type of vibrations being measured, and the accessibility of the sensor for maintenance or replacement.
Clean the surface where the sensor will be mounted to ensure a secure and reliable connection.
Install any necessary mounting hardware, such as brackets or adhesive pads, onto the sensor and the mounting surface.
Carefully position the sensor on the mounting surface and secure it in place using the mounting hardware.
Connect the sensor to the appropriate monitoring or control system, following the manufacturer’s instructions.
Test the sensor to ensure it is properly installed and functioning correctly.
8
ncd vibration sensor V3 can be used with any ncd modems and gateway and from there data can be pushed to any cloud or local server.
If there is no data on the gateway side, here are few things users can check
- Sensor is powered on
- Batteries are in good condition ( Leaving the sensor in cfg mode for a long time will drain batteries)
- Antenna is connected and pig tail is secured
- Press the reset button and sensor will send a welcome message followed by a sensor data packet.
- Check the LED status. if the LED is blinking as expected, means sensor is working
On the Receiver side —
- If you are using a modem make sure correct port settings are selected
- Sensor radio module and Modem/gateway radio module are of same frequency
- Gateway is connected to WiFi
- Gateway and Sensor are atleast 3 feet apart
Sensor Support Map
9
Sensor | Sensor Type | Product SKU | Alpha Station | AWS Gateway | Azure Gateway | MQTT Gateway | Node Red | Python | Min Sample Interval |
Temperature Humidity Sensor | 1 | PR49-24A | Yes | Yes | Yes | Yes | Yes | Yes | 3Sec |
Push Notification 2-Channel | 2 | PR52-3D | Yes | Yes | Yes | Yes | Yes | Yes | Status change And 3 Sec |
ADC Converter 2-Channel | 3 | PR52-1 | Yes | Yes | Yes | Yes | Yes | Yes | 3Sec |
Thermocouple 1-Channel | 4 | PR52-2 | Yes | Yes | Yes | Yes | Yes | Yes | 3Sec |
Gyro Magneto Acellero | 5 | PR49-24D | Yes | Yes | Yes | Yes | Yes | Yes | 5Sec |
Wireless Pressure Sensor | 6 | PR49-24H | Yes | Yes | Yes | Yes | Yes | Yes | 3Sec |
Acceleration and Impact Detection | 7 | PR49-24K | Yes | Yes | Yes | Yes | Yes | Status change and 3Sec | |
Wireless Vibration Sensor | 8 | PR49-24E | Yes | Yes | Yes | Yes | Yes | Yes | 5Sec |
Wireless Proximity Sensor | 9 | PR49-24B | Yes | Yes | Yes | Yes | Yes | 3Sec | |
Wireless Ambient Light Sensor | 10 | PR49-24C | Yes | Yes | Yes | Yes | Yes | Yes | 3Sec |
In Development - Wireless Color Sensor | 11 | ||||||||
Wireless 3 Channel Thermocouple Sensor | 12 | PR55-19B | Yes | Yes | Yes | Yes | Untested | 5Sec | |
Wireless 1 Channel AC Current Sensor | 13 | PR52-7 | Yes | Yes | Yes | Yes | Yes | 6Sec | |
Wireless 1 Channel 4-20mA Receiver | 14 | PR52-9 | Yes | Yes | Yes | Yes | Untested | 3Sec | |
Wireless 1 Channel 0-10V Receiver | 15 | PR52-10 | Yes | Yes | Yes | Yes | Untested | 3Sec | |
Wireless 1 Channel Soil Moisture Sensor | 16 | PR55-2B | Yes | Untested | Untested | Untested | Untested | 3Sec | |
Wireless 1 Channel AC Voltage Sensor | 17 | PR52-13 | Yes | Untested | Untested | Untested | Untested | 6Sec | |
Wireless 1 Channel Frequency/Pulse Sensor | 18 | PR52-14 | Yes | Untested | Untested | Untested | Untested | 3Sec | |
Wireless 2 Channel Current Sensor | 19 | PR55-4B | Yes | Yes | Yes | Yes | Untested | 6Sec | |
Wireless High Precision Pressure Sensor | 20 | PR55-24 | Yes | Yes | Yes | Yes | Untested | 3Sec | |
Wireless Differential Bi directional Pressure Sensor | 21 | PR49-24M | Yes | Yes | Yes | Yes | Untested | 3Sec | |
Wireless 0-24V AC/DC Optically Isolated Inputs | 22 | PR52-12 | Yes | Untested | Untested | Untested | Untested | Status change and 3Sec | |
Wireless 2 Channel Thermocouple Sensor | 23 | PR55-19A | Yes | Yes | Yes | Yes | Untested | 3Sec | |
Wireless Activity detection sensor | 24 | PR49-24J | Yes | Yes | Yes | Yes | Yes | Status change and 3Sec | |
Wireless Asset Monitor sensor | 25 | PR49-24I | Yes | Yes | Yes | Yes | Yes | Status change | |
Wireless Pressure Sensor | 26 | PR52-33P | Yes | Untested | Untested | Untested | Untested | 3Sec | |
Wireless Environmental Sensor | 27 | PR49-24L PR55-45L | Yes | Yes | Yes | Yes | Yes | 24Sec | |
Wireless 3 Channel Current Sensor | 28 | PR55-26C | Yes | Untested | Untested | Untested | Untested | 6Sec | |
Wireless Linear Displacement Sensor | 29 | PR55-2E | Yes | Untested | Untested | Untested | Untested | 3Sec | |
Wireless Structural Monitoring Sensor | 30 | PR55-2F | Yes | Untested | Untested | Untested | Untested | 3Sec | |
Air Quality TVOC eCO2 Temperature and Humidity Sensor | 31 | PR49-24G | Yes | 24Sec | |||||
Particulate Matter Sensor | 32 | PR52-33M | Yes | 60Sec | |||||
Wireless AC Current Detect Sensor | 33 | PR52-45 | Yes | Status change and 3Sec | |||||
Wireless Tank Level | 34 | Yes | 3Sec | ||||||
Wireless 1 Channel Counter | 35 | PR52-3B | Yes | Yes | Yes | Yes | Yes | Counter Thershold and 3Sec | |
Wireless 2 Channel Counter | 36 | PR52-3C | Yes | Yes | Yes | Yes | Yes | Yes | Counter Thershold and 3Sec |
Wireless 7 Push Notification | 37 | PR52-18 | Yes | Yes | Yes | Yes | Yes | Status change and 3Sec | |
In Development | 38 | ||||||||
Wireless 3 Wire RTD Temperature Sensor | 39 | PR52-27 | Yes | Untested | Untested | Untested | Untested | 3Sec | |
Wireless Enterprise Vibration Sensor** | 40 | PR52-33N | Yes | Yes | Yes | Yes | Yes | Yes | 10Sec |
RPM Proximity Sensor | 41 | Yes | Untested | Untested | Untested | Yes | 3Sec | ||
Wireless 0-24VDC Voltage Monitor | 42 | PR52-10A | Yes | 6Sec | |||||
Wireless Dual Temperature Humidity Current Detection Sensor | 43 | PR55-41A | Yes | Status change and 3Sec | |||||
Wireless CO2 Gas Sensor | 44 | PR52-33Q | Yes | 60Sec | |||||
4-20mA 16-Bit Input Transmitter | 45 | PR55-5A | Yes | 6Sec | |||||
Motion Detection Sensor | 46 | PR52-48 | Yes | Status change and 3Sec | |||||
Wireless Tilt Sensor | 47 | PR52-33_TS | 3Sec | ||||||
4-20mA 16-Bit Input Transmitter | 48 | PT55-48 | Yes - Untested | 6Sec | |||||
Wireless 6 Channel Thermocouple Sensor | 49 | PR55-47_6TC | 6Sec | ||||||
Predictive Maintenance Sensor | 50 | PR55-20A | Yes | Untested | Untested | Untested | Untested | 10Sec | |
6 Channel Current Sensor | 51 | PR55-59_6CT | Yes - Untested | 10Sec | |||||
Wireless 2 Channel 4-20mA Receiver | 52 | PR55-47_2CR | Yes - Untested | 6Sec | |||||
Wireless Air Quality CO2 and PM Sensor | 53 | PR55-59_THPC | Yes - Untested | 60Sec | |||||
Wireless 2 Channel RTD | 54 | PR55-47_2RTD | Yes - Untested | 6Sec | |||||
Wireless 3 Channel RTD | 55 | PR55-47_3RTD | 10Sec | ||||||
Wireless 2 Channel 0-10VDC Receiver | 56 | PR55-47_2DC | Yes - Untested | 6Sec | |||||
Wireless Tank Level V2 | 58 | PR55-81T | Yes - Untested | 6Sec | |||||
Wireless Air Flow/Velocity Sensor | 60 | PR55-24V | 3Sec | ||||||
Wireless pH Temperature Sensor | 61 | PR55-47pH | Yes | 60Sec | |||||
Wireless ORP Temperature Sensor | 62 | PR55-47ORP | Yes - Untested | 60Sec | |||||
Wireless pH and ORPTemperature Sensor | 63 | PR55-47pHORP | Yes | 60Sec | |||||
Wireless EC Sensor | 64 | PR55-47EC | Yes | 60Sec | |||||
Wireless DO Sensor | 65 | PR55-47DO | Yes - Needs Parser Review | 60Sec | |||||
Wireless EC and DO Sensor | 66 | PR55-47EC_DO | Yes - Needs Parser Review | 60Sec | |||||
Wireless PAR Sensor | 67 | PR55-57PAR | Yes | 60Sec | |||||
Wireless 2 Channel Soil Moisture Sensor | 68 | PR55-2C | 60Sec | ||||||
Wireless 1 Channel Soil Temp Moisture and EC Sensor | 69 | PR55-57_SLA | 60Sec | ||||||
Wireless 2 Channel Soil Temp Moisture and EC Sensor | 70 | PR55-65_SLB | 60Sec | ||||||
Wireless 3 Channel Soil Temp Moisture and EC Sensor | 71 | PR55-65_SLC | 60Sec | ||||||
Wireless SDI Soil Moisture Temperature Moisture Probe | 72 | PR55-66A | 60Sec | ||||||
Wireless Temp Humidity Pressure Air quality Sensor | 74 | PR55-81L | 60Sec | ||||||
Wireless Siemens Air Velocity Probe | 75 | PR55-5C | 20Sec | ||||||
Wireless CO Sensor | 76 | Yes - Untested | 90Sec | ||||||
Wireless 3 Channel SDI Soil Moisture Temperature Moisture Probe | 77 | PR55-66C | 60Sec | ||||||
Wireless Oil Particulate Count Sensor | 78 | PR55-81P | 60Sec | ||||||
Wireless Oil Quality Analysis Sensor | 79 | PR55-57E | 60Sec | ||||||
Wireless Enterprise Vibration Sensor V3 | 80 | PR55-61E | 5Min | ||||||
Wireless Enterprise Dual Vibration Sensor V3 | 81 | Yes - Untested | 5Min | ||||||
Predictive Maintenance V3 Sensor | 82 | Yes - Untested | 5Min | ||||||
Standalone Smart Vibration Sensor V3 | 84 | Yes - Untested | 5Min | ||||||
Wireless One Channel Auto Lubricator | 85 | PR55-81OL | 5Min | ||||||
Wireless 1 Channel Current Sensor With Frequency | 87 | PR55-59BF | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless One Channel Ultrasound Sensor | 88 | PR55-81US | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless Two Channel Ultrasound Sensor | 89 | PR55-81U | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless 1 Channel 0-100Amp DC Current Sensor | 90 | PR55-5DC | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless Air Velocity Sensor HVAC | 91 | PR55-81AV | 20Sec | ||||||
Wireless 3 Channel Current Sensor With Frequency | 92 | PR55-59CF | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless Oil Quality Analysis Sensor Lite | 93 | PR55-57OL | 60Sec | ||||||
Wireless 1 Channel 0-24V DC Receiver | 95 | PR55-5F_24V | 6Sec | ||||||
Wireless 1 Channel 0-48V Receiver | 96 | PR55-5F_48V | 6Sec | ||||||
Wireless One Channel Ultrasound Sensor FFT | 97 | PR55-100US | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless Two Channel Ultrasound Sensor FFT | 98 | PR55-100U | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Wireless Laser Sensor | 99 | PR50-56L | Yes | Untested | Untested | Untested | Untested | 10Sec | |
Custom Accelero Meter | 103 | PR50-54A | Yes - Untested | 5Min | |||||
Wireless 1 Auto Luber With Ultrasound Vibration Sensor | 105 | PR55-85_1AL | 6Sec | ||||||
Wireless 2 Channel Auto Luber With Ultrasound Vibration Sensor | 106 | PR55-85_2AL | 6Sec | ||||||
Wireless 4 Channel 4-20mA Transmitter | 107 | PR55-89D | 6Sec | ||||||
Wireless Machine Uptime Monitor Sensor | 108 | PR55-87UT | 6Sec | ||||||
Wireless Custom Solar Sensor | 109 | PR63-5A | 6Sec | ||||||
Wireless Enterprise Vibration Sensor V4 | 110 | PR55-95E | 5Min | ||||||
Wireless Enterprise Dual Vibration Sensor V4 | 111 | PR55-95N | Yes - Untested | 5Min | |||||
Predictive Maintenance V4 Sensor | 112 | PR55-95PM | Yes - Untested | 5Min | |||||
Standalone Smart Vibration Sensor V4 | 114 | PR55-83A | Yes - Untested | 5Min | |||||
Dual Pressure Sensor | 118 | PR63-2 | Yes - Untested | 5Min | |||||
Wireless Machine Hour meter | 119 | PR63-16A | Yes - Untested | 5Min | |||||
Wireless H2S Sensor | 120 | PR55-101A | Yes - Untested | 5Min | |||||
Wireless Wood Moisture Sensor | 121 | PR63-11 | Yes - Untested | 5Min | |||||
Wireless 4-20mA Splitter | 122 | PR55-102B | Yes - Untested | 5Min | |||||
Wireless 3 Channel Production Counter | 123 | PR63-10A | Yes - Untested | 5Min | |||||
Wireless Modbus Flow Sensor | 124 | PR63-13A | Yes - Untested | 5Min | |||||
C_50-27 | 502 | ||||||||
C_Current_1C | 505 | Yes - Untested | |||||||
C_Current_3C | 506 | Yes - Untested | |||||||
C_Current_12C | 515 | Yes - Untested | |||||||
Custom Wireless Air Flow/Velocity Sensor | 517 | PR55-24V_MAYA | |||||||
Custom Wireless Vibration Sensor With Wire Draw Sensor | 519 | PR55-59_GEO | Yes - Untested | 5Min | |||||
Custom 6 Channel Current Temp Humid Sensor | 520 | PR55-59_6C | Yes - Untested | 10Sec | |||||
Custom 3 Channel Light Sensor | 521 | PR55-59_LS | Yes - Untested | 10Sec | |||||
SDI Multi Soil Probe | 524 | PR55-81_SDI | Yes - Untested | 10Sec | |||||
Custom Noise Sensor | 531 | PR55-59_LS | Yes - Untested | 10Sec | |||||
Custom Wireless CO2 sensor | 535 | PR55-81_CO2 | Yes - Untested | 5Min | |||||
Custom Wireless DO Flow Sensor | 536 | PR55-81_CO2 | Yes - Untested | 5Min | |||||
Custom Wireless Vibration Sensor | 537 | PR55-67A_CS | Yes - Untested | 5Min | |||||
Custom Wireless RS485 IO-Link | 538 | PR55-88I | 5Min | ||||||
Wireless Modbus Sensor | 539 | PR55-88D | 5Min | ||||||
Wireless Inline Flow Sensor | 541 | PR55-89IFS | 5Min | ||||||
Wireless Inline Pulse Flow Sensor | 542 | PR63-10FS | 5Min | ||||||
Wireless seismic vibration sensor | 543 | PR63-1S | 5Min |
Revision History
Hardware Revision — D
Manual Revision — A
This product is designed and manufactured by National Control Devices ( ncd.io)
Address — 430 Market Street
Osceola, MO 64776
