RCMS & Gateway Setup
- Go to rcms-cloud.robustel.net
- Log in or signup
- MS account recommended, but not required
- On the left hand side after logging in choose Add/Remove Devices
- On this page click on the “ADD” button
- A pop-up should appear
- In a separate tab navigate to the web management portal of your local gateway
- Open your browser and enter the IP address or domain name (http://ncd-[last_four_of_mac].local
- See the Enterprise Gateway Quickstart Guide for more information
- Copy the Serial Number listed on the gateway’s dashboard into the SN field of RCMS
- On RCMS for the Mac/IMEI choose MAC from the dropdown menu
- Â Copy the MAC address listed under LAN Status of the Gateway’s Dashboard and paste it into the RCMS form
- Give the Device a name in RCMS
- Specify where the device will be located using the “Device Area” dropdown
- Choose ROS PRO on the DeviceOS field
- Assign any tags preferred
- Tags can be used to categorize gateways by application, location, department, etc.
- Provide a short description of the use case of this gateway.
- Check that this form looks similar to this example
- Once everything is set press the Save button
- Go back to your local Gateway’s web management and navigate to Services > RCMS
- Enable RCMS, RobustLink, and RobustVPN. Apply settings as shown in image below
- Hit Submit at the bottom of the page
- Click the Red Checkmark icon at the top of the page
- Go back to RCMS and click on RobustVPN
- Click on Manage VPN Groups
- If no groups exist click Create
- If your desired group already exists skip to step 28
- Assign a group name, encryption method, VPN region, and Virtual IP only
- Select the checkmark next to the Device recently added
- Select the Assign Users tab and select your user
- Click the OK button
- Confirm the region is correct by hitting yes on the subsequent modal alert
- Click on the desired group
- Click on the Devices tab
- Select the checkbox next to your desired Gateway and click Initialize
- Click the switch to connect VPN
- The icon under VPN status should turn green
- Open the web interface on the local gateway
- Navigate to Network > Firewall > General Settings
- Set Input to “Accept” in the General Settings box
- *Optional Step
- Click on the edit icon next to the Firewall Zone used by your Gateways WAN interface
- If you’re unsure of this refer to Appendix A
- Under Zones, make sure Input is set to Accept
- Insert image
- Under Access Control Settings select the protocols you want access to from the VPN
- Click on the Submit button
- Click the red checkbox along the top
Windows Client Instructions
- Go to rcms-cloud.robustel.net and log in
- Click on Support across the top of the RCMS portal
- Click the download icon next to RVPN Manager
- Unzip the newly downloaded file
- The filename should start with “Resources Batch Export-“
- Run the installer located in the newly unzipped folder and install the RobustVPN manager
- After Installation run the RobustVPN_Manager
- Choose Global Default (rcms-cloud.robustel.net)
- Login to the VPN Manager using the same account used for RCMS
- Once logged in choose the VPN Group created earlier and click START
- Go back to the RCMS portal and click on Robust VPN along the top > Manage VPN Groups
- Select the VPN Group that contains your target gateway
- Click on Devices
- Copy the IP address of your target gateway
- Open a new browser tab and paste the IP address into it
- Open a new browser tab and paste the IP address with :1880 after it
- If SSH is enabled on this device you can open Windows Powershell and run the command
