Introducing NCD’s One Channel Vibration Sensor Gen4. Lightweight rugged and reliable for accurate asset monitoring and boasting up to a 2-mile range using a wireless mesh networking architecture & Incorporating a 16-bit Vibration and integrated Temperature sensor.
This sensor combines these data with temperature data in a data packet, and transmits the result to modems and gateways within wireless range. Once transmission is complete, the vibration sensor goes back to sleep, thus minimizing power consumption.
Features:
- Small & lightweight for ease of installation.
- IP65 rated sealed enclosure for dust &
moisture protection. - Metal probe housing for durability in harsh industrial environments.
- A versatile user-configurable sample rate for slow or fast-running machines
- Integrated temperature sensor in base.
- In-Built Machine Learning optimizes power consumption.
- Asset On-Time Calculator automatically tracks operational status.
- Hardware Accelerator enhances vibration sampling accuracy.
- Configurable Sample Rate – 100Hz to 25.6KHz
- Available Frequencies – 900Mhz, 868Mhz, and 2.4Ghz
- Supports MESH networking via DigiMesh
- Fully open Node-RED library for configuration and data ingestion
Figure 1: Device Overview
| Height | 85mm | |||
| Base diameter | 48mm | |||
| Weight | 225g | |||
| Enclosure Rating | IP67 | |||
| Mounting | ¼-28 UNF thread Magnetic mount | |||
| Temperature Sensor Accuracy | ±1°C | |||
| Accelerometer Sampling Rate | 26.6 kHz | Vibration Sensor Data Rate | ||
| Accelerometer Bandwidth | 6.3 kHz | |||
| Accelerometer Full-Scale Range | -16g | +16g | ||
| Accelerometer Noise | 70 μg/ √Hz | |||
| Sample Duration | 1sec | 1sec | 10sec | Device will take readings for the set time and then send over wireless |
Enclosure Type 1
Enclosure Type 2
RF Module Specifications
Probe Specifications
While changing the batteries:
- Turn off the sensor
- Only use a new D-cell battery (obtain one from NCD, as it has a built in supercapacitor, this is not a regular battery).
- Make sure to align the connector in the proper orientation (this will assure you match the polarity)
- The battery should not be replaced in fire-risky areas
- Do NOT install a rechargeable battery
Head to the NCD store if you want to purchase the One Channel Vibration Sensor Gen4.
